Question about Uniden GMR-1558 / 2CK 2-Way Radio
What frequencies does uniden use
I am trying to replace my motorola radius vl50 radios with uniden transceivers but need to match at least some of the frequencies on both devices. Is there some readily accessible source of info to determine which frequencies the different uniden models use? Thank you for your help.
    Genius:
  • 2,035 Answers
Please click on this link and download the manual and then refer to the page no 2 in specifications ,you get the frequency information:
http://www.uniden.com/pdf/GMR1558-2ckom.pdf
Good luck...
Posted on Jan 20, 2009
  • 296 Answers
If you are using it as a 2way then you should just have to set to the proper channel.
Can I get a motorola VL50 communicate with a motorola mh230r? if so, how can i do it?
No. Both radios are pre programmed at the factory. One is consumer frequencies. the other is business frequencies. They do not overlap or mix.
Dec 18, 2016 | Motorola Radio Communications
What are the default PL codes for the Motorola VL50?
I don't have a VL50, but a CLS is frequency two, code one. There is a way to reset to Factory default: press & hold PTT switch and the Monitor as you turn it on. If I got it wrong, try the scan switch instead of monitor. How this helps, if you want the actual numbers, post again please.
Feb 11, 2015 | Motorola Radio Communications
How to get a Talkabout T5720 to communicate with a
The frequency range and operatngmode of the two radios are compatible. To get the Radius operating on a GMRS channel you'll need a Motorola programming cable and software, OR a trip to a Motorola dealer for frequency programming. Considering the cost involved, the 2-watt output of the Radius, and the 1-watt output of the Talkabout, you would be better off performance and cost wise buying a pair of 5-watt GMRS portables.
BillB
Jan 11, 2010 | Motorola Talkabout T5720 (7 Channels)...
How do i get my motorola radius sp50+ to communicate with my motorola rdx radios
The radio must be reprogrammed by an authorized dealer to match the frequencies in your RDX radios.
Oct 02, 2009 | Radio Communications
How can i tell if i have a UHF radio or VHF radio
You can use the model number to tell if you are VHF or UHF. You will still need to know the frequency(s) and PL code(s) your radios have to get radios to match.
VHF model number starts with P93.
UHF model number starts with P94.
The current replacement radio for the SP50 is the CP200. It is construction grade and was made to replace the SP50. There are other radios which will also match the SP50 including (but not limited to) the BPR40 and the new CP185.
Apr 28, 2009 | Motorola Talkabout FR50 (14 Channels)...
Can Motorola TA200/T5622 work with newer T5000?
A 22 channel transceiver is an American system call FRS/GMRS radios which are actually illegal in the UK and rest of europe. They use different frequencies completely and will not work together on you other PMR radios.
Mar 15, 2009 | Motorola Talkabout T5720 (7 Channels)...
Two way radio cross model compatbility
Normally yes just as long as the frequency assignment to each channels are the same and no security/locking (such as (CTSS) is in place.
You have to check if the frequency settings of the Motorola matches those of the uniden.
Good luck and kind regards.
Oct 23, 2007 | Uniden GMR638-2CK (22 Channels) 2-Way...
Uniden GMR-1558 / 2CK 2-Way Radio Logo
51 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
Greg Cann
Greg Cann
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
