Question about SanDisk Sansa e250 MP3 Player
I need to delete songs, but there is no music file!
I am trying to delete the songs, but there is no file called music on my player, nor is it in another folder. I don't understand because I have music on the player but I can't see it. help please!
You have to first change the USB mode on the player to MTP (as opposed to MSC). Forget using the Windows Media Player (yeah, I know). Go to Explorer, go to drive E or whatever your Sansa is listed as....open it and it will show different types of folders. Go to MUSIC folder. The songs are listed and you can delete, e.g. delete mp3 and keep WMA of the same song, or whatever else you want to delete.
Posted on Jun 29, 2007
2 Suggested Answers
SOURCE:
frit
  • 67 Answers
SOURCE: File error
Try a reset and see if it corrects itself. hit menu, settings, scroll to reset all, select yes. This won't delete any files, but it should clear up the song transfer problem. If that doesn't work you may have to reformat the device which will erase all data on it. But then you can start fresh again.
Posted on Jul 31, 2007
How do I delete songs
Just Connect it to your Computer using the USB Provided.
Once your Done with it, Go to My Computer, Select your Music Player there, Go to Music or Sound File Folder, Just Click on the Song You want to Delete and Delete it....
Good Luck!!!!!
Dec 30, 2011 | Audio Players & Recorders
How do I remove a song or songs from my Sansa SanDisk mp3 player model m240?
There are 2 ways to delete music files. You can delete them from the player directly or
using the computer.
To delete music files directly from the Sansa player, follow these steps:
1. In playback mode, press Submenu button.
2. Select the Delete Song item.
To delete music files using the computer, follow these steps:
1. Connect your Sansa to the computer.
2. Select Open device to view files using Windows Explorer on initial connection.
3. Locate the folder where your music files are stored.
4. Highlight and delete the music files or folder.
I hope this helps.
Thanks.
gylacz
Sep 01, 2011 | SanDisk Audio Players & Recorders
Not enough space
Hello. You will need to delete a few tracks from your MP3 player to in order to add more songs.
Simply select the songs you wish to delete, right click, and click "Delete" or "Move to Recycle Bin"
To select more than one song at a time, you can multi-select by selecting one song, holding down Ctrl on your keyboard, and selecting the others until all songs you don't want are selected.
1 Gb is rather small, coming in at about 1024 Megabytes. The average cd quality Mp3 file is around 3.5 to 5 megabytes in size.
1024 / 5 = 204.8
This means you will only be able to fit around 203 high-quality mp3s on your player at one time, and will periodically need to delete and replace them as your music library gets larger.
With these smaller capacity mp3 players, it is often handy to arrange your music library into small folders on your computer so that you can simply clear the player and drop in the contents of one folder. You can even monitor how many files are in each folder to ensure you don't run into this problem often.
I hope this was helpful. -
Frankie
May 11, 2011 | SanDisk Sansa m240 MP3 Player
Files not deleted from m250
Try this solution:
Hook up your mp3 player to your computer
Go to your desktop and double left click on "My Computer"
When it opens you will see listing that says "Devices with Removal Storage" your mp3 player should be listed there.
Right click on your mp3 player, and a window will open, right click on "Open" and now your files/songs should be visible.
Hold the left click down and drag it across all the files/songs that you do not want this will highlight the files/songs you do not want, release, right click and then click on "Delete"
Now you mp3 player should be clear of the files/songs you do not want.
Good Luck,
I hope this helps
Nov 14, 2009 | SanDisk Sansa m250 MP3 Player
Deleting files
You have to plug the mp3 player into the computer, double-click My Computer, double click on the icon of the GoGear, and then go into the Music folder - exercise caution: only delete music files - if you delete files that are non-music files, you will effectively destroy your GoGear.
Windows Media Player is more complex, but it is a safer way to delete songs:
To delete files from your mp3 player using Windows Media Player 11:
My Directions:
1. Connect your mp3 player to the computer
2. Open Windows Media Player
3. Click on the icon of your Mp3 player on the left-hand side of the Library
4. Click on the Songs, Tracks, or other Music Folder
5. Find a song or songs that you want to delete
6. Left-click the song once to highlight it
7. Press the “Delete” button on your computer’s keyboard
-Tha Mp3 Doctor
Dec 09, 2008 | Philips SA5125/37 MP3 Player
My sansa 1gb won't let me delete songs
To delete files directly from the Sansa player, follow these steps:
1. In playback mode, press the Submenu button.
2. Select Delete.
connection.
3. Locate the folder where your files are stored.
NOTE: Music files are stored in the MUSIC folder. Voice recording files
are stored in RECORDING folders. Photos and Videos are stored at PHOTO
and VIDEOS folders, respectively.
4. Highlight and delete the desired files.
Dec 07, 2008 | SanDisk Sansa m240 MP3 Player
Music Player
Find the folder option. if you don't know how to find it. Double click your folder you can the tools. click it and point to folder option and then click view and chose show hidden files and folders. And try to look the files you want to delete. Be sure that the audio songs you want to copy is compatible to you phone.
Jun 01, 2008 | Motorola Mobility ROKR E6 Smartphone
When i connect to the computer, i can add songs, but the songs on it dont show up
I don't know if you've inadvertently deleted the music folder, but that's what I did, when I deleted all the folders by mistake, thank heavens for in-store warrenty, they replaced it with another one. What I noticed on my replacement is synchronizing with media player doesn't work, it creates ghost folders and thinks music is there when it isn't, I don't understand it. Solution: open two windows for my music and sansa e280 music, then just drag and drop the folders; what I noticed is that in my music the folders are named by artist, and I prefer to see them by album, but when I view them in the player, I see the albums with the tracks in the right order.
Aug 17, 2007 | SanDisk Sansa E280 MP3 Player
Help
Hi tater. Hmmm. The product category you selected is for a Standard E260. But if your player is an E250R (Rhapsody player), here's a set of procedures that might help you. Deleting songs from your E250R can be done in 2 ways: By using Windows Media Player 10 or 11, or by browsing the player through Windows Explorer. Before you delete files, though, it's important to know that your player comes in 2 modes: "Rhapsody" and "PlaysForSure". The reason why is that music files saved in one mode would not be seen in the other mode, and vice versa. Therefore, if you can't find the music files in your player, switch to the other mode. Here's how to do it: Use the "Menu" button to navigate the player as follows: Menu > Settings > Mode > This will give you the option of: "Rhapsody" and "PlaysForSure". Here's how to delete your songs: (1) By Using WIndows Media Player: > Plug your Sansa to your computer and open your Windows Media Player. > If your Windows Media Player is version 10, then click on the "Sync" tab and you should see your player ("E250R") on the right pane along with its folders, named "Data" and "Media" or "Music". Expand the "Media" folder and you'll see the "Music" folder containing your songs. Right-click on a song and select "Remove" to delete them. > If your Windows Media Player is version 11, then either click on the "Sync" or "Library" tab and you'll see your player listed on the left pane. The music files will be displayed on the center window. Right-click on a song and select "Delete" to delete the songs. (2) By browsing the player in Windows Explorer Note: the folders containing the music files on your player are "Hidden" and you would need to set your Windows Explorer to show "Hidden Files and Folders". Open your Explorer, select "Tools" on the top menu, select "Folder Options", select the "View" tab and enable the "Show Hidden Files and Folders" radio button. > Plug your Sansa to your computer and open your Windows Explorer > If your player is in "PlaysForSure" mode, then your player will be recognized as a "Portable Media Device". Double left-click on your Sansa E250R and you'll see 2 sub-folders named "Data" and "Media". Open the "Media" folder and you'll find sub-folders normally named after the Artist. Your songs are located on those Artist folders. Delete them by using the keyboard "Delete" key or right-click the file and select "Delete" > If your player is in "Rhapsody" mode, then your player will be recognized as a "Removable Drive" with a drive letter. Double left-click on your Sansa E250R and you'll see the following sub-folders: "Albums", "Music", "Photo", "Pictures", "Playlist", etc. Your songs can be found in the "Music" sub-folder. Delete them by using the keyboard "Delete" key or right-click the file and select "Delete" I hope this procedure helps. A bit lengthy but, hey, it worked for me (lol).
Apr 27, 2007 | SanDisk Sansa e260 MP3 Player
Deleting songs from Sandisk
Hi. The minimum requirements of your Sansa E250 is Windows XP and above and Windows Media Player 10 and above. If you're using Windows Media Player 10 or above, your Sansa E250 and its contents should appear on the right pane when you click on the "Sync" tab. You can right click on a song and select "Remove". The songs will be erased permanently from the player. If your songs do not appear on Windows Media Player 10 or above, it is possible that your songs may have been saved on another mode. Your Sansa E250 comes in 2 modes: MTP and MSC. Songs saved on one mode will not be seen by the other mode, and vice versa. There are 2 ways to delete songs from your Sansa E250: By browsing the folders containing the songs, or by formatting the player. You can switch modes by navigating your E250's menu using the following: Menu >> Settings >> USB Mode Next, plug your player in your PC and open Windows Explorer. You should first set your Explorer to "Show hidden Files and Folders" by going to the "Tools" menu (located on menu lists on Windows Explorer window), then choosing "Folder Options", then enabling the "Show Hidden Files and Folders" radio button Deleting Music files under MTP Mode: 1. Your player should appear as a Sansa E250 icon in Explorer as a "Portable Audio Device". Double left-click this icon to browse the player. 2. You'll find a "PPI NAND" sub-folder. Again, double left-click on this sub-folder. 3. You'll find a series of sub-folders, one of which should be titled "Music". Double left-click this to open it. 4. Your music should appear as individual files or folders. Delete this to remove the file(s) from the player Deleting Music files under MTP Mode: 1. Your player should appear as a Drive letter and entitled either as a "Removable Drive" or as "Sansa E250" 2. Double left-click on this drive letter to browse the player 3. You may find your music files immediately on this folder, or you'll find a series of sub-folders, one of which should be titled "Music". Double left-click this to open it and view your music files. 4. Delete the music files you want, and they should be removed from the player Deleting files through Format: 1. Formatting the player erases all files in the player, and oftentimes this is the best option to ensure that all files are removed and any corruption eliminated. Also, it is best to format the player when in MSC mode. 2. When the appears as a drive letter (under MSC mode), right-click on that drive letter and select "Format". On the "Format" pop-up window, click "Start" to begin the format process. 3. Follow the on-screen prompts and safely remove the player from your PC when the "Format Complete" display appears. 4. Unplug the player from the PC and when the player is powered up, the message "No Files" should appear on the player's LCD screen 5. Switch the mode back to "MTP", or continue to use "MSC". Note: It is best to use "MTP" when you are transferring subscription music to the player. I hope this helps. :)
Apr 22, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
140 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
