Question about Kenmore 24 in. 15652 Built-in Dishwasher
Drying Agent reservoir problem
Whenever I try to fill the drying agent reservoir with Jet Dri it just sits in the little hole and does not flow into the reservoir. Is there some trick to getting it to flow? Thanks
    Sergeant:
    Champion:
  • 338 Answers
If the resevior is full then it should go right in.. if you try filling it every day it wont take anymore.. the rinse aid should only be filled maybe once a mmonth or once every other month
Posted on Jan 20, 2009
Paint will not dry extremely sticky after days of drying time
Synthetic coach finish will usually be touch dry in about six hours in normal humidity and mild ambient temperatures. During mixing the colour the paintshop should add a drying agent, without which the paint will remain tacky forever.
A friend in the trade was bemoaning how he had just had several gallons of mixed colour returned because somebody, perhaps himself, had forgotten the drying agent.
The only other paint in my experience that is reluctant to dry is the various types of 2-pack which should have one of various types of activator added.
I know there are many types of paint on the market for various purposes and many are only suitable for curing in an oven. Whenever buying paint ensure a manufacturer's data sheet is also supplied as that will be found to be most valuable.
Sep 25, 2015 | Air Tools & Compressors
After the dishwasher has finished its cycle and the unit has sit for 24 hours, should there be water all over the sides of the inside stainless steal? It seems as if it is not drying. We just purchased...
I have looked at the users manual for this machine and it is not equipped with a drying cycle, so you need you used a Rinse Agent, like Jet Dry to get the result you desire.
Joe
Sep 20, 2011 | LG LDF6810ST Stainless Steel Built-in...
Do i need additional rincing agent if i use tablets or gel that already contain the agent for the drying process to work?
i would eliminate the gel tablets all together. the machine is designed to have jet dry in the compartment.
Mar 06, 2010 | Dishwashers
I recently bought a different type of dishwashing detergent for my Frigidare dishwasher and my dishes look as if they have not been rinsed. They cycled all the way through the drying cycle so the detergent...
the best way to use your dishwasher is the way it was designed.
if your unit has a compartment for jet dry or rinse agent then you should add and fill that compartment with rinse aid. try not to buy soap with any extra like soap with jet dry or shine plus . because when you fdo that sometimes customer think that they dont need rinse agent . big mistake. rinse agent is deposited at a certain time in the cycle. diod you know that is you use lets say jet dry and a soap with shine plus or rinse aid in soap the machine can over suds? as a tech trust me i have seen it.let me know if i was helpful. drop a 4thumbs up post
Feb 28, 2010 | Dishwashers
Whirlpool dishwasher is not fully drying dishes
Are you using jet dry or a similar drying agent? If not you should be. Also check to make sure the heater is getting hot in the dry cycle, just place your hand over the heating element to see if it's generating heat, don't touch it as it will burn you.
Feb 19, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Where do I add my rinse agent???
I have the same dishwasher, KUDS01FLSS. All you need to do is pour the rinse agent (We use Jet Dry) directly into that circle like plug with the line through it that you mentioned above. It acts like a funnel.
Pour the rinse agent in slowly as it takes time to drain into the dispenser. Just watch the little sight glass to the right of the rinse agent fill funnel. It will begin to darken (or turn blue if you use Jet Dry) as the dispenser starts to get full. I just pour it in slowly and when the rinse agent does not flow down the funnel any longer, it is full. Be sure to wipe up any spills or excess rinse agent. Hope this helps you.
Good Luck,
Tom
Jan 08, 2009 | KitchenAid 24 in. KUDS01FLSS Built-In...
There is a whitish film left on dishes/glasses/silverware after wash cycle is finished.
Are you using Jet Dri or another type of rinse agent? If not, that will become your main issue. These machines HAVE to have it, or they wont remove that film. Also, have you changed washing agent (soap) etc. You may be using a little to much. Other issues that can cause this are: bad drain or main pump unit, clogged drain hose, etc. Let me know if you need any other help or information.
Nov 15, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Not Drying
I found that if the rinse agent (Jet Blue) has run out the dishes stay wet.
Aug 21, 2008 | Bosch SHU3305 Dishwasher
Dishes not dry at end of cycle
check to see if your jet dry dispenser is empty and on some of them you can turn them up higher its important to use a rinse agent back when everyone was trying to cut down on energy use the only way to to it was to cut back on drying time so they came up with jet dry which creates a sheeting action and causes most of the water to run off before the drying cycle
Jul 14, 2008 | Miele 24 in. G892SCU Plus Built-in...
Kenmore 24 in. 15652 Built-in Dishwasher Logo
121 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
