Question about Mitsubishi Televison & Video
Mitsubishi tv stuck on usb mode
I plugged my MP3 player into the USB port of the television, but it was taking too long to load, so I removed it. Now the screen is stuck on "USB Media Player". How can I fix it?
ThaMp3Doctor
  • 8596 Answers
SOURCE: iLO 2GB MP3 Player Not Working!!!!
1) Disconnect from computer, turn it off, hold in volume + button and reconnect it to your computer - continue holding volume + until the Found Hardware Wizard comes up.
2)
REFORMAT FOR WINDOWS MEDIA PLAYER - Erases Everything: Connect your iLo player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "ILO 2GB" (wording may vary slightly), and then select "Format." - this should erase everything, and give you a fresh start.
Posted on Mar 19, 2008
  • 8 Answers
SOURCE: usb port
The USB port is for updates, I am not sure how to update the television? However it is my understanding that it doesn't read MP3 or other media players, However there are several DVD players that read media devices.
Posted on Jan 01, 2009
SOURCE: disconnected samsung mp3 player
Gday...the most likely issue concerning the "USB Disconnected" message on the U3 is that the device has installed itself with incorrect drivers. If this is the case then following these steps should rectify your problem...
1) Plug the MP3 player into the USB port
2) Open up Device Manager (Start, Settings, Control Panel, System, Hardware, Device Manager)
3) Find Samsung UP-Y3 in the list (should be under "Other" or "Portable devices" with a ? next to it)
4) Right click on this and select Uninstall
5) Remove the player from the USB port and plug it back in
Windows should automatically detect the device and install it's own drivers. If not, and you have a driver disk, then just install the Samsung drivers. You should now be abe able to drag and drop files onto the player using Windows Explorer. Hope this solves the issue.
Cheers,
Scott
Posted on Jan 02, 2009
SOURCE: I HAVE AN EMERSON MP3
I have an Emerson 2gb MP3 player model EMP 312-2, not sure if this info is for you or not. Make sure you are in the MUSIC MODE, when you use the menu button to go from music mode, voice mode, settings etc. you must push menu button again when the mode you want is hi-lited. I had a similar problem. Files were loaded (my music is on my harddrive already so I just copy to mp3 player) but when I turned player on it said no files. AHA, I finally realized I had somehow got into the voice mode and I did not have any voice files, so it said no files. I then went to Folder Mode and it only said micin.dir and it was empty, THAT WAS BECAUSE I WAS IN VOICE MODE, when I switched to music mode, they were all there. I know this sounds very rudimentary, but I am pretty computer literate and had no idea how I switched to voice mode. Before I figured this out for myself I called Emerson customer service, they said it was bad firmware and send it back. If someone there had walked me through what I just told you it would have saved me a lot of time. Hope this helps.
Posted on Apr 01, 2009
SOURCE: 1 gb AMT MP3 player stopped working after 1 month
use flash Flash_Disinfector.exe
it flash ur mp3 memory
then go to tools>>folder option >>view>>
unselect hide protecting oprating system files
then select show hidden files
then you can easily seen the file" autorun.inf"
then go to cmd (run cmd)
change attrib by this command
type drive name from you want to delete
attrib -s -h -r autorun.inf
then
del autorun.inf
it will fix ur problem
Posted on Apr 14, 2009
Used for years. Deleted mp3 files. Tried to reload new mp3 files by select all and drag and drop to audible folder. Message said it was full and would only load partial. Deleted partial load safely...
Sorry mate it has been corrupted and and may not work any more it seems the set up and read file that is like a operating system has been moved or deleted. The same things happens with usb drives.or has been disconnected without using the disconnect usb device icon.
Jan 31, 2011 | SanDisk Sansa m240 MP3 Player
My son's mp3 stopped playing yesterday. We plugged it into the computer. There's no response from the player and no indication from the computer. the usb ports on the computer work.
Are you plugging it infront or at the back USB port of the computer? Try turning it off first and then plug at the back usb port. Once plugged in, that would be the time you turn the MP3 player on. If the computer still does not detect the mp3 player as new usb device, then i guess the mp3 player must have been fried due to not being "safely removed" from the usb port. Make sure you are safely removing ALL usb devices when disconnecting them from the computer.
Mar 01, 2010 | Audio Players & Recorders
I plugged in my usb cable for a coby MP-C582 mp3 player
I work for Coby technical support. Our customer service phone number is 1-800-727-3592.
If you have a piece from the USB cable stuck inside your USB port, the computer needs to be serviced. Until that piece is removed you will not be able to use the port. I do not recommend trying to remove the piece youself.
If you feel this solution doesn't deserve a good rating, please let me know why so that I may better assist you. If there is anything more I can do to help, I will!
Dec 30, 2008 | Coby MP-C582 MP3 Player
I unlplugged my mp3 without removing it safely and now its stuck on a message that says please connect player to PC. and i did and it doesnt reconize it.
Unplug your mp3 player again and reboot your computer. Once windows fully loads plug your player back in and it should recognize it. If your player won't recognize at that point run windows update and download all the latest updates and reboot again.
Also, try plugging it in to a different usb port on your computer (somtime that works for me)
Jul 16, 2008 | Audio Players & Recorders
Doesn't look like its charging
Change the USB cable and/or PORT. If you have another device assigned to the USB port and didn't select to remove it correctly, the PC will not recognize the new MP3 player when plugged into that port. Simple fix... remove the MP3 Player from the USB, reboot the PC, then plug the USB cable back in. If it doesnt' recognize the MP3 you have something assigned to that port, possibly a printer and it will need to be removed before you can use it.
Apr 19, 2008 | SanDisk Sansa e250 MP3 Player
Files will not load
Try reformatting the drive to factory defaults. I would also try this unit on other PCs to verify that the USB port will not work correctly. Does the USB port on your Sony Walkman MP3 player have any damage or broken pins/connectors on the USB port?
Mar 31, 2008 | Sony Network Walkman NW-E005 MP3 Player
MyMusix PD-6110 MP3 Player wont play any songs
Unfortunately, your files must have gotten corrupt. This issue is most prevalent if you disconnect the mp3 before it has completed the transfer of songs.
To fix it, format the mp3 by plugging it into the USB port, right clicking the drive that is displayed and choosing "Format". This will remove all songs from the mp3 player. Afterward, you can re-add any songs that were lost. But make sure when disconnecting, you see no loading animation on the screen. Then right click the "Remove Hardware" icon on the bottom right of you screen, choose "Stop". Check again for a loading animation on the screen (if there is one, wait until it stops), and you can remove the mp3 from your USB port.
Jan 23, 2008 | MyMusix PD-6070 MP3 Player
How to clear the mp3 player and put new songs on it
Take off the USB cap on the side, and plug that end into the USB of a computer. The "My Computer" window should open and the screen on the mp3 should turn on. At this time, you can copy/paste songs onto the new drive that appears. (probably drive F: or D: ) When you're done, make sure to unmount the drive. On some Windows computers, there will be a new icon on the taskbar at the bottom of the screen. Right click that and choose "safely remove hardware". Then click "stop", then "OK". When it says you can remove it, make sure the mp3 doesn't have a loading animation. (not the battery animation)
On Unix computers, right click the drive on the desktop and choose "unmount". Make sure you wait for the loading animation on the mp3 to finish. Then you can remove the mp3 from the USB port.
To remove songs, you do the same thing, but instead of copying and pasting, you just select the songs you don't want on it and choose delete. (If you're on a Unix computer, delete the ".trash" folder as well(it's a hidden file) or else the songs will remain.)
There's also a way to transport files back and forth with Windows Media Player, but I haven't tried it yet.
Dec 26, 2007 | MyMusix PD-6070 MP3 Player
Stuck m230
to put your mp3 in MTP go to settings, and then to usb mode, then click in MTP, i don't know how to solve the rest of your problem, sorry, hope you find a cure
Jun 17, 2007 | SanDisk Sansa e250 MP3 Player
Usb connect then removes player repeatedly
have you tried to insert it at the other usb port in your pc? cause the port that you are using might be already defective try to use the other port.
Jul 27, 2006 | Creative Labs MuVo V200 MP3 Player
Televison & Video Logo
167 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
