Question about Refrigerators
We are unable to get water from water dispenser
  • 700 Answers
Check the water resevour inside of the frig. down towards the botom backside in the refrigerator compartment. sounds like the water lines frozen. take a hair drier and gently thaw out the plastic tubing that comes out od the resevour tank.
Posted on Jan 21, 2009
The ice maker makes ice and dispense water, but won't dispense ice. Cleaned out ice tray, not ice blocking any discharge area. When you try you can hear the ice dispenser door open, but the motor to...
i have the same fridge... same problem, except not only does it not dispense ice, it also dosent dispense the water too. i recently had a power outage, and when the fridge was turned back on the digital warmer and colder setting have been flashing 0 non stop making it unable to set temps... any suggestions?
Aug 22, 2011 | General Electric GSH25JSXSS Stainless...
Unable to get water out of the door dispenser
could be several items.... 1st you want to make sure you have a good filter in the unit if you havent changed in a while could be a problem... 2nd alot of the g.e. models have dual water valves and it could be the water valve solenoid is bad... if you have mechanical capability you can go to rear of unit and disconnect the line going to dispenser and hold a cup at valve and have someone depress the dispenser .... if you are getting water there that eliminates the valve and the actual dispenser switch ...if you are not getting nothing will need to test for 120 volts ac current and make sure the valve is getting power when you hit the dispenser lever. if no power the problem is going to ne the actual dispenser switch ... hope this helps service tech 18 years
Dec 31, 2010 | GE GSS25LGM Side by Side Refrigerator
Clogged Water Dispensor
The water inlet solenoid is the culprit. It lets water into the icemaker and water for the dispenser. Follow the waterline to the back of the frige and it ends at the water inlet solenoid. Note the 2 solenoids built into 1 part. Replace this part and you are done. Don't forget to unplug frige and turn off the water before you replace this part. EZ FIX...
Mar 29, 2010 | Kenmore 21.7 cu. ft. Top Freezer...
Older kenmore fridge. Ice & water dispensing not working.
Yes water valve can go bad. Can you post model # and can get you a manual.
Mar 02, 2010 | Refrigerators
Unable to reduce the temperature in the fridge
Sounds like the thermostat is broken and its freezing the water line. I believe the thermostat needs to be replaced.
Aug 30, 2009 | Refrigerators
Icemaker will not stop dispensing ice
Can you confirm please does it dispense water by itself if you select water? have you tried lifting the ice maker stop lever by hand? At a guess from your fault description I'd say you need a new dispenser micro switch. at worst a new Ice maker unit inside freezer. cheers
Mar 26, 2009 | GE Refrigerators
My Kenmore Refrigerator will not dispense water'
Hi!! you have a bad water valve located in the lower back of the frig..or your water tank located inside your frig is luck..
Jan 20, 2009 | Kenmore Refrigerators
Refrigerators Logo
197 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
