Heating pad has flashing light and no heat model hp215-s
Light flashes and gives no heat
SOURCE: new heating pad not working
have same problem with heating pad . reset control by unplugging unit for 1 minute , while holding down power button plugged unit back in . sometimes this takes 3 or 4 tries.
Posted on Jan 10, 2009
SOURCE: Dreamland electric blanket not heating
Yes we had an electric duvet from this company and it stopped working. Was replaced very kindly and no fuss by John Lewis and the same thing happened. (They had said they wouldn't replace again) . Spoke to the company but the woman was very rude. Said that if we lived in a rural area that was our tough luck basically. (A power surge or something). I don't think that's acceptable but we have given up on it now. I think there are 'known' issues with these products that are beingswept under the carpet.
Posted on Oct 24, 2009
SOURCE: have heating pad model 818-7. blinking red light
I had this problem with a heating pad too. I tried turning it off, unplugging it, then plug it back in and see if the light is still blinking. If it's not, set it to the temp you want. My heating pad was very temperamental that way, it didn't want to be set before it was plugged in. I hope this works for you.
Posted on Dec 16, 2009
SOURCE: Sunbeam Heating pad will not reset
I have a Sunbeam heating pad with the SW204 controller that the High light blinks when it is plugged in. I called Sunbeam and the first thing they said is it cannot be plugged into a surge protector. Next, to reset it unplug it from the wall, then unplug the controller from the heating pad. Wait 30 seconds, then plug the controller back into the heating pad and then into the wall. It did the trick. However, when I move it to the bedroom plug it does the same blinking. Sunbeam is sending me a replacement heating pad. They appear to be very good with Customer Service since it is more than a year old.
Posted on Sep 28, 2010
  • 3074 Answers
SOURCE: I have a Kenmore Heating
3 RED FLASHES: This indicates the normally open pressure switch.. Here is a link it has ac troubleshooting on it,also. Very helpful:
http://arnoldservice.com/Troubleshooting_Heating_Problems.htm
Posted on May 06, 2011
Mod.Hp980PT, red and top green light flash, no heat
This is a very common feature on these types of simple, high-volume, low-cost home appliances known as a safety fault. This fault will temporarily (or permanently) disable the appliance and happens for several reasons: (1) an over-temp (high heat) occurrence, (2) an over-power (power surge) occurrence, (3) an under-power (power outage or trickle power) occurrence, (4) an over-time occurrence (auto-off fails), (5) a short-circuit occurrence (exposed/crossed/frayed wires, etc.). Fortunately, it uses a digital "fuse" system and can be reset by the user. However, there is no universal reset process on SoftHeat products so you just have to play with it until you figure it out (customer service dept is no help). Mine is a Kaz SoftHeat HP980PT, with a red power indicator/power-off button and 4 green heat setting buttons. Mine faulted after a heavy storm caused multiple power outages and power surges in my neighborhood. The green light on the highest heat setting button was flashing on mine. Here's how I fixed it: (1) unplugged both ends of power cord and straightened out the cord, then plugged back in to the heating pad end. (2) While holding down the flashing light button, I plugged back in to the wall outlet. (3) While still holding down the flashing light button, pressed and held down the red power-off button, then while still holding down the red power button, I released the flashing light button, followed by releasing the power-off button. This stopped the flashing green light and caused the red power indicator light to stay on (steady-on). It works fine now. Note: Some models have an actual hard fuse in addition to the digital fault feature or possibly only a simple fuse (without the digital fault system). These fuses can the found at many retail stores and then very easily replaced. I hope this helps some of you!!!
Jan 27, 2014 | Softheat Heating Pad HP218 12 3P
I have a Fisher&Paykal DD6031 drawer dishwasher. Stopped running mid cycle. Lights flashing on drawer front green,red,yellow,red green,red,yellow . I don't know what that code means. On the inside Heavy...
follow this steps and fix it. GOD BLESS YOU
Heating Element
If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Heating Element Assembly
If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Check Fault Codes
If the display lights are flashing and there is an error code in the display window, check the wiring diagram and tech sheet in the dishwasher that will provide information on the fault.
Drain Pump
If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective You'll need to replace it. Drain pumps are not repairable.
Touchpad and Control Panel
If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Jul 30, 2013 | Fisher and Paykel 24 in. DD603H W Built-in...
My Hotpoint DWF40 Dishwasher flashes wash and rinse lights. Water fills and drains fine. How do i fix it?
test this and fix it. God bless you
Heating Element
Check Fault Codes
Drain Pump
Touchpad
Jul 24, 2013 | Dishwashers
G 2582 scvi
make this test and fix it. God bless you
Heating Element
Check Fault Codes
Drain Pump
Touchpad
IF THE MACHINE START IT SHOWS FLASH AFTER 2min
test this steps and fix it. God bless you
Heating Element
Check Fault Codes
Drain Pump
Touchpad
Jul 22, 2013 | Dishwashers
Whirlpool quiet partner iii pots & PANS LIGHT flashing
test the steps and fix it. God bless you
Heating Element
Check Fault Codes
Drain Pump
Touchpad
Kenmore dishwasher clean button constantly flashing ,washer has been unplugged ???maybe reset itself did not work. 2 yrs old
please follow this steps and fix it. God bless you
Heating Element
Check Fault Codes
Drain Pump
Touchpad
Jul 09, 2013 | Dishwashers
Dishwasher Siemens /se64m359gb tap light comes on in red on main display,what does this mean?
Heating Element
Check Fault Codes
Drain Pump
Touchpad
Jul 08, 2013 | Dishwashers
Sunbeam heating pad no longer heats. The red
I had same issue w/ red blinking light on my Sunbeam controller SW114, pad CAT93. Was about to toss away but then got it to work perfectly by doing this:1. With unit UNplugged, press & hold the single grey controller button2. While pressing the controller button, plug the unit inUnit will power up in the 'warm' (green light) setting; pressing the controller button will cycle you thru the others modes.
Jan 12, 2010 | Kitchen Appliances - Others
New heating pad not working
Apr 26, 2008 | Sunbeam 805810 HeatSense Heating Pad...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
