Question about Creative Labs Zen Micro MP3 Player
Headphone jack problem
I have an RCA H100 and it turns on and everything but when i plug in the headphones in i cant hear anything will somebody PLEASE help me?
  • 247 Answers
Starting point needs to be to find out whether the problem is with your headphones, or with the player. See if you can borrow someone else's player for five minutes, swap the headphones over, then see which one works. If the problem moves to the borrowed player, buy yourself a new set of headphones (although it's usually possible to repair them, the quality of repair is rarely worth the effort). If the fault stays with your player, first check all your settings to make sure you haven't "told" the machine to make no noise. Once convinced it's actually broken, you have the choice of taking it to get it fixed, or opening it up to see if you can see anything obviously wrong. Realistically, any inspection you can do once in is likely to be confined to checking the headphone socket and its connection to the board for damage. If you do decide to open the thing up, make sure all your music is backed up somewhere else first. A.
Posted on Jun 28, 2007
Sennheiser RS 120 headphones won't work, only hear static
Adjust the tuning wheel on the side of the headphones so it picks it up.
Mar 20, 2014 | Sennheiser RS 120 Consumer Headphones
Sylvania wireless headphones
Set up the transmitter. Wireless headphones rely on a transmitter that sends audio via infrared or radio waves to your headset. Use the digital audio output (coaxial or optical), RCA outputs (red and white) or headphone jack on your TV to connect the transmitter. The connection will depend upon which outputs are available on your TV and/or the transmitter.
Use an RCA-to-headphone adapter. If you don't have a headphone jack on your TV and the transmitter includes only a headphone connection, connect an RCA-to-female headphone connector. This will allow you to plug the wireless transmitter into the female headphone end and then hook the RCA ends into your television's audio outputs. You may also need a 3.5 mm (mini jack)-to-1/4-inch adapter if the headphone plug on the transmitter doesn't match the television jack.
Read more :
Set the transmitter on top of, or next to, the television. For infrared transmitters, you'll need a direct path between the headphones and the transmitter. Placing the transmitter on or near the TV will allow you to take advantage of the clear path you already have.
Plug in the transmitter and turn it on. Charge the headphones if necessary.
Turn on the headphones. Adjust the volume and settings and you're ready to watch TV.
Read more :
good luck
Nov 14, 2013 | Sylvania SYL-WH930GB Wireless Headphones
Can I watch a DVD and use the WH-930 headphones to hear it better?
Most DVD's have line-level outputs which will NOT drive headphones. You need to run the audio line outputs, which are usually RCA jacks to jacks on an amplifier and then plug the headphomes into that. An inexpensive source for an amplifier is OFTEN at thrift shops. Run the pair of cables into jacks that would likely be labeled TAPE INPUT for example. FInd one that does have a headphone output jack on the front.
Oct 23, 2011 | Sylvania SYL-WH930GB Wireless Headphones
I am attempting to use my sennheiser rs 110 headphones with my lcd-led tv. the componet jacks coming out of the transmitter are red and black. All my componets on the tv are red and white. so when i plug...
What are you plugging your 2 RCA connectors (from the headphones) into on the television?
You are correct, usually:
White = Left Red = Right
In this case
Black = Left Red = Right
Not sure....guess some manufacturers need to be different...
Back to the issue,
You to need to connect the Black to White and Red to Red to the TV BUT you need to make sure you are connecting to an OUTPUT and not to an INPUT on the TV. Most newer TV's do have an "audio out RCA jacks" on the TV but not all. It should be labeled at the connector if it is an output, or just another input. You can always consult the TV manual to be sure.
Few things you can do to test
  • Does your TV have a "headphone jack", use the adapter (2 RCA female - 3.5mm connector) to plug into the headphone jack and see if there is sound
  • Connect the Black and Red RCAs from the headphones directly to the another output, like a DVD player, CD Player etc....
I hope this helps,
Mar 10, 2011 | Sennheiser RS 110 Consumer Headphones
How to find JVC AV27320 headphone jack? I've plugged into the avs(red & white) in the front panel as well as the extra ones in the back. Altho - I CAN hear the sound thru the headphones, The external...
This model doesn't have a headphone jack. The only JVC TV in the series that does is the model AV-20D202. For the JVC AV-2732, use the RCA audio out jacks with an RCA to 3.5 mm adapter to connect to the headphones. The front audio jacks are audio in (for the audio from a video camera for example).
When you use any external speakers or headphones through the audio out jacks, make sure to turn off the TV speakers. Press Menu and navigate down to TV Speakers (up/down arrows). Then use the right/left arrows to select Off and then Exit the menu. Make sure you scroll the TV volume before doing this. Note: if your headphones do not have a volume control they are a bad choice for this type of audio output.
You can find the manual for the TV here: .
I wish that I had better news for you.
Jan 06, 2011 | JVC AV-27320 27" TV
If I hook up a set of headphones to the slot on the side of the TV the sound goes off and you can only hear sound through the headphones, no one else in the room can hear the TV. Is there a way to hook...
The headphone jack on the TV has switch built-in to kill the TV speakers when headphne jack is used, you need to use powered PC speakers with headphone jack and connect this PC speakers to the Audio line out of the TV set (RED and WHITE RCA audio line out). Basically the powered PC speakers are being used a headphone driver. Or you can get one of those wirless headphone system instead.
Jun 27, 2010 | Televison & Video
We have a Sanyo DP19649 and headphones dont work
Turn speakers off in sound menu if available. Then turn up volume to hear in headphones.
May 06, 2010 | Sanyo DP19648 19 in. LCD TV
Marshall MG50 DFX amp line out/headphones not working
Contrary to what's posted above, the Marshall MG series does not pass the speaker power output through the headphone jack, and inserting the headphones into the jack does not disable the speaker. The headphone amp is a separate circuit and it's input is taken before the master volume. So Jan's post is exactly right. Turn off the master volume and turn up all the other gain/volumes as high as they will go. The other issue is that the headphone jack's output does not drive low efficiency headphones well, so you need some headphones similar to Sony's MDR-V700s to hear it well. Earbuds just don't cut it.
Mar 07, 2010 | Marshall Mg50dfx 50-Watt Combo Guitar...
Everything works in my turtle beach x1 but people cant hear me speaking
Have you tried using your X1 on your PC? Plug the green plug to the green jack, pink plug to pink jack, USB plug to USB port. Speak into the mic and you should hear yourself in the headset. If you can hear yourself, then the problem is the chat-controller cable and you should get that replaced. If not, it may mean your X1 mic is broken and you should contact Turtle Beach about that ---
Oct 24, 2009 | Voyetra Turtle Beach Turtle Beach Ear...
Creative Labs Zen Micro MP3 Player Logo
71 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
