Question about Refrigerators
My voltas fridge compressor burn tout. I purchased new relay dfc1 . There are two terminals L1 and L2.. Let me know the wiring details.
In which terminal I should fix input current line,neuter and earth. In which terminal I should attach compressor wiring line,neuter and earth.
  • 11 Answers
SOURCE: PTC relay on compressor
Try to find the "secret" wiring diagram.  Almost all refrigerators have a hidden paper wiring diagram.  It is usually tucked into a slot under the refrig, behind the front grill, or otherwise on the inside of the lower rear cardboard fan cover, or sometimes inside the back area near the fan.  While you're in there, it's a good practice to clean the coils.
Posted on Oct 23, 2007
SOURCE: Kenmore refrigerator PTC relay for compressor
This is for a Kenmore PTC relay that I just pulled from my fridge. It dosn't have an ice maker. Hope this helps.
Pin 1 = White
Pin 4 = Blue
Gold Pin = Red
Posted on Nov 05, 2008
  • 82 Answers
SOURCE: Replacing a relay switch/kit on a maytag refrigerator MSD2432GR
Wow! I am confused also. It sounds like it is more complicated than the ones I use. Can you send me an image of the relay and the terminals on the compressor?
I can tell you that the live wire ( wire with electricity) is the one that goes on the common terminal, that is the one that it at the top of the trangle formation, unless the formation is upside down then it goes on the bottom. Then the other neutral wire goes on the run terminal which is usually on the right if the triangle formation is right side up. Usually the neutral wire is white. So
try putting the white wire on terminal 3 and the orange on the top (or bottom) terminal. If there are any wires left over that you think need to be connected I would need to see an image.
Posted on Dec 05, 2008
  • 1388 Answers
SOURCE: need help wiring new pressure switch for craftsman air compressor
Assuming that you are wiring for 115v. Lets start with the ground. The cord that attaches to the wall outlet will have three wires, green, black , and white. Insert the cord thru one of the openings of the pressure switch and attach the green wire to the ground screw. Next look very closely at the contacts and notice that they are arrainged in pairs. There is a small brass bar with two contacts that completes the circuit for each line. Start with L1 and attach white wire from cord, then attach white wire from motor to the screw terminal that small brass bar bridges to (should be T1). Next attach black wire from cord to L2 and black wire from motor to remining screw. Remember that the small brass bar with two contacts is the bridge and simply connects white to white and black to black. Enjoy
Posted on Dec 16, 2008
  • 27 Answers
SOURCE: kenmore fridge start relay wiring
there is no need to shroten the lengths of the wires, u can directly connect it
Posted on Mar 10, 2009
I am trying to determine which wires correspond to the correct plugs as they are numbered slightly different. Is their a diagrsm i can follow for this specific switch model # 318369616?
The important thing here is to make SURE the wires from one switch are connected to the same terminals on the new switch...the physical locations might be different but as long as the wires that are at L1, L2, H1, H2, 2p are connected to the SAME terminals on the new switch, you should be good.(use this as JUST AN EXAMPLE BECAUSE I DON'T KNOW THE MODEL RANGE YOU HAVE!)
  • l1 connects to 3-l1
  • l2 connects to 5-l2
  • h1 connects to 1-h1
  • h2 connects to 4-h2
  • p connects to 2-p
  • I need the part number of the old switch *and* the new one to be able to better visualize the connections. Thanks.
Aug 25, 2015 | Kitchen Ranges
I have an old air compressor that I have replaced the motor magstart and pressure switch on the motor is a 220 / 240 volt 5 horsepower motor it also has a low pressure oil cutoff switch does anybody have a...
Control: L1-SS-P-O-OL-OL-M-L2 In series, L1 is line 1, SS is start/stop switch, P is pressure switch, O is oil switch, OL is overload contact, M is magnetic coil (solenoid), L2 is line 2.
The voltage of M must be rated for the control voltage, across the line voltage (240V) or of a control transformer voltage, e.g. 240v/24v. A control voltage would be wired across the line, to L1 and L2.
Power: L1-T1-OL-M1, L2-T2-OL-M2. Line one to Line 1 on contactor, T1 on contactor jumpered to OL (overload heater) and out the overload heater terminal M1 to the motor terminal 1. Same for line 2, Line 2 to L2 on contactor, T2 on contactor jumpered to OL (overload heater) and out the heater overload terminal to M2 motor terminal.
The heater overload relays needs to be chosen by the motor full load current, a chart is given with a motor starter on selecting heater size. If no chart is available, go 115% of the motor FLA (full load amps) to select a heater size. E.G. 25 FLA motor at 115% is 28.75a. Sorry, no schematic available now, draw your own from this info. If using 3 phase, add the third line as duplicating one other line1 or line 2
Mar 10, 2015 | Air Tools & Compressors
How to connect the power to the dryer
most likely 240volts as most 120 volt dryers are already wired,depending on if its a 3 or 4 wire system depending on local electrical codes,but if its a 3 wire cord,take the RED to terminal L1 and Black to L2 terminal on the dryer terminal board HINT:(the RED and Black can go on either L1 or L2 they are interchangable) ,then the White wire to the N neutral terminal on the dryer terminal board usuall between the L1 and L2 terminal,if theres a Green Wire on the cord this is safety ground and can be attached to any metallic part on the dryer,if its a gray flat cord the 2 outside wires are L1 and L2 the center is Neutral,
so its:
RED=L1 or L2
BLACK=L1 or L2
WHITE=N or Neutral
GREEN=Safety Ground the metal dryer frame
Dec 09, 2012 | Dryers
I need to hookup up a Grasslin GM40 timer controlling one load and a 120vac application. Just wondering if someone could verify the hookup terminals as I cannot read the schematic as it is mostly gone. ...
Open following links to identify timer and download manual:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#GM
GM40 can be used for 120V or 240V 277V applications for single-phase and some 3-phase applications.
For 120Volt, set all 4 dip switches to ON position BEFORE applying power.
ON position is pushed to left.
120Volt cable from breaker box has black hot and white neutral wire.
Black hot typically connects to terminal L1
White neutral connects to terminal L2/N
This action will power the time clock and relays.
Other terminals on GM40 are the relay terminals, and these terminals are dry.
Dry means they receive no power when wires are connected to L1 and L2/N.
There are two independent relays and each relay has 3 terminals: NC NO and COM.
If you are controlling one 120volt Load, then use one relay.
Run a jumper wire from terminal L1 to COM terminal.
So COM terminal is connected to Hot.
Cable going to 120V Load has black and white wire.
Connect black Load wire to terminal NO (normally open).
Connect white Load wire to L2/N.
Jul 19, 2011 | Intermatic GM40 - 24 Hour/7-Day Dial...
Fujitsu AST12LSACW - The green timer light is blinking on the indoor unit. The unit is in cooling mode but the compressor dosent come on and only the indoor fan operates. There is power to the outdoor unit...
Compressor contactor relay struck or relay not activated. Remove L1 and L2 wires and jumper with L1 with T1, L2 with T2 and check now. Be careful. It's only checking. When compressor starts, switch off and replace contactor relay.
Jan 27, 2011 | Refrigerators
Wiring new motor
The L1 and L2 are the load terminals. Connect the black wires to the L1 and L2 and the green one to the green colored screw.
May 14, 2010 | AO Smith 1 1/2 HP 115/230V 56C Replacement...
I received no manual for my 60 gal. Porter Cabel air compressor (model #VT627504AJ) and I need to know the spec. for wiring.
being that its 220 on the compressor Is where I assume you are wanting to know where the wires go? There should be a terminal strip or box that has a terminal strip by each terminal there should be L1 L2 and either ground or neutral. The two hot wires one each go to the Line terminals and the ground or neutral to marked terminal.
Jan 09, 2010 | Porter Cable Cable 135 PSI, 60 Gal. Oil -...
Compressor wiring digram for kitchenaid refrigator fsrs25qdwh03
Good day,
You can go here to see the basic wiring setup of your terminals for the compressor along with the relay and overload.
http://www.jimdow.com/jimdow/sales/diagrams/refcopressorterm.jpg
L1 andL2 can be interchanged, since it is alternating current.
Basically, the overload is clipped to the body of the compressor, and is wired to the top center pin (common).
The relay, is pressed onto the R & S terminals. L1 or L2 can be used to connect to the overload terminal. The unused one is connected to the R side of the relay.
In addition, there is a run capacitor that is jumpered between R & S.
Actually it is an accessory to improve the effeciency of the compressor. It would run without it.
Hope this helps..
Thanks for using Fix Ya
Dec 24, 2009 | KitchenAid Superba KSRG25FK Side by Side...
I NEED TO RECONECT WIRES TO CONTACTER RELAY ON
Power leads L1 and L2 to top terminals of contactor.
Compressor leads T1 and T2 to bottom terminals of contactor
Side terminals get the low voltage leads from transformer.
May 18, 2009 | Continental Heating & Cooling
Need help wiring new pressure switch for craftsman air compressor
Dec 16, 2008 | Air Tools & Compressors
Refrigerators Logo
75 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
