Question about Garden
Free service manual for 1999 polaris sportsman 335
  • 4 Answers
SOURCE: looking for a free service manual for a 2001
Go to polaris industries.com under tech go to manuals should have 1 there.
Posted on Oct 25, 2009
  • 12650 Answers
SOURCE: I have a 1999 polaris sportsman 335 atv and I am
carb needs work possible float or fuel/air mix valve worn
Posted on Mar 07, 2010
SOURCE: Service manual for a 2006 500 Polaris Sportsman HO
I have a 2006 Sportstman 500HO ATV, EFI. Sometimes it will run 100% correct, other times it will start, idle fine but then when giving it throttle will will start to surge almost like it's hitting a rev limited. Sometimes it will backfire and stall. I already replaced fuel filter, flushed the fuel lines and gave it fresh gas and installed a new spark plug, but no good. I also checked the throttle switch and it's not making contact to stall it. I download the service manaul and tested each sensor and they tested fine which is probablt why I get no check engine light.
This ATV is mainly used to plow snow in my driveway, no salt. It's used around my property but very lightly. It's still as clean as it was when I bought it and it doesn't have but about 40 hours on it.
Polaris 500 HO EFI 4x4 ATV: Vin# 4XAMH50A56B707664 purchased 6-8-2006
gtopercy@comcast.net
Posted on Jul 15, 2010
SOURCE: polaris 2005 sportsman 500 H.O. service manual
Downloaded this last week....its the factory service manual ($3.99)
http://www.tradebit.com/filedetail.php/6901881-download-now-polaris-sportsman-500-2005-05
Posted on Aug 10, 2010
  • 9 Answers
SOURCE: My 1999 Polaris 335 sportsman
you have down all the electrics ( so have spark at plug ) has to be something with the carby does the spark plug have fuel on it when you remove after trying to start if not fuel problems, does bike have T.P.S (throttle positioning sensor) some on carby, some on thumb throttle etc might be causing problems.
Posted on Sep 21, 2010
2013 sportsman 500 gas running out the carburetor bowl from bottom. plastic tube to the ground. is the needle seat stuck?
Hi, Christopher and the usual suspects are:
1. Damaged or restricted fuel tank venting system.
2. Loose float bowl screws.
3. Damaged float bowl o-ring.
4. improper fuel level in the float bowl.
5. Worn or dirty inlet valve or seat.
6. Damaged or leaking float assembly.
7. Particle contamination in inlet fitting cavity.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
2012 500 ho leaking gas from carb overflow tube
Polaris fuel leak repair
Polaris 2007 Sportsman 500 EF Service Manual
2013 Polaris SPORTSMAN 500 HO A13MH50AJ AQ AX AZ OEM Parts
Polaris Sportsman 500 HO Owner Manual
Jan 15, 2017 | GAS Motorcycles
1999 Sportsman 335 4x4. Why doesn't it seem "right"?
Make sure it is the recommended size. Can you adjust the tension? Try some belt dressing, it's a spray that makes belts grab better. Good luck!
Feb 29, 2016 | Polaris ATV
Just bought this bike had no manuals with it I need to know about checking and changing oil
PDF]Sportsman 400 H.O. Sportsman 500 H.O. - Polaris
cdn.polarisindustries.com/polaris/.../parts-manuals/9923420r01_lo_res.p...
... parts and acces- sories, available through our online store at www.purepolaris.com. Have ... 2012 SPORTSMAN 400/500 HO Owner's Manual. P/N 9923420 ...
Polaris Sportsman 500 HO Owner's Manual - ManualsLib
www.manualslib.com > ... > Offroad Vehicle > Sportsman 500 H.O.
View and Download Polaris Sportsman 500 HO owner's manual online. PolarisIndustries All-Terrain Vehicles Owner's Manual. Sportsman 500 HO Offroad ...
2011 Sportsman 400/500 Service Manual - Polaris ATV Forum
www.polarisatvforums.com > ... > ATV Repair and Maintenance
Apr 11, 2011 - Indy Red 2011 Sportsman 500 H.O. -Polaris rear rack extender -Ricochet a-arm guards -Polaris fender bag -Koplin hand guards w/mirrors Owners, Service, and Parts Manuals
Sep 14, 2012
2005 Polaris 500 H.O. ATP service manual
Aug 12, 2011
Service manuals
Nov 29, 2010
Service Manual
Sep 23, 2010
More results from www.polarisatvforums.com
Dec 21, 2015 | Polaris 2011 Sportsman 500 H.O
I have a 1999 polaris sportsman 335 and when i go more than quarter throttle it spits and sputters. anyone know whats going on?
notorious for plugs, always have 2 sets of new plugs with u when u go out , check on availability of hotter plug upgrade.
Jan 07, 2013 | Polaris ATV
My 1999 Polaris 335 sportsman automatic 4x4 won't fire and I have replaced....starter, battery, coil, stator, plug,cdi unit, and replaced all the fluids, and sanded the magneto. What is wrong?
Sep 20, 2010 | Polaris ATV
I have a 1999 335 sportsman with no spark. It ran fine then just died. It wont pull start or crank over???
I had the same problem with my sportsman 500, I replaced the cdi box and still wouldn't start then I replaced the stator, and still didn't start, then I checked my pulse coil air gap and it worked perfect after that. 0.016 to 0.040 inch sometimes the metal clip that holds the pulse coil gets slight off I guess from viberation. Mine was still tight I had took a flathead screwdriver and slightly bent the pulse coil to the proper guage. Hope this helps
Mar 17, 2010 | Polaris ATV
I have a 1999 polaris sportsman 335 atv and I am getting gas in the air filter
Mar 07, 2010 | Polaris ATV
Looking for a free service manual for a 2001 polaris sportsman 90 were can i get one ?
Oct 24, 2009 | Polaris ATV
Garden Logo
934 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
