Question about XFX NVIDIA GeForce FX5200 Graphic Card
I want to know of a graphics card that supports vista graphics can play fallout 3. this card needs to be for agp x8 and under $50 can you help???
    President:
  • 2,692 Answers
Minimum requirements
  • Windows XP/Vista
  • 512MB System RAM (XP)/ 2GB System RAM (Vista)
  • 2.4 Ghz Intel Pentium 4 or equivalent processor
  • Direct X 9.0c compliant video card with 256MB RAM (NVIDIA 6600 or better/ATI X850 or better)
Posted on Jan 20, 2009
I just want to know whether SATA 1TB hdd support Asus K8V SE Deluxe Motherboard or not? and also i want to use 512 MB grafix card. can both things support to this motherboard?
Yes as long as there are SATA ports on the motherboard it will work fine.
You will need to find out if your graphics card is pci-e or agp and make sure it matches the motherboard.
May 03, 2011 | ASUS K8V-SE Deluxe Motherboard
HI this is pradeep iam using ASROCK motherboard processer AMD Anthlon(TM)XP2600+ for this motherboard which graphic card can i use my problem is i brought dell 24inch moniter ST2420L but graphic...
Asrock K7VM3 mother board with AMD Athlon 2600+ processor.
The Motherboard is having a AGP slot which says to use AGP with 4X and 1.5 V
Can someone suggest the market products available
when I contact the technical team of Asrock. they responded as below:
The AGP slot on K7VM3 is the standard AGP x8 slot , as long as the VGA card you want to buy is standard AGP VGA card , K7VM3 can support the standard AGP VGA card.
Or , you can double check your question with your VGA card vender before you buy it .
Oct 17, 2010 | Asrock K7VM3 Motherboard
ASUS Radeon 9600XT/TVD stop working need to replace.
An nVidia 7800 is the best agp card made, as agp has been taken over by pci-ex16
but any AGP x8 card will do, if its just for word processing and internet stuff just go with a cheaper one.
found on on ebay for £20 http://cgi.ebay.co.uk/NVIDIA-7800-GS-AGP-Graphics-card_W0QQitemZ380205251305QQcmdZViewItemQQptZUK_Computing_Computer_Components_Graphics_Video_TV_Cards_TW?hash=item5885ffbae9
Feb 15, 2010 | ASUS RADEON 9600 XT/TVD (128 MB) Graphic...
Cheap graphics card
Newegg.com  has APG 8  graphics cards Three are listed upnder $50
Jan 20, 2009 | XFX NVIDIA GeForce FX5200 Graphic Card
Pixel and Shader 3.0 Support
Pixel Shader 3 (PS 3), is just a technique used by video cards to render images to your screen.
In order to get a video card to support PS 3 you need to install DirectX 9c (the 'c' is very important, version 9 is not good enough).
Unfortunately your card only supports DX9 not DX9c and will therefore only play games that support Pixel Shader 2 or below.
Your only option in order to play the games you want, is to upgrade your Video card to one that supports DX9c or higher.
Geforce 6 & 7 series cards all support DX9c.
One other thing, if you are looking to upgrade check and see if your card is AGP or PCIe. I have a feeling that they only made the FX5200 in AGP but check it to make sure.
AGP cards are almost obsolete now, but Nvidia & ATI do still make a few and they can be found on large online PC retail outlets or perhaps try and pick up a good one on Ebay.
Hope this helps
Bri
Jan 18, 2009 | XFX NVIDIA GeForce FX5200 Graphic Card
Max hard disk support
hello. the motherboard supprts this
Max Supported RAM - 3gig
Audio Output - Sound Card • 5.1 Channels • Line Out
Video Interface - AGP 8x
On Board Graphic Processor - Intel Extreme Graphic
Expansion Slots - AGP x8 x 1 • PCI x 3 • CNR x 1
don't forgett to rate. Ty
Jan 09, 2009 | Mercury P4VM800M7 Motherboard
AGP Device Gigabyte GeForce FX 5200
The AGP speed (x4 -- x8 -- x2 etc etc) is probably set to a lower setting in bios and it could be set on a higher speed. it can be also set in windows by a program possibly.
Nov 14, 2008 | Gigabyte GeForce FX5200, (128 MB) AGP...
Is my motherboard compatible with a new graphic card
Being agp3.0, it is backwards compatible so in theory, it should work. With the older system, it may be dangerous. I would find a card that clearly states that it works in x8 (3.0) 1.5v. If it doesn't work it could fry the whole system. If i find a card that works, I'll let you know.
Oct 27, 2008 | XFX GeForce 6800 GT, (256 MB) Graphic Card
ATI RADEON X1650 Pro, AGP Graphic Card 512MB compatibility
Maybe this post is a bit old, but on last deceber I bought an AGP 512MB ATI Radeon X1650 PRO for my Foxconn motherboard and I must say that it's simply awesome!
I can play most games on mid-high settings on reasonable resolutions (most on 1024x768) with good FPS (except with Crysis... but let's face it, did Crytek bought a time machine to warp a 2010 game??).
So, if you already have it, then congratulations, and if you still are thinking on buying it, then what are you waiting for!?
Also, it's AGP x8, if your motherboard support x8, then it should run perfectly fine.
Also, I have a bit of problems trying to run Prey on the X1650...
It always appears an error... it's not of much importance, as I have much better games, but I haven't tried it with high fancy graphics... :P
Oct 13, 2007 | ATI RADEON X1650 Graphic Card
XFX NVIDIA GeForce FX5200 Graphic Card Logo
78 people viewed this question
Top XFX Computers & Internet Experts
David
David
Alun Cox
KG John Justin
KG John Justin
Are you a XFX Computer and Internet Expert? Answer questions, earn points and help others
