Question about Vacuums
Kenmore vacuum model# 58014700 how do i replace the belt
2 Suggested Answers
SOURCE: Need to replace belt on a Kenmore Model: 116
Instructions:
Posted on Jul 10, 2010
Kenmore vacuum cleaner model no. 116. 5861279 belt replace
Do you need the belt or the directions for changing the belt? Sears Parts Direct has the manual for the 116.58612790 here: http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Vacuum-Parts/user-manuals/manual-downloads/Model-11658612790/0582/0640500?modelNumber=11658612790&diagramPageId=&documentId= . The direct link to the manual is http://c.searspartsdirect.com/mmh/pd_download/lis_pdf/OWNM/L0802691.pdf . See pages 14-15 of the manual.
To replace the belt, you need to remove the light cover and then the light bulb. Press in the sides of the cover and lift to remove it. the bulb needs to be pushed in and then turned couter-clockwise. Remove the cover screws. Then flip over the Power Mate and use the flat blade screwdriver to release both tabs. Turn the Power Mate back to right side up and press on the handle quick release pedal and lower the swivel. Tilt the cover forward until it snaps free. Carefully, use your screwdriver to pop the brush supports free on both sides to remove the brush. Slide off the old belt. (If needed, slide off the brush supports and washers. Clean the brush before reassembling the unit. Then replace the brush supports and washers.) Push the belt on motor drive and then onto the brush sprocket. Push the brush supports back into place on the base. (Make sure that this isn't assembled upside down.) Then line up the front of the cover with the base and tilt the cover back into place. Press firmly until you hear both sides click into place. Replace the cover screws, light bulb and bulb cover.
The belt is available here: http://www.searspartsdirect.com/Kenmore-Vacuum-Parts/742024/0020/116/Model-11658612790/0582/0640500.html . This is part number 5285; it's the direct replacement for the original 742024 belt.
I hope this helps.
Jun 16, 2016 | Kenmore Vacuums
How do I change the belt on the 116 model?
To properly fix a belt on a Kenmore vacuum, you will first need to indicate whether this is an upright or a canister vacuum. The model given, 116, is only the first part of the model number, and all Kenmore vacuums, upright and canister style, start with 116. There is a period first, then a whole string of numbers, 116.255553 etc.
Kenmore vacuums are mainly made by Panasonic for Sears, and most will use a Panasonic belt. If the belt is an upright, this makes it simple, and will be a Panasonic "UB" belt.
For a canister vacuum, most models use what's referred to as a cogged belt. This type of belt has little teeth on the inside of the belt, and is Panasonic CB-5 belt.
Instructions on How to Replace the Belt for an Upright;
There will usually be to plastic screws on the top of the agitator housing on the base of the vacuum, that will say belt access. Simply take a flat head screw driver, and turn the screws so that the screw is pointing up and down on both sides. Then pull the plastic agitator housing, or the top of the base of the vacuum off. Inside you will see a the roller brush, and the belt (or broken belt). Simply take the new belt and wrap it around the silver pulley located in the back of the machine, opposite the roller brush, and wrap the other end of the belt through the roller brush. Stretch the roller brush back into the housing of the machine, and replace the top of the base of the vacuum back on the machine. You should give the belt a tug, to ensure that the brush is spinning when the belt is being pulled..
Aug 02, 2012 | Kenmore Vacuums
I cannot open and replace belt on Kenmore Model 116 (594299900) BELT ( 20-5285
The manual is here and there are diagrams on page 17 and 18 showing how to access and replace the belt.
http://www.hammerwall.com/Manuals/Kenmore/Description/116.20612003/Kenmore%20Canister%20Vacuum%20Cleaner%20Manual/L0705059/
I hope that helps
Jan 26, 2011 | Kenmore 25512/ 25513 Progressive Canister...
Is there an easy way to see if a drive belt may be broken? It's so difficult to push my Kenmore upright vacuum!
Well there is only turning the vacuum over and see if the brush is rotating.
If it is not moving then you need to replace the belt.
If you need to know how to remove the bottom plate to replace the belt, please post the model number, the numbers you posted above are not the kenmore model numbers, the model numbers will look like this
316135912,FPF311PHSB, FGF316WGSK
Feb 15, 2010 | Kenmore 35912 / 35913 Progressive Upright...
How do I replace the belt on my Kenmore canister vacuum?
Turn the power brush over so the bottom faces up. On the bottom there are two access screws. Remove the two screws and then the top cover can be removed from the base. With the top cover off you can access the belt. You can get a replacement belt for your model here:
Kenmore Progressive Replacement Belt
Nov 17, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Kenmore cannister style. Cannot remove the
It depends on the model you have. Do you know the model number? If you need a replacement belt you can get one here:
http://www.vacbelts.com/kenmore.htm
Oct 25, 2009 | Kenmore Vacuums
Kenmore Vacuum cleaner #175.3866180 bags and belt
I logged into the Kenmore website, entered the vacuum model no. and found that the bag has been superceeded by 20-50004, which appears to be available only from Kenmore. The belt required is #5270.
Aug 01, 2009 | Kenmore Bagless Upright VacuumVacuum
Belt broken a a Kenmore model 116 canister vacuum
Greetings from GoVacuum.com,
Feel free to email me if you have any further questions, I'd be happy to walk you through it, or even shoot an instructional video to show you how you to replace it. My email is chris.jones at govacuum . com.
Chris Jones
GoVacuum.com
chris.jones@govacuum.com
Sep 29, 2008 | Vacuums
Vacuums Logo
157 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
