Question about Kitchen Ranges
How do I clean under the top of my simpson neptune stove? cant seem to lift the top!
  • 23 Answers
SOURCE: how to lift rangetop
You should be able to lift it up actually fairly easy by grabbing onto each corner near front and lifting. Then usually a little prop comes out to set so it stays up and you can clean.
Posted on Dec 08, 2007
  • 3 Answers
SOURCE: I want to know how to get the top of my stove to open
It usually just lifts from the top, some times you may need to engage a lock thing, kinda like when you open the hood on your car.
Posted on Apr 08, 2008
IFIXALL
  • 868 Answers
SOURCE: RA 517302W
I need the correct model number.If this is the model number than its not in the system (due to age)
Posted on Jun 09, 2008
  • 969 Answers
SOURCE: How do I lift the top on a smooth cooktop electric
LIFT FRONT, NOT GLASS!
Posted on Nov 12, 2009
  • 3 Answers
SOURCE: dent on stove top pans lean toward dent . how do I
slip a stiff putty knife or screwdriver under the top and pry gently....
Posted on Nov 28, 2009
I have a Simpson Neptune stove 2U602W which needs new simmerstats.
If the connectors are in the same pattern, you can ignore the numbers and go by the position of the connectors, so top left on the old, would go to top left on the new.
You could ask the maker direct.
http://www.simpson.co.nz/SupportCentre
Sep 13, 2015 | Ovens
How do I adjust the flame on a MGC5430 gas cooktop? Flames are too yellow and cause black soot on bottom of pans. Doesn't seem to have an air shutter adjustment
Is this unit set up for natural gas or propane? New stoves usually come with ORIFACES for both gasses. They would install between the on/off knob and the burner tube under the stove top. They may be tapped to the under burner area of your stove. If you lift your top stove cover you may find them. If you don't find them, you may need to purchase the correct applications for your stove. GOOD LUCK FRIEND.
Nov 28, 2014 | Maytag MGC5430 Gas Cooktop
How do i open the top of stove to clean its lrg30855st
Turn off the gas. Lift off the burner cap and the burner head from all remove the torx screws under each of the five burner heads then lift off he top. The picture on these two pages of the manual show where the screws are and what the stove looks like with the top off:
http://www.manualslib.com/manual/705911/Lg-Lrg30855st.html?page=21#manual
http://www.manualslib.com/manual/705911/Lg-Lrg30855st.html?page=22#manual
Oct 05, 2014 | LG LRG30855ST Stainless Steel Gas Range
Simpson Neptune, atlas series electric oven isn't working.
Hi If you have Simpson Neptune 3U 602 then it may be to do with the timer function. This also happened with my oven.
There is a red section on the face of the clock. The oven seems to work if it shows the hand icon. I'm not sure what it symbolises yet, as it's a new oven for me, but it is now working. You can change the icons by turning the left nob left and right. Hope this helps.
Jul 07, 2012 | Ovens
Stove top elements on high only
Yarsu Spiros
I like you purchased one of these thinking you can trust the name simpson(pope) but after putting on a fry pan with sum saucages in and having a major fire in my kitchen, I through the heap of junk out and bought a *** oven (current technologie) howerver to answer your question you have pulled the elements and trays out to kleen them (that seems normal) but you need to make sure the element terminals are clean and so are the spring clip things they fit into, use a peice of emery cloth (not wet & dry) this should fix it
alternativly not buy this junk again and get a proper stove
regards Graeme
Auckland NZ
Jan 02, 2009 | Kitchen Ranges
Want to clean under stovetop
Hello
welcome to Fixya,
This stove has sealed burners and there is no need to lift or clean under anything except the burner caps.
You can not get inside the top and you can not lift the top like the old pilot stoves!
When you clean the burners and around rings do not spray or saturate the are and or the igniter element that creates the spark.I'll be back in a moment with your user manual.
first what is the complete model number of your range as written on the sticker in the door jam of the storage compartment down below. left side!
Huuum
Dec 15, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Lifting the top to clean spills
Hi
Look under the counter top find the bolts that secures the stove top, unplug the power and remove the top, then look around the edges of the stove top and you should see some small screws that atach the glass to the frame, remove those and lift the glass carefuly, "DO YOUR THING" and then just reverse the steps and done.
Eddie Rentas
Tupper Lake NY
Jun 22, 2008 | Cooktops
Kitchen Ranges Logo
161 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
