Question about Sony Handycam DCR-DVD92 DVD Camcorder
How to finalize a dvd - Sony Handycam DCR-DVD92 DVD Camcorder
  • hippiegirly7 Jan 30, 2009
    I burned many dvds and wont play in any other one but the toshiba and i cant figure how to finalize it. please help? Toshibs D-KR10 HDMI
    Problem Solver:
  • 5 Answers
Most units give you the option to 'Erase', "Lock" or "Finalize" the disc at the "TOP" level of Disc Title.
Posted on Jan 25, 2009
Need to know how to finalize recorded disc so that it can be played in regular dvd player
You can record and finalize DVD+Rs one time. After you fill a DVD+R or
complete all the recordings you want on a single DVD+R, finalize it.
Otherwise, the DVD+R will play only on this Recorder.To play the Disc on
other DVD Players, you must finalize it first.
Once you finalize a DVD+R, you cannot record on it anymore or make
editing changes.Therefore, make sure the Disc is as you want it before you
finalize it.
Press SYSTEM MENU. Press
; to select in the top left
corner of the menu bar at the top of the TV screen.
Press CH-
9 repeatedly to select in the second screen,
then press
Press CH-
9 repeatedly to select Finalize disc. Finalize disc
appears in the menu only when an unfinalized DVD+R is in the
Recorder.
Press OK.
"Finalizing" will appear in the menu.The process may
take a few minutes.
When finalization is complete, the Index
picture screen will reappear.
You cannot unfinalize a DVD+R, and you cannot record or
edit the DVD+R after you finalize it.
A DVD+R will play on other DVD Players only after the
Disc is finalized.
Mar 22, 2011 | Philips DVDR75 DVD Recorder
Magnavox DVD/VCR Recorder ZV457MG9 How do I finalize my DVD on this player/recorder?
http://www.ehow.com/how_8623235_do-finalize-magnavox-dvd.html is how to finalize a disk on Magnovoz! I have the ZV457MG9 - its model takes with
1) loading disk
2) select the set up button
3) select DVD edit
4) select finalize DVD
Then you finalize the DVD!!!
Jan 31, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
About finalizing
Once a DVD+R or DVD-R has been finalized, it cannot be edited again. You are stuck with whatever you have. On the other hand, you have to finalize the disc to make it playable on other DVD players.
The exceptions are DVD+RW, which, according to the manual, does not have to be finalized, and DVD-RW, which you can "Undo Finalize" in the "SETUP/Disk Edit" Menu
Aug 16, 2008 | Philips Magnavox MWR10D6 DVD Recorder
Cannot finalize dvd-r
Have solved the finalized problem by simply looking on the Canon website and read that you have to plug the camera into the wall to do it! If only they simply put this in the manual!!! Goodluck!
Mar 01, 2008 | Canon DC95 DVD Camcorder
Samsung R155 Recording from VHS Issues
The reason why you are having this problem is because you haven't finalized the disc. In able for you to play that Burned DVD that you have you need to Finalized the disc. Finalizing a recordable optical disc means writing the disc's lead-in (the Table of Contents or TOC) and lead-out information (blank data that fills up the unused space at the end of the disc) so that a DVD player will know where the various tracks begin and end. Without the TOC, a conventional DVD player will not be able to read the contents of the disc. Once the disc is finalized, no more information can be written to it. Finalizing takes about two or three minutes. To finalize a DVD-RW/DVD-R: 1. Press the Menu button with the disc stopped. 2. Select Disc Manager and press Enter or the right arrow. 3. Select Disc Finalize and press Enter or the right arrow. You will be asked twice if you are sure that you want to finalize the disc. Select Yes and press Enter. Once the disc is finalized, you cannot delete entries from the record list. After being finalized, the DVD-R/DVD-RW (video mode) operates in the same manner as a DVD-Video. Recorded discs must be finalized in order to play back in non-Samsung DVD players. A DVD-RW disc that has been recorded by DAO (disk-at-once mode) in a PC cannot be unfinalized. A DVD-RW disc that has been recorded in Video Mode on a non-Samsung recorder cannot be unfinalized by a Samsung recorder. A DVD-R disc cannot be unfinalized. Note: Finalization does not apply to DVD-RAM. If you cannot finalize a DVD-R or DVD-RW disc, make sure that Disc Protection is turned off. If you are still having difficulty, you may try calling technical support of SAMSUNG. Note: Do not turn the recorder off while it is finalizing the disc. Data on the disc will be damaged if the finalization process is interrupted.
Sep 17, 2007 | Samsung DVD-R155
Finalizing DVD-RW
no you can't finalize the dvd without the camera.you need the competable camera to finalize it
Jun 18, 2006 | Sony Handycam DCR-DVD403 DVD Camcorder
Finalizing vs. not finalizing a DVD-R. DVD-R vs. DVD-RAM?
on standard players. The write all the information that a standard player looks for to read the disk. Nothing is lost if you take the DVD out of the recorder without finalizing it. On a PC, you would tell the software to eject the disk. Later model hardware can usually reopen a disk after it has been finalized. Is this a typo? 'I know that the disc cannot be seen in a DVD player after being finalized'. It should read; I know that the disc can be seen in a DVD player after being finalized
Sep 05, 2005 | Hitachi DZ-GX20A DVD Camcorder
How long does it take to finalize? Can I finalize on other recorders?
The finalizing time depends on the remaining time on the DVD-R disc; Approximately 8 minutes to finalize with 20 minutes recording time on disc Approximately 3 minutes to finalize with 10 minutes recording time on disc Approximately 2 minutes to finalize with no recording time on disc. DVD-R discs recorded on the DVD-Camcorder cannot be finalized on other DVD-R Recorders or PCs.
Finalizing Discs
The only reason that you have to finalize a DVD-R disc is so that you can play it back in an external DVD. Once finalized, you can no longer add motion video to that particular disc. Discs that are not finalized can still be played back when inserted in the DVD-camcorder.
Sony Handycam DCR-DVD92 DVD Camcorder Logo
345 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
