Question about Maytag Dryers
Model mgdx700xl1
Changing door swing with doors with glass
4 Suggested Answers
SOURCE: zanussi ZDC67550 Dryer, door swing change?
Hi
just reversed the doors in 15-20 mins. It worked for me. You do need to be a competent DIYer to do this.
If in doubt, do now't. Get in an engineer
Disconnect from mains (obviously)
Remove top using 7mm nut driver/spanner
Remove 2 cross-head screws holding the door - Door will come away from dryer.
Remove 2 cross-head screws holding the white top and bottom blanking plates
pull out the switch blanking plate
Locate the PINK wires connecting the switch/latch mechanism inside the dryer at the top. This will be taped to a blue wire.
Unscrew the 2 smaller cross-head screws holding the latch/switch assembly whilst holding the pink wire to stop the mechanism dropping inside the dryer.
Pull up the latch mechanism and unravel the black tape holding it to the blue wire.
Drop the latch assembly down the lefthand side of the dryer and refit using the 2 small cross-head screws.
Retape to the blue wier and feed the PINK wires through the plastic retainers.
Fit the white blanking plates to the RIGHT handside of the door opening.
Swap the hinges and the switch latch on the door (don't lose the spring !!!, refitting the hinge blanking plates(ease these out with a small flathead screwdriver covered witha bit of insulating tape to avoid damage.)
Fit the door using the 2 cross-head screws you have left
Refit the top.
Connect to the mains and switch on to the sound of £80 you have just saved yourself !!
Electricity kills Be careful
Posted on Aug 25, 2008
erpaalai
  • 999 Answers
SOURCE: Purchased a damaged GE dryer. Model and Serial number removed.
Model tag is inside door frame or at the bottom corner on the side. It may have been removed or not replaced if the front panel was replaced, Eric
Posted on Jul 07, 2009
chadtonline
  • 93 Answers
SOURCE: can I change the door swing? How???
I read through the product specifications and didn't see any reference to switching the door around. I have a lot of appliance repair experience and have never seen a drier with this option, only refrigerators.
Posted on Apr 07, 2011
How to clean between glass oven doors on whirlpool oven?
You need to remove the inner door panel, Usually a few screws holding it on. On some models the handle screws also need to be removed. Do it slowly and carefully as the door may want to swing up quickly, once the weight on it is removed. Pay close attention to each step so all screws etc go back in the same place. Make a diagram as you take them out to be sure.
Aug 10, 2014 | Whirlpool RBD305PD Electric Double Oven
How to change door swing?
Hello Rich, I am happy to assist you!
I see that your question is listed under front load washer, ATF6000F. If this is your correct model number, the doors on this particular model is not designed with reversible doors. Please reconnect if you have a different front load washer. I hope this information helps to some degree.
Feb 19, 2014 | Frigidaire Affinity ATF6000F Front Load...
Ford Explorer back hatch door/window latches broken
What year? Was the recall done on the glass supports?
Jan 13, 2014 | Ford Explorer Cars & Trucks
Swinging glass door
are there screws or adjustments points on the hinge?
Oct 17, 2013 | Home
Can i replace the glass doors on my cooler to the solid doors?
If they are swinging doors yes but if they are sliding doors probubally not, but you could get doors and brackets made up if you really wanted to I wouldn't recommend it
Sep 06, 2012 | True TBB-2G Commercial Refrigerator
How to change doors from right to left on Whirlpool Duet
Duet dryer doors cannot be reversed for the swing. They wil only open one way. Depending on your model of washer the newers ones will allow you to reverse the door swing without a kit. The older units require a kit to reverse the washer door.
Apr 22, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
The inside shower door is uneven, making it come of the hinge after moving it more than 4-6 inches.The metal attachment holding the glass is lower than the other ones.How do I get it even so it slides...
The top rollers should have adjustments on them to bring the door to horizontal as it swings accross the track.
Start with door in the middle and adsust by seinging it to both sides.
Dec 02, 2010 | Basco Deluxe Sliding Glass Shower Door /...
I want to change the door around to match the
Unfortunately, only some model Dryer doors are able to be changed, not the washer doors. You can find out the Model of your dryer and I can let you know if indeed you dryer door swing can be changed or not. The other solution is to stack the set to not have the doors impede loading and unloading if your models have a stacking kit available for them. I hope this helps! Good luck!
Dec 29, 2009 | Frigidaire GLTR1670A Front Load Washer
Can you change the door direction on a Maytag
Unfortunately, you can only change front loading dryer door directions on some models. Washing machines do not allow this. If the units are stacked i may be easier to switch loads, otherwise the dryer door may be able to have the door swing direction changed but without the Dryer model # I couldn't say for sure.
Dec 29, 2009 | Maytag EPIC MFW9700S Front Load Washer
Dryers Logo
24 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
