Question about Samsung RS2530BBP (25 cu ft) Side by Side Refrigerator
Refrigerator side not cooling. Freezer works fine.
Researching this issue and found that the issue may be the defrost timer. I unplugged the unit and let it set for about 6 hours and now there is water in the drip pan that wasn't there before. I have been trying to locate the defrost timer but I am not able to locate it. I read on other sites that this model does not have a defrost timer but that there is a defrost sensor on the heater. Is there a defrost timer on this model and if so, where is it and what does it look like and can I replace it myself? This unit is only 4 years old and I really can't afford to replace it. I have been looking for a diagram but have not been able to locate one. I have the users manual but it does not have a parts diagram. Thanks!!
murdozzz2
  • 75 Answers
SOURCE: inside fan area freezing up (no defrost?)
hi there this is a common fault you need to replace the evaporator cover with the new modified one which has a large heat sink around the fan to stop iceing up also you will need to replace the thermal fuse and the defrost sensor.
hope this is of some help
Posted on Dec 13, 2007
sandy82
  • 10 Answers
SOURCE: samsung SR-S22FTCS
dear friend
The water filter doesn't affect the cooling perfomance of ref.ther may be problem of defrosting of ref.compartment.
regards
sandy
Posted on Jun 08, 2008
tborn6
  • 700 Answers
SOURCE: samsung rs2533sw fridge not cooling
it sounds like the refrigerator evap is frozen up causing the compartment to get too hot. shut the unit off and let it thaw out. then take the screws out of the cover to check the stryrofoam on the back side of the cover to see if theres broken spots on it causing the air to bypass the evap causing it to freeze. Theres two screws behind the light cover and two at the very bottom of the cover and two behind the decorative plugs about 1/2 way
Posted on Dec 22, 2008
Sea Breeze
  • 4654 Answers
SOURCE: never bye a samsoung refrigerator
That model has a flaw that the defrost heater is woven into the evaporator. I think you may have a 5 year sealed system warranty and if the defrost element is defective the complete sealed system evaporator will need replaced. So I believe that a complait filed to the company regarding this flaw will get their attention and may solve the cost of repair.
http://www.servicematters.com/maytag_library/docs/ASC20051129001.pdf
Posted on Jul 23, 2009
SOURCE: Samsung Model No.RS2533SW Refrigerator
My ice maker has stopped working. Water is not flowing to the fridge at all
Posted on Aug 09, 2009
Maytag side by side msd264rheb freezer works frig isn't cold. We found ice on bottom freezer side and did melt it with a hair dryer. Frig vent is letting in, now a little cool air, but not a lot.
If you found ice in the freezer then there is usually a lot more behind the back plate. If you let it defrost completely it should work good for a couple days until the ice builds up again. you more than likely have a deefrost issue. There are usually nthree components in a typical defrost circiut. The heater, defrost thermostat and a defrost timer or control. one or those is bad.
Jul 28, 2014 | Maytag Refrigerators
Freezer side not cold enough, similar temperature as Refrigerator side
It could be many things. My first guess would be the defrost. The coil that gets cold in your freezer builds ice on it and the only way to get the ice off is to run a heater near the coil long enough for the ice to melt. All freezers have something built in to defrost and domestic are typically just an electric heater on a timer. When your freezer stops working again, you may want to pull open the panel of your freezer and see if your coil (a heat exchanger that probably looks a lot like your car radiator) is covered in ice. If it is, it could be the timer or the actual heater that is bad.
Nov 12, 2013 | Refrigerators
The freezer part of my fridge is working fine the fresh food part is not cooling we cleaned everything and there was ice built up on the flap so we unplugged it overnight and we noticed the fan not working...
Sorry to hear about your problem. Sounds like you have a defrost issue. Hence your unit is not defrosting. All of this apply's if your freezer side has ice on it. If not. you have other issues
Here is a list of some things that can go wrong.
1. Defective heat coil
2. Defective defrost timer
3. Defective defrost sensor
You should call a service company to resolve your issue.
Since I tried to help you, Please help me and Rate/Vote on the response. Thanks
Dec 21, 2010 | Maytag MSD2651 HE Side by Side...
Hi, our ge profile refrigerator is having temp
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 03, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Feezer seems to be stuck in defrost mode. Everything will defrost and and water leaks out on the floor. Refrigerator becomes too warm. If the unit is unplugged for a time, and then restarted, it works...
The defrost timer probably is not working at all...
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
Water Running in efrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Aug 16, 2010 | GE GSS25JEMWW Side by Side
Fridge boken, freezer fine
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
heatman101
Jun 01, 2010 | GE GSS25IFR Side by Side Refrigerator
Freezer working fine-refrigerator not cooling-unit bought 1998
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
tydue6
Oct 17, 2009 | Kenmore 50522 / 50524 Side by Side...
Problem with Whirlpool side by side refrigerator (Model ED25RFXFW01). Approximately 6 weeks ago, I found the refrigerator had quit cooling and ice in the ice maker was melting. The top half of the freezer...
sounds like a defrost problem ...
maybe the heater or defrost thermostat is bad...
he should bypass the timer and jump the heater to see if its woking...if not then i would remove the heating element for further testing. if the heater checked ok..it would only leave the defrost timer to blame.
good luck
Oct 05, 2009 | Freezers
Samsung RS2530BBP (25 cu ft) Side by Side Refrigerator Logo
48 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
