Question about Fisher and Paykel IWL12 Top Load Washer
My fisher & paykel was washing then it just stopped what to do
    Sergeant:
  • 291 Answers
So what did it do exactly? If no power check the breaker.
Posted on Jan 06, 2013
JULIANFIX
  • 975 Answers
SOURCE: fisher & paykel (mw511)
check out the DRAIN MOTOR PUMP , its a small motor with 2 hoses connected to it , it could be clogged , need to remove it , inspect inside the impellers for any debri , clean it , re install and try again , hope this helpful AJ
Posted on May 20, 2008
RescueTech
  • 145 Answers
SOURCE: Fisher Paykel washing machine model # GWL15 drips
Hi Dale..
It sounds like you have a leaky inlet valve assembly. The part number is 421029P and is easy to replace. You can get one here:
http://www.fisherpaykelparts.net/ecart/item.php?item_id=266&category_id=56
Posted on Apr 20, 2009
  • 10 Answers
SOURCE: Fisher & Paykel GW612 Top Loading Washing
Hi there
That fault is the pump blocked error (no change in water level).
i have a quick and easy way to solve this problem.
first turn the machine off then tilt the machine back and lean it on something(a chair or wall), look underneath, in the top right hand corner of the plastic outer boul you will see a small pump motor it has a fan on it spin this fan and if it is hard to turn that means there is somthing stuck in the drain pump keep turning the fan and try to free whatever is stuck in the pump, then try the machine on spin again all goin well the object in the pump should come out with the drain water(doing this will not harm the machine) if the object is still stuck you will need to get the water out of the machine (bailing or siphioning will work) and tilt the machine back again and take the wires off the pump and there should be a white tab on the boul holding the pump on pull this tab and twist the pump anticlockwise about a quarter turn(you will need a few towels or a boul or bucket to catch the water) and it should come off exposing the blockage.
Hope this solves your Problem.
Nick
Posted on Aug 03, 2009
hattonhall
  • 349 Answers
SOURCE: fisher & paykel fill up with water then
Yep it sounds like another electronics panel has failed.
We never had this much trouble in the old days with the old electric timer machines.
Posted on Oct 19, 2009
  • 1531 Answers
SOURCE: fisher & paykel smartdrive 508 filling slowly
remove the hoses and check for any kind of clogging or restriction in the line there may also be a problem with your fill valves
Posted on Mar 08, 2010
My Fisher Paykel washing machine won't spin it's goes to rinse then stops. The wash light and the last rinse light comes on also spin light comes on and it's beeping
Fisher & Paykel technician in your area
Contact
Http://www.fisherpaykel.com/au/support/service-appliances#
request-a-service
Customer Care - Online Locator
Feb 18, 2016 | Fisher Washing Machines
It was on the last cycle spin it stopped had pumped the water out but stopped spinning.
Expert Tips, Troubleshooting & FAQs - Fisher & Paykel ...
https://www.fisherpaykel.com/us/support/expert-tips/Fisher & PaykelFind Tips, Troubleshooting Information, How-tos, FAQs and Answers to Commonly Asked Questions about Fisher & Paykel Appliances.
also on Youtube
Aug 17, 2015 | Fisher and Paykel Washing Machines
Fisher & Paykel GW612 won't spin
you want to check the drain pump if there is nothing stuck there sometimes a drain restriction will cause the machine to stop
Jan 27, 2014 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher & Paykel Aquasmart washing machine makes loud banging noise then stops during rinse/spin cycles
Your Aquasmart machine requires 4 new suspension damper rods & 4 top bands, these are a common problem for AquaSmart machines.
Feb 02, 2013 | Fisher and Paykel Washing Machines
My fisher & paykel 7.5 kg excellence smart drive doesn't spin
Check the out of balance switch (under the larger Grey board)
for corrosion on the terminals and replace if faulty.
Jul 03, 2012 | Fisher and Paykel Washing Machines
My fisher & paykel washer will not move to rinse cycle
Fisher & Paykel GW712 AU 93200-A STOPS @ THE RINSE CYCLE & THE SPIN CYCLE?
Oct 12, 2011 | Fisher and Paykel IWL12 Top Load Washer
Our Fisher & Paykel Intuitive Q came up with an Error Code 51, Stopped and an Alarm came on.
Hi, this is an update on what I found out about the E51 error code from Fisher & Paykel. This code is an error with the internal memory as one of the previous poster's said. Fisher & Paykel Rep said though it wont hurt the function of the machine it should still be replaced because it may effect the compliance information.
Nov 15, 2010 | Fisher and Paykel (IWL12)
My fisher paykel washer stopped in the middle of a wash leaving the clothes soaking wet and now the power button does not work
Either the computer board is dead OR the pump was on it's way out & took the board with it.If your lucky the pump is just dead & therefore not providing power up to the board,thats the cheaper way to go first.Or you may be up for both.It was probably pumping out at the time when it stopped.
May 20, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher & paykel smartdrive 508 filling slowly
Mar 08, 2010 | Fisher and Paykel Fisher & Paykel Washer
Fisher & paykel fill up with water then
Oct 19, 2009 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel IWL12 Top Load Washer Logo
21 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
