Question about Kenmore Refrigerators
My Kenmore Refrigerator will not dispense water'
My Kenmore Refrigerator is unable to dispense water.
  • 163 Answers
Hi!! you have a bad water valve located in the lower back of the frig..or your water tank located inside your frig is frozen.goog luck..
Posted on Jan 20, 2009
Kenmore side by side refrigerator water dispensor will not shut off
Your water control valve is defective and will need to be replaced. Even though you hear the electrical part of the valve turn off the mechanical part of the control valve is stuck open causing water to continue to flow. What is your model number? Kenmore model numbers look like this example=> 312.234567 If you can find your model number I will show you the replacement part number, Thanks Sea Breeze
Nov 29, 2012 | Kenmore 18.3 cu. ft. Top Freezer...
Clogged Water Dispensor
The water inlet solenoid is the culprit. It lets water into the icemaker and water for the dispenser. Follow the waterline to the back of the frige and it ends at the water inlet solenoid. Note the 2 solenoids built into 1 part. Replace this part and you are done. Don't forget to unplug frige and turn off the water before you replace this part. EZ FIX...
Mar 29, 2010 | Kenmore 21.7 cu. ft. Top Freezer...
No water coming from water dispenser.
It is possible the water control valve for that dispenser has failed and will not open. This happens a lot for those and the ice maker valves. All you need is the model number for your refrigerator and that will look like this for Kenmore. 213.564897 for example. and I will help you find the correct part number. Sea Breeze
Nov 24, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My Kenmore side by side unit leaks water onto the floor and the water dispenser has stopped working. When I hit the dispense switch I hear water squirting.
Probably the plastic tube that came from the solenoid is broken somewhere between the solenoid and the dispenser(usually under the refrigerator).
Sep 20, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Water Dispenser Temperature not acceptable
This is a brand new refrigerator - I cannot solve the problem and I am returning the refrigerator to the dealer. Thank you, but I am not paying $ to fix a new refrigerator. I have tried everything.
Feb 02, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Water dispenser in the door is dispensing water very very slow.
check and see if the ice is fully formed or look hollow / if hollow then run you a new water line to frig / if cubes are full then replace water valve.
Nov 24, 2008 | Kenmore 53642 / 53644 Side by Side...
check the mirco-switches behind the panel at the dispenser section. basically, when you depress the lever for water or ice, those levers make contact with a switch, and the switch turns on the ice dispenser motor. if the lever is pushed too hard, the switch can be knocked out of position. I had to re-position my ice switch with some duct tape.
Feb 16, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Refrigerator stopped dispensing water
Either your water tank in the fridge froze up, the waterline that goes up the freezer door from the bottom hinge froze, or the switch that your glass hits is damaged. Do you hear any humming or noises when you put your glass up to get water?
Oct 27, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
78 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
