Question about Harman Kardon Harman/Kardon AVR 1700
My Cox HD/DVR controller will turn off but will not turn on my new HKAVR1700 using the AUX button on the Cox supplied URC-8820-Cisco remote.
I've used all six Cox supplied code numbers. I need to continue use of the Cox remote to still have control and access to my DVR in the Cable Box. Any suggestions? Could the 1700 I just purchased be defective? The 1700 turns on and off fine with the HK remote?
  • 3 Answers
This is a documented problem with the Harmon/Kardon AVR-1700 and the Cox remote. Here's how I solved it. On the HK1700, go to System Settings and turn on HDMI Link. This will allow your TV (if it has the feature) to put the HK in standby mode when you power down the TV. Go to your setting on your TV and turn on HDMI link, or equivalent. I have a Sony TV and the setting is called "Control For HDMI." Then, use code 0110 for your Cox remote. This code will only turn on the HK, not turn it off. BUT, the HDMI Link should put the HK into standby.
Posted on Jan 09, 2013
sapperj
  • 70 Answers
SOURCE: Center Speaker sound just not right
If the optical cable was bad, the sound would be distorted period. The optical cable (whether coax or fiber) just simply carries the coded audio to the receiver which in turn decodes it. I have never heard of a signal just screwing up the center channel, and I've been at this better than 30 years. Not to say it's impossible, but very unlikely.
Did you try swapping speakers? Move the left one to the center and the center to the left. Does the center remain "distorted"? Does the left become "distorted"? If the center remains distorted, the receiver's center channel has something wrong with it. If the left is distorted, the speaker has a problem.
For the future. it is un-neceaasy to purchase expensive cables. In fact it could make things worse. The claim to fame of most expensive cable manufacturers is the gold plating on the connectors. Unless the bioth sides have gold plating (receiver, cable box) this actually creates a capacitive reactance between the different metal types. FYI-capacitive and inductive capacitances are the basis for designeing cross-overs, filters, etc. So basically, an undesired filtering effect is created. This applies to speaker cables, audio, video, etc....
Jeff
Posted on Feb 17, 2008
dunnbiker
  • 8546 Answers
SOURCE: my harmon kardon hk 3475 has very poor sound,
Poor sound or low volume?
Sudden onset or always like this?
When you say this, "if i hook up through the line input it sounds ok ", what exactly do you mean? What alternatives are you using to Line Level inputs. All inputs except Phono are Line Level.
How does FM sound?
How is the MP3 player different than anything else, hook-up-wise? Do you have it jacked into the Main In? That would bypass all signal processing and selection in the receiver.
There should be jumpers between Pre Out and Main In. Are they there when you DON'T have the MP3 player plugged in there? If not, install a short pair of RCA cables between them.
Describe what is hooked to what in detail. Have you checked to make sure the Mute and Tape Monitor (T-Mon) are NOT active?
A manual is available for free download if you register with retrevo.com .
Posted on Feb 24, 2010
  • 308 Answers
SOURCE: my HK 3380 doesn`t turn on...
If the display does not turn on, then you have a power problem. The unit is not completely turning on. Since you opened up the unit, give it a sniff test to see if there is any burnt odor inside the unit. Check the fuses also. Have a look at the transformer board. It may have several fusible resistors sitting high on the board. If they burn open, there is no power to the display/cpu board.
Posted on Mar 22, 2010
walesarumi
  • 6993 Answers
SOURCE: I have a avr 520
I'm sorry to say this, but unfortunately, there is no other code that will work with the remote. If it was going to work, it would have worked with the code that came with the remote. Since the code that came with the remote does not work with it, then I don't think there is any other code that will work for the unit.
Take care.
Posted on Dec 02, 2010
dunnbiker
  • 8546 Answers
SOURCE: I have an HK AVR
Obviously you removed (or disturbed) something that was really necessary to the DVD's digital audio path. "Doesn't work" is pretty non-specific.
Do a web search for "HK AVR 355 manual" and download it. Then read the part about assigning digital audio sources and speaker configuration setup.
Look at the Troubleshooting Guide part that mentions the Channel Indicator Display (page 33).
Posted on Aug 17, 2011
Have jvc tv, lost remote, have cox remote turns tv on but doesn't change channels don't have cable just tv antenna
Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window" to get gathered related posts.
Sep 25, 2016 | Charter Cable Cox Cable URC-8820-CISCO...
Does anyone have a remote code for a Sharp HT-SB602 sound bar to work with the cisco remote URC-8820
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://electro-medical.blogspot.com/
Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls.
Jan 17, 2016 | Charter Cable Cox Cable URC-8820-CISCO...
Charter remotehow do i program a charter remote to control directv?
Nov 08, 2015 | Charter Cable Cox Cable URC-8820-CISCO...
My pause button does not work on live tv. It will pause on DVR shows.
I have seen freeze frame but I do not have a clue as how to stop a live tv show, that is saying everything stops on the show until you release it. Some TVs can buffer the show but then it is no longer live. That is what the DVR is for.
Dec 05, 2014 | Televison & Video
How do I sync my remote to my tv
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts. Search the sites by type in the brand name to your device, in its search box. It will help you to find the document easily.
Sep 30, 2014 | Charter Cable Cox Cable URC-8820-CISCO...
How to reset up my tv with my remote?
To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Sep 01, 2014 | Charter Cable Cox Cable URC-8820-CISCO...
How to take apart remote
Don waste you time taking it apart. I work for them for several years and all you need to do is take it to the store and say it's faulty and they will replace it for free.
Jul 22, 2014 | Charter Cable Cox Cable URC-8820-CISCO...
Pioneer dvd player codes
0379.0381,0393. Try these codes. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" or "Magazine" view. It will make surf easier.
Try this link too
May 06, 2014 | Charter Cable Cox Cable URC-8820-CISCO...
Top and bottom of the screen are cut off
That set has an aspect ratio of 4:3. The problem is that what you are sending to it is 16:9 So you are sending an hd signal to a non HD television. The tuner is NTSC which is not HD. Theres not much that you can do about this.
Jan 17, 2014 | RCA F27650 27" TV
Harman Kardon Harman/Kardon AVR 1700 Logo
314 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Electro Med Services...
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
