Question about SonicWALL TZ 100 [son-01ssc8734] (son01ssc8734) Firewall
Sonicwall tz 100 blinking orange - SonicWALL TZ 100 [son-01ssc8734] (son01ssc8734) Firewall
5 Suggested Answers
  • 42 Answers
SOURCE: i need to add an ip range to my sonicwall tz 170
This is not directly possible to do with a TZ170 as the device will only allow configuration for 1 static or dynamic IP at a time for the WAN port.
However this being the case, I suggest setting the SonicWALL up as a perimeter firewall and place devices that require the other public IPs form the additional IP range behind the TZ170. Basically the SonicWALL becomes the gateway for the other IPs needed as long as the range of the IP block is contiguous.
This would involve using the 4 ports of the LAN on the back of the TZ170 to connect directly to the other devices or if it is more then 4 devices, using a switch connected to the LAN side of the SonicWALL to provide connectivity to the multiple devices behind it. Most TZ170 are licensed for 10 connections on the LAN side and if you require more then 10, additional licenses will need to be purchased.
I would be careful pushing too much traffic through a TZ170 as it is designed for Small Business use and will quickly become overloaded with too much traffic causing high latency/traffic bottlenecks and in extreme cases connections being dropped. This is especially true for multiple VPNs.
Posted on Feb 07, 2010
SOURCE: How to configure Sonicwall TZ 190?
Hi, first u connect the firewall to the Ethernet port using straight through cable. Then set the ip address automatically. Then find the default gateway address from command promt using ipconfig/all command.After that browse the default gateway ip in the browser. you will get the sonicwall login page. Enjoy
Posted on Mar 19, 2010
supernova278
  • 1932 Answers
SOURCE: sonicwall tz 170 password
Password for you sonicawall tz170 is password
Thank You
Posted on Sep 24, 2010
mind397
  • 16 Answers
SOURCE: We have an SBS2011 behind a Sonic TZ-100. A router
So I can understand better... You are trying to move DHCP off of your Small Business Server and on to a router that is connected to your firewalls WAN? I don't understand why you are trying to block the connection between your router and your server. Once you turn off DHCP on your server and remove the static IP on it, it should get a new address from your router.
Best, -Mind
Posted on Aug 04, 2011
We have an SBS2011 behind a Sonic TZ-100. A router with DHCP enabled is connected to WAN of TZ-100. We need to block DHCP in the TZ-100, as the SBS shuts down his DHCP when it finds the DHCP on the router....
Best, -Mind
Aug 04, 2011 | SonicWALL TZ 100 0101SSC8734) Firewall
How to disable team viewer in sonicwall TZ-210?
You can disable Team-Viewer using Sonicwall TZ-210. This is process that you need to understand with some examples. Please visit " http://www.fuzeqna.com/sonicwallkb/consumer/kbdetail.asp?kbid=6038&catID2=110&catID1=143". This will help you.
May 25, 2011 | Sonicwall TZ 210 Appliance
I need to add an ip range to my sonicwall tz 170
Jan 23, 2010 | SonicWALL TZ 170 SP Firewall
I am using Sonicwall Pro 2040. I am trying to connect Sonic Wall gateway but it is asking for pre-shared key instead of user and password please help me. regards pratap
pre-shared key is a must for connectivity. only after inputting this, you would be prompted with user id & password, if configured to.
Sep 02, 2009 | SonicWALL Pro 2040 Firewall
Sonicwall Safe mode Problem
How do I access the SafeMode menu?
In emergency situations, you can access the SafeMode menu by holding in the Reset button on the back
of the TZ 180 (it’s the small pinhole button located to the left of the Console port) for 12-14 seconds until
the ‘Test’ light begins flashing yellow. When the SonicWALL is booted into the SafeMode menu, assign a
workstation a temporary IP address of 192.168.168.200 and attach it to a LAN interface on the TZ 180
Then, using a modern web browser (Microsoft IE6.x, Mozilla 1.4+), access the special SafeMode GUI
using the device’s default IP address of 192.168.168.168. You will be able to boot the device using a
previously saved image, or you can upload a new version of firmware with the ‘Upload New Firmware’
button.
Apr 07, 2009 | SonicWALL TZ 170 Firewall
Not able to see HP C6180 on SonicWall TZ 180
Not sure if you've done this already or not, but I would suggest installing the printer manually as a local printer, and create a TCP/IP port that points at the IP of the Printer. Rudimentary way to go, but should help.
-Backu
Jan 16, 2008 | SonicWALL Total Secure 25 VPN Gateway, WL...
Adding offices to my remote server
The SonicWall TZ 190 is a good appliance for the Tampa location.
The SonicWall TZ 150 is a good appliance for the remaining locations.
For the remote locations, a decision has to be made as to how many sites you want to interconnect to. If you want the network to be such that each site connects to every other site, then you will need the SonicWall TZ 190 as it supports VPNs for up to 15 sites.
In the end, everything comes down to cost. For a Small-to-Midsize Business, this is considered operational cost.
Hope this helps :) Kindly leave a rating. Thanks..
Nov 27, 2007 | SMC TigerSwitch 6508TT
Site to Site VPN Link with dynamic dns
Hi Rajmeet, Here is the documentation on the SOnicwall TZ170 the detail configuration can be found on page 211. Please let me know if this helps you and if youhave any other questions. http://www.sonicwall.com/downloads/SonicWALL_SonicOS_Standard_3.1_Administrators_Guide.pdf
Apr 02, 2007 | Sonicwall TZ 170 NFR (01-ssc-5564)...
SonicWALL TZ 100 [son-01ssc8734] (son01ssc8734) Firewall Logo
106 people viewed this question
Top SonicWALL Computers & Internet Experts
Raymond Ramirez
Raymond Ramirez
Frank Zabroski
Frank Zabroski
Steve P
Steve P
Are you a SonicWALL Computer and Internet Expert? Answer questions, earn points and help others
