In china, Bosch WAS20460TI washing machine. Door won't open, handle feels loose like it is disconnected. This is in "open" mode after the unlocking "click".
5 Suggested Answers
  • 566 Answers
SOURCE: door handle of washing machine broken
if clothes are still in washer? and machine has finished cycles? then handle broke so unable to open ??? your best option is to unplug/ and if necessary disconnect water supply hoses then remove the top screws from rear panel which also secure the top panel as you will observe ? then pull backwards top panel and loft off ? you now have access/visual of the door catch inside front machine look?? at the catch and you will see how it locks ? you can lever the catch gently and door opens to fit a new door catch is easy diy and not expensive if you are confident usual problem these break ? is the time delay micro switch sticks with age /moisture try dw40 and work plunger b4 you refit door back after replacing handle/catch assy
Posted on Feb 16, 2009
SOURCE: The door on my indesit
slide in a piece of string around the door. if lock is on the right, pull round the door til the pieces of string are at left of the door and pull left quite firmly.
Posted on Mar 10, 2009
  • 1382 Answers
SOURCE: door wont open on bosch classixx 6 1400 express washing machine
The "F16" on a Bosch indicates the door is open / unlocked. If it's happening during a wash it would suggest either a faulty door lock, faulty wiring or worse, a faulty main control board. The wash program should halt when this comes up but you should be able to restart it when the door is closed. As the cost of a new door interlock isn't overly expensive. The best way to fix this problem is to purchase a new lock and fit it.
Thank you !
Posted on May 19, 2010
SOURCE: LG Tromm Front door won't unlock
I have this exact problem!!! Did anyone ever figure it out??!! HELP!!
Posted on Jul 19, 2010
My Bosch AvantiXX front load washing machine has finished the wash and now it has locked on me and I can't open it. How can I open the door?
hi Suzanne.
i have had a look around the internet and found that there is lots of ways to try and open it.plus there is people on youtube showing how to open a door.
so if you go to this link and pick the one you think would be the best one for you to try.
Bosch AvantiXX front load washing machine door wont open Google Search .
or this one.
How to open washing machine door that won open normally
Nov 20, 2017 | Bosch Washing Machines
Bosch exxcel 7 have E43 code flashing I can open the door ok and washing Is wet any clues?
drum motor does - REMANENT ERROR - speed sensor is broken - Reset error with activating Normal mode not rotate - washing program is aborted - drum is blocked by laundry test mode Pos.3 Motor - door is unlocked, if possible - motor is blocked - check control - operator control actions are blocked - control is broken - the current indication is frozen ? Triac is broken
Feb 13, 2016 | Bosch Washing Machines
Bosch error E23 flashing
disconnect the power the door unlock within 30 secound
Oct 12, 2014 | Bosch Washing Machines
F16 error code on washing machine
May 06, 2012 | Bosch Washing Machines
I have a front loading Bosch washing machine and it was working fine on Friday. On Saturday morning I went to take a load of clothes out and the door won't open - I am getting an E13 signal. My...
Hi!
The door lock uses electrical power to keep the door closed. Unplug the machine from electrical power and the lock will be released in a couple of minutes. Please be sure not to flood the room if the water level inside is above the door level.
Regarding the E13 error itself, it means too long draining time, and it can be caused commonly by something stuck in the drain filter. To get to this filter and clean it, you have to look at the lower part of the machine and remove the circular panel, then insert a little screwdriver into the hole and twist , the acces pannel will get open. Now twist the handle of the filter and pull it out. Now it can be cleaned. CAUTION: opening the filter will cause all water inside the machine to get out, so have some towels handy to avoid water to spread all over the floor.
Hope it helped,
Bogdan
Aug 28, 2011 | Bosch Washing Machines
Bosch Nexxt 300 has error code E-13 and the door is locked. turned on/off, unplugged, removed the drain hose to see if it is blocked, but ok. but still won't unlock. Is there someway to unlock the...
Turn the dial to off position wait few second, door should unlock. Unless you try to open it during cycle, it won't open. Otherwise, follow owner manual. call the manufacture.
May 18, 2011 | Bosch Washing Machines
Suspect door handle is broken on Indesit Washer Dryer WD12x
yes u can open door from the inside,take the top off (take plug out first)put your arm down to near the door latch and you will feel the mechinism there just gently push down or up until the door opens,if water is still in the washer then take drain pipe out of the waste pipe and place a bucket on the floor then put the pipe in that to manualy drain it,hope this helps you,ps you can buy a new door handle from any washing repair shop and they are easy to replace just see how the old one comes off,rgrds,paul
Jul 07, 2009 | Indesit W 123 Front Load Washer
Door to my washing machine is locked and I can not open it.
I have the same machine, the pump is behind the round door at the bottom of the machine. use a heavy paper clip puched into the little hole to unlock it andwith a rattle motion turn the door clockwise and it will pop off. the pump is right behind it. It's a big screw cap, you will get wet if the machine still has water in it. Use a wet vac if you have one to catch the water. there is also a white plastic door release handle hanging there just a little tug with the machine off and the door will open. good luck ,Chuck
Mar 09, 2009 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
