Question about Carrier XHB123D X/Y Series Heat/Cool Air Conditioner
Carrier gas furnace wont start model number 59SP5A080E171116 yellow light flashes
  • 230 Answers
SOURCE: model number for Carrier furnace with issue for blower 5 minute off delay
I believe that this model number is for an air conditioner evaporator coil. This unit is probably directly attached to your furnace. The Model number for the furnace will be located in the compartment where the flames can be seen. It will be on a sticker or plate that contains lots of other information too like BTU/h, Volts etc...
The number you gave me gives me this info:
Cased air conditioning evaporator coil.
3 Tons
Horizontal application
Posted on Jun 27, 2008
  • 124 Answers
SOURCE: pilot ligting instructions
many of the newer furnaces don't have a standing pilot. look to see if you have a gas valve with a knob on top that says off pilot and on. look to see if a tube the size of a pencil comes out of the valve and goes down by one of the burners, look to see if there is a little gold piece of metal tubing protruding down to the opening of the larger tube . that is where you place the match. i prefer to use a grill lighter. safer and positive flame. turn knob to off wait 5 minutes for any gas to disipate. be sure your incoming gas valves are all open . usually at the meter and one at the furnace. usually the handle is in line with the pipe when open. from the off position, turn the knob on the furnace gas valve to pilot position and push down on it as you turn. this lets gas flow to the pilot tube by the burner where you have you flame starter lit and waiting. once pilot lights hold down on button for 3 minutes or less. longer is better to be sure the thermocouple senses flame . then gently release the downward pressure and the pilot should stay lit and you gently turn knob to on. if pilot goes out you may have a bad thermocouple. be especially careful if its lp or propane as that gas does not disipate like natural gas and can virtually lay on the floor till ignited. also consider having the heat exchanger checked by a pro with a carbon monoxide detector. they do crack after a few years and can be deadly when they do. good luck
Posted on Nov 13, 2008
Therinnaiguy
  • 1420 Answers
SOURCE: Carrier furnace, pilot does not light, fans run
On a call for heat, the 24 volt thermostat sends a signal to the control module. The control module will indicate a call for heat with a light on the control either blinking or remain solid depending upon model. The inducer (exhaust) blower will purge all gasses from the furnace and pressurize a pressure switch. Once the pressure switch tells the module to continue, the electronic ignition will energize and send 120 volts to the igniter. The igniter will glow and you will be able to see it if viewed thru the small inspection port. Once the igniter gets hot enough, it sends a signal to the module opening up the gas valve (24 volts). Either a pilot will come on or the burner tube will ignite then spread the flame to all burners. Lastly a safety sensor will be looking for a certain temperature within a few seconds and the furnace will continue to operate and the room air blower will turn on in a minute or two.
What could go wrong? The unit will not run if there is no signal from the thermostat (bad thermostat or broken wire), the control module does not sense a signal from the thermostat (bad control), the inducer does not energize (bad motor), the pressure switch does not close (blocked vent piping, bad switch, plugged condensate hose), the igniter does not energize (bad control, bad igniter), the gas valve does not open or there is no gas (bad gas valve, broken wire, no gas), the pilot does not light (dirty pilot), the burner does not light (bad burner, plugged orifice, not enough combustion air), the flame does not spread to each burner (bad flame spreader, dirty flame spreader, more bad burners), the flame safety sensor does not detect flame (dirty or bad flame spreader, bad flame sensor, broken wire, bad control), or the room air blower does not energize (bad fan motor, bad control).
Posted on Nov 28, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: Carrier Gas Furnace runs fine randomly stops blowing LEDs flash
That blinking light may be the diagnostic light. Count the blinks next time it fails. Carrier units will have two different blinks depicting the error code such as one blink followed by a pause than 3 blinks giving you an error code of 13. Then look at the wiring diagram, it will have an error code chart telling you where to start with your diagnosis. You already know that if you remove the cover it erases the error code, so look thru the small window first.
Posted on Dec 01, 2009
  • 288 Answers
SOURCE: carrier furnace burners will not light.if i blow
this sounds exactly like the problem. I replaced a gas valve yesterday in a Goodman furnace that had the same symptoms. I would check it or have it checked with a manometer before you replace the valve. If your inlet pressure is right and you cant get enough pressure by turning the adjustment screw clockwise, it is bad. LP should have @11-13inches of water column coming into the vavle and an outlet pressure of 7 inches of water column. Natural gas should have @5-7 inches coming in and an outlet pressure of 3.5 inches of water column
Posted on Jan 06, 2010
Why wont an older model carrier gas furnace light when standing pilot light is lit at all times? Why would there be no gas at the burners
when it comes to GAS appliances , I do not recommend any self fixes . they can explode and do you serious damage even up to death .call a gas furnace repairman
Feb 28, 2016 | Carrier Weathermaker 8000 Gas Furnace 125k...
A carrier furnace model 58dla110---10122 won't start
Make sure the kill switch on the blower door is closed, or furnace won't do anything. Then remove power from furnace for a few seconds, then try again. Still no go? Take a jumper wire and jump the "r" terminal to the "w" terminal on the furnace's board. This bypasses the thermostat. This is only for testing. If it still wont run, call service guy. Gas furnaces are not good things to tinker with.
Nov 25, 2013 | Heating & Cooling
How to install a spark ignitor in a gas furnace?
How to install a spark ignitor in a gas furnace? - Fixya
www.fixya.com/support/t15727344-install_spark_ignitor_in_gas_furnace
Jan 8, 2013 - How do I connect the high voltage wire to the Model 990-516 spark - Air ... SOURCE: Goodman furnace wont light, ignitor suspected. Notice.
carrier igniter
Jan 08, 2013 | Heating & Cooling
Carrier furnace HK42FZ011 wiring diagram
carrier plas 90 bryant Gas Furnace wont light - LED has 2 blinks what can be
Dec 25, 2012 | Heating & Cooling
Intertherm furnace model # MMHB-070ABHR-06 red light blinks two times
Number of flashes mean different things for diff models. The meanings of those flashes should be posted somewhere on the unit; usually inside front of the bottom service panel. Though you can't truly diagnose a problem by number of flashes they can give you an idea of where to look for a problem. There are a ton of videos and how-to's about furnaces on youtube by real service techs. Most modern furnaces have basically the same set-up and features so don't worry about your paticular brand; but of course that would be the best place to start looking. You could start here to familiarize yourself with your brand of furnace:
http://www.youtube.com/results?search_query=Intertherm+Gas+Furnace+&oq=Intertherm+Gas+Furnace+&gs_l=youtube.12...62316.62316.0.63907.1.1.0.0.0.0.202.202.2-1.1.0...0.0...1ac.Ko9QBdxK6OM
And then here:
http://www.youtube.com/results?search_query=gas+furnace+won%27t+light&oq=gas+furnace+won%27t+light&gs_l=youtube-reduced.3..0.5619.10061.0.11544.11.5.0.6.6.1.741.1982.0j1j2j5-1j1.5.0...0.0...1ac.1.5-0zJyxNMEo
Hope this helps.
Dec 21, 2012 | Heating & Cooling
I have a carrier furnace and a error led code is one long then an immediate short folliowed by another short before the long
Lucky for Light Emitting Diodes huh? (led)
I'm looking at a legend, on a Carrier furnace door, right now.
One long followed by two short is the "twenty one" code.
Here's what the door sticker says;
"EACH OF THE FOLLOWING CODES IS A TWO DIGIT NUMBER WITH THE FIRST DIGIT DETERMINED BY THE NUMBER OF SHORT FLASHES AND THE SECOND DIGIT DETERMINED BY THE NUMBER OF LONG FLASHES."
Look on your legend, inside the door of the furnace, to find the code diagnostic recommendation.
Make sure to read the codes several times and see the code from the beginning so you make sure the code starts with that digit.
Knowing this furnace means; the code diagnostic recommendation is just that, a suggestion. It will not tell a trained tech what to fix, only a starting point and tell-tale signs.
Code 21 is the gas valve lockout, and will not reset. May be a gas valve, relay or control board (most likely). Call someone.
It's complex for a trained person too, so if you're not familiar, this isn't something to make a mistake on.
Luck to you. Let me know how you get on.
myairfixer@gmail.com
Dec 23, 2010 | Carrier Heating & Cooling
I have a Carrier Infinity 96 gas furnace with no heat
That means that the furnace is throwing a code to trouble shoot whats wrong. Most of the time, furnaces will have a code list on the inside of the door cover to explain what each code means, some of them don't. Its hard to say what it could be without knowing where to start. However, answering a few questions with someone knowledgeable over the phone if possible could help speed things up, but it would involve you being at the furnace and seeing what happens before it throws the code. If you do have a code list, this would help tremendously.
Feb 03, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
Nov 30, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Gas wont ignite
unless you are well trained in troubleshooting you need a pro .carrier furnastys are overly complex you should call carrier dealer if you want the shortest route to a workin system
Feb 23, 2009 | Coleman Propane Forced Air Heater...
Carrier XHB123D X/Y Series Heat/Cool Air Conditioner Logo
74 people viewed this question
Top Carrier Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
