I have a dvd-720u dvd player connected to my sony tv and the image is flickering and repeating vertically. audio is fine! what could be wrong? It has worked on this tv before
  • 236 Answers
SOURCE: TV picture flickers
If your DVD player is separate from your tv, you might have a loose cable plug or connection. Depending on the type of flicker you have, a vertical circuit loose connection would cause this. If you could connect it to a cable or antenna it might tell you where the problem is located. A faulty circuit in the DVD might cause this too. Stargazer
Posted on Mar 03, 2007
SOURCE: DVD/VCR combo player won't work
I had a similar problem and corrected it with a solution found on another site. Try hitting the I/P button on the remote which controls whether "Interlaced" or "Progressive Scan" is used to display the image on the TV. Mine worked when "Interlaced" was used. but no picture was displayed when "Progressive Scan" was used. The I/P button toggles between the two settings.
Posted on Jul 19, 2007
SOURCE: No sound from digital cable thru AVR3200 after adding HDTV - DVD plays fine
you need a digital coax cable and then connect it to 6.1 also the digital cable type is not a coomon type so check that also
Posted on Jan 23, 2008
SOURCE: sony str-dg510
Why dvd sound does not play on sony str-dg510?
Posted on Feb 02, 2008
SOURCE: Denon AVR 1705-no audio on TV
I have had the same problem and was told that it is a "board" inside. Essentially it has lost the surround sound ability and can only play things in Direct/Stereo. Mine is just over 2 years and I originally thought my kids had hit a button on the thing causing the issue...ended up paying $100 to trouble shoot it and confirm that it is internal and more expensive to fix than replace. Can't say that I will be buying a Denon again.
Posted on Jul 15, 2008
No Video Error on TV Screen
Select SOURCE on tv to dvd or component or dvi or auxilary etc
Aug 24, 2014 | Sony DVP-SR210P Progressive Scan DVD...
All of a sudden the "welcome screen" goes flickering up and scrolling .over and over like with old televisions.....which you used to be able to fix by adjusting the vertical hold knob. Or...
Check the connections between the DVD player and the TV. If using RCA cables, replace them, as one may be defective. If using S-video, check its connection is secure. It is probably just a bad cable connection or in the case of the standard yellow-white-red RCA, this is probably defective at its sealed plug points - replace this.
If checking/replacing cables does not fix the issue, the DVD player and/or TV may require workshop attention, which could prove costly. I hope it's just something simple, like bad cables/connections.
Apr 19, 2011 | Aspire Digital Televison & Video
I have a 5 year old KLH DVD player. I had it hooked up through AV cable to a 6 year old SONY Trinitron 37" TV & it worked fine. I am now trying to hook it up to a new Westinghouse flat screen TV...
double check the wires are in the correct connections on both the tv and dvd player also the KHL dvd player may need to be put in progressive scan. Usually the red wire for video and the one for audio get plugged into the wrong input and causes this issue
Dec 10, 2010 | Televison & Video
HOW TO SET UP SONY DVD PLAYER WITH HITACHI 42 LCD TV
Connect yellow video output on DVD player to yellow video input on TV using RCA cable. Connect white audio output on DVD player to white audio input on TV next to yellow. Connect red audio output on DVD (next to white) to red audio input on TV using RCA cable. Select on the TV using remote, the proper input for DVD player connection.
Aug 08, 2010 | Sony Televison & Video
RCA drc286 screen flicker
it sounds like the vertical hold on your tv set needs adjusting also with your tv and dvd are there a set of three plugs usually red,white and yellow in colour ?? if so connect these with a cable as this by passes the tv tuner hope this helps regards JIm
Mar 12, 2009 | RCA DRC-285 DVD Player
Recently bought a Sony Bravia 20KDLS4000. Sony DVD player DVD-NS575P was compatible with 3 year old Sony TV but with Bravia, the DVD image is in Black and White. TV gets color fine. Thanks for your...
Try to set your video output settings on your dvd player . I assume you used to connect to your old tv by using svideo and now you are using another connection like component, scart or hdmi.If the video output setttings on your dvd are still on svideo you will have to set it to rgb or component or else you will get black and white images..
Sep 29, 2008 | Televison & Video
Cannot hear audio when connect dvd player to TV using analog audio cable
i think you need to get an Optical Digital Audio Cable and connect it to the tv and speakers then it should work
Jul 08, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
Black Screen with vertical lines down the side?
· http://esupport.sony.com/perl/news-item.pl?news_id=24
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
Jan 03, 2008 | Sony KP-57HW40 57" Rear Projection...
TV picture flickers
Mar 01, 2007 | Sanyo DS31520 31" TV
Televison & Video Logo
127 people viewed this question
Top Televison & Video Experts
