Question about Crosley Audio Players & Recorders
Crosley cr6010a making records sound warped
Record played well, then half hour later, same track sounded warped. now all records sound warped.
  • 1 more comment
  • snoogans_525
    snoogans_525 Jan 07, 2013
    I'm having the exact same issue with the exact same player...ironically today as well. Just got it out of the box
  • snoogans_525
  • snoogans_525
djproaudio
  • 515 Answers
SOURCE: Warped record sound?!?!?!
Go to the following reply to your original post:
http://www.fixya.com/support/t303119-technic_sl_1210m5g_problem
Posted on Feb 24, 2008
  • 17 Answers
SOURCE: Needle slides across the record on Crosley 5 in 1 player
you have unscrewed the suspension screw?
also check the needle for dirt and dust... try blue tacking a 5p coin to the top on the needle to give it a little more weight, if the needle stays in place then the arm balance if off, and unless there is a mechanism to adjust that on this turntable then i guess its a return!
Posted on Feb 12, 2009
mydogisk
  • 50 Answers
SOURCE: crosley cr 78 cd record player plays to fast.
move the needle arm to the extreme right and the turntable will start spinning, this is the problem with the younger generation.....no skills!!!
Posted on Apr 10, 2009
SOURCE: everything works on my record player but my turntable doesnt spin
This happened to me tonight. I had the same problem, to activate the player on you need to move it to the right until you hear a click. If you don't do it it won't start. Even if all the power is on. This should fix everything!
Posted on Oct 12, 2009
  • 4 Answers
SOURCE: Crosley Record Player Stopped Spinning...
I had this same problem with my Crosley 704 and it bamboozled me to no end.
After digging around I dug up the manual online (I bought mine used so I didn't have one to consult). It turns out the record stops when it gets to the end, and to get it spinning again you have to lift up the tone arm and move it right (past the holding latch) until it clicks, and voila, it starts spinning again, ready for a new record.
You'd think that they coulda made it more obvious :(
Posted on Sep 20, 2010
Crosley Cruiser turntable vibration noise
How to Identify Damage in Your Record Player ' eBay
www.ebay.com > ... > Record Players/Home Turntables
They produce audible sound by reproducing sound vibrations from tiny grooves etched on the surface of vinyl records. Record players have three primary ...
Crosley Cruiser Turntable Review - YouTube
? 2:26
https://www.youtube.com/watch?v=w5KVANeimVU
Dec 8, 2013 - Uploaded by DTM
This is a review of the Crosley Cruiser turntable. ... cartridges (the mechanism that converts the vibrations of ...
Just getting into vinyl. Is there any way to improve a Cros
Dec 14, 2015 | Crosley CR8005A-TU Cruiser 3 Speed...
Crosley cr249
are you using a standard microphone jack? like a 1/8" if so this is most likely the problem. also what program are you using. i recommend audacity.
Jun 19, 2008 | Crosley 0187SST Turntable
The turntable on the Crosley I have just brought,spins round unevenly(up and down),is this a problem as it plays some records ok but will not play others.
The platter should be level. If it is not then it could either be warped, by oil, heat affecting in the past. Or just faulty. Even if a warped turntable plays a record OK, it could damage it, as it is so easy for a record to be damaged, it could cause a scratch on the record. It should be checked out.
Feb 23, 2015 | Crosley Cruiser 3-Speed Portable Turntable...
My crosley keepsake turntable has been having a lot of static and the sound is very low, I can only hear it if I turn the volume all the way up. I'm not sure if the needle is the problem or there is s
I would check the wires to the cartridge. It might that one or more is off or loose.
If you turn down the volume completely and listen with a record playing you should be able to hear (with your ear) the stylus in the grooves of the record playing the track. Pick a loud (rock) record for this. If it does that OK the stylus is good.
Dec 26, 2014 | Crosley Keepsake USB Turntable
How to fix warped records?
There is no easy fix for warped records
Dec 28, 2012 | Crosley Director CD Recorder Turntable...
One side of my vinyl record will play fine but the other side won't spin right and the needle gets stuck on the record
The only thing you can do is clean the record with cleaning fluid. You will find special cleaning fluids for records on Amazon. If the record is warped you can try a weight pressing down on the record. But sadly if a record is warped bad there's no real cure.
Dec 28, 2012 | Crosley 0187SST Turntable
Sonar 4 and midi sound cuts offat start of playback
If you are recording from bar 1 at time 1.00 you might want to start recording one or two bars later. So try starting your song on bar three istead of bar 1
Mar 22, 2009 | Cakewalk SONAR 4 Producer Edition for PC
Automatic arm
Wild guess. Sounds like the vertical tracking force is too low and/or the ant-skating is maladjusted.
Jul 02, 2008 | Crosley 0187SST Turntable
87 people viewed this question
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
