Question about Toro Blowers Rake and Vac - Electric Blower/Vac - 51573
Huskee Snowblower has to be constantly at high RPM to throw snow
I can move the throttle from low to high and the RPM speed doesn't change. I have to adjust the bottom screw on the carburator to the point where it sounds like the engine is going to blow up so when i get into the snow it will actually throw snow.
    JERRY ABELL May 11, 2010
    hello mr b, sounds like you have a tecumsen engine,could you let me know if this coorect. sounds like governor is out of adjustment or throttle linkage is stuck. anyway let me know.thank you,MrFixIt. oh need horse power too.model# would be good too.
  • 76 Answers
It sounds like the sping that goes from the throttle lever to the govonor arm is either streched or broken.
Posted on Feb 13, 2009
Huskee snow thrower spout clogs
Before use spray chute/housing with Pam or WD-40
Also push unit faster to move snow through easier.
Feb 24, 2015 | Huskee 21 in. Single-Stage Snow Thrower
Craftsman 27" 305cc snowblower has a hard time throwing wet or heavy snow and also while blowing it will stop moving for abit then move again. Any ideas
I had to replace my carb and while I was in there I increased the govenor speed. The extra rpms throws the snow a little better.
Jan 04, 2015 | Garden
I have a 2009 troy- bilt snowblower 10/24,and when it is under a load it does not rev-up to high to throw the snow, what causes that?
check the linkage to be sure gov is working
its not going to rev up higher ,but it should maintain speed (rpm)
be sure to match your foot speed to amount of snow trying to remove. you can feed it too fast
Oct 09, 2014 | Garden
Snowblower c950 52361 throttle will not change out of idle
Sounds like snow blower has been sitting since last season. Remove carburetor shield and move throttle linkage at top of carburetor. They some times seize or tighten up from sitting.Spray with WD-40 or something to lubricate.
Feb 22, 2014 | Craftsman Snow Blower / Snowblower Bottom...
Snowblower always in gear and wont throw snow and cant move when engine is off
Service kit available for that mess of gears in the motor box(needle bearings inside the gear seize up), there is also a shear or sacrificial adapter mounted to the impeller input shaft Parts and Diagrams for MTD 31AS63EF729 2011 check around part # 7 and 15 top right hand corner. hope this helps. if this didnt help check out this web site
Feb 05, 2014 | Garden
Huskee snowblower help
so you only have idle speed ?
it must start hard
there is a governor but not normal to go out of adjustment
check carb linkage and springs
does your thottle lever move anything when you move it ( as far as throttle plate or any linkage?
Oct 14, 2013 | Tecumseh Snowblower Snow Blower Starter...
Snowblower will not throw snow as far as before.
two things to do. One, get the carb service and have them check the governor.
Two, have the auger belt replaced.
Dec 27, 2012 | Garden
My snowblower does not seem to run at full speed. Barely throws snow recently. Any adjustments I can make?
There is a spring attached to the throttle linkage. At the other end is an arm that the spring attaches to. Bend the arm so that the spring is tighter and it will throttle up higher under a load. Don't go too far or you will take a chance of blowing the engine. Best to use a rpm tester and set it to factory specs.
Feb 22, 2011 | Toro Snow Blower Ccr 1000 Belt 715381...
I have a toro snowblower with a 2 cycle engine. When it's just running under no load it seems fine(maybe a little too high of rpm). When it starts throwing snow it gradually slows down until it quits...
It sounds like it is running lean. Back out your carbuerator adjustment screws a quarter turn counterclockwise. These settings should be 1 and a quarter on low speed (closest to engine block) and 1 and a half on high speed (farthest from engine block). These are starting points the adjustment may vary a little eigther way. Never adjust for max rpms that is too lean and will cause engine failure. Hope this helps ya.
Dec 22, 2010 | Toro Garden
Toro Blowers Rake and Vac - Electric Blower/Vac - 51573 Logo
639 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
