Question about HP Officejet 7210 All-In-One InkJet Printer
Color cartridge is not intended for use in this printer
I recently relocated my printer from my living room into my bedroom and when I plugged in the power I now have this error message on the display panel. It worked fine prior to relocating it. Any thoughts?
  • Pat Batta
    Pat Batta May 11, 2010
    what's the error message?
    Master:
  • 461 Answers
Check to see that the printer cartridges are inserted properly and locked in place.
Posted on Jan 20, 2009
I just purchased another RS120 to put in bedroom, have one in liveing room, the one in the liveing room works great but the one in the bedroom will not work, it will pick up the show from the liveing room...
is there a frequency channel selector on the headphone base, and on the headphones? the two pairs must be on different frequencies, or they will pick up the same show as the other
Oct 21, 2013 | Sennheiser RS 120 Consumer Headphones
I recently replaced both the black and the color cartridges but I'm still getting the message to replace the color cartridge. Please explain why this would happen and if i can fix it?
The problem could be due to a communication failure between the color cartridge and the All-In One (AIO) or by a short in the color cartridge. Here's what you can do:
  1. Try to re-seat the cartridges in the printer. Open the printer cover > remove the cartridges > close the printer cover > re-brick you printer by pulling out the power supply - black box behind the printer where the power cord is plugged in, and re-plug after 10 seconds. When the printer turns on, reinsert the cartridges and close the cover. Try to print a document again to verify that the problem is fixed.
  2. Try to insert a different known working cartridge to identify if it's a faulty cartridge issue.
  3. Ensure that you are inserting original supplies. Refilled, re-manufactured or clone cartridges are not recommend for use with your printer. These are unreliable and tend to fail unexpectedly. If you're using genuine Lexmark cartridges yet it continues to fail, please contact the Lexmark Technical Support Center for further assistance.
Feb 23, 2012 | Lexmark Z2420 Printer
Aerial Socket on LG TV ceased working
Most likely the TV has a burned out receiver board.
May 24, 2017 | LG Televison & Video
My printer error says: Color cartridge inserted is not intended for use in this printer
That printer is intended to use the HP 95 and HP 97 cartridge. If anything other than these are inserted then it will not operate. Check to be sure your color is one of these two. If it is then you should take that cartridge back to where you bought it and get it exchanged or contact HP.
Mar 18, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Brought new tv for bedroom freeview inc..set up
If you have got a good aerial, the high gain type- see image, it should run all the TV's you say. Make certain you have decent cable coming off the aerial (the stuff they use for satalite dishes). Then buy some high quality splitters, to feed the TV's. Don't split the cable outdoors!
Jan 25, 2010 | Televison & Video
Problems moving the router and getting the internet.
your bedroom cable phone plug has issue.
These is not dial tone or low voltage problem in line.
So just replaced that phone cable and jack .then check.
Aug 07, 2009 | Linksys WAG200G Router
"Cartridge Error: Cart. on left is not intended for this printer"
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
djiu9o15
Apr 19, 2009 | HP Officejet 5610 All-In-One InkJet...
I have a bedroom ceiling fan that recently started to have a surge issue. It was working fine before (although the remote control for this fan also worked on the Hampton Bay fan in the living room and the...
Sounds like you could have a problem with the fan....but there is also an equaly good chance it's the wiring of the fan. Perhaps a loose connection. If you are not familiar with checking electrical connections, you probably need to call an electrician to check the wiring SOON, before there is a short. If all connections are good, then you will know it's the fan (or the remote receiver on the fan).
Hope this helps!
Chad
Oct 14, 2008 | Hunter 52" Ceiling Fan With Light And...
My printer will not print.
Is there a cable physically connecting the printer to the computer? If so, do you see the printer in Printers and Faxes?
Nov 26, 2007 | Compaq Presario 5000 PC Desktop
HP Officejet 7210 All-In-One InkJet Printer Logo
265 people viewed this question
Seeker5211
Seeker5211
