Frigidaire FAA065M7A Air Conditioner
Problem for Frigidaire FAA065M7A Air Conditioner
Blower motor cycling on and off
By markshew on Jan 20, 2009
I have a Payne Furnace (model# 396JAZ048080AAFA) using a CESO 110018-00 control board and I have two problems that I suspect may be related.
The first is at the start of the heat or cool cycle when the fan starts up. About 50% of the time, the fan comes on for 2-3 seconds, does not reach full speed and requires a "second attempt" to start and reach operating speed.
The second problem is at the end of the heat or cool cycle when the blower motor switches off. 2-3 seconds after stopping, it cycles on and off again for a couple of second and this happens 3-4 times before finally switching off.
Whe I use the manual override, the fan starts and stops without the above problems.
After looking at the circuit diagram, I notice that the heat fan relay seems to be energized via a transistor that get's it's signal from a "time delay circuit".
I have gone about as far as I can with this without testing to compoent level on the controller PCB (which may be beyond my skill level) so I am thinking about changing out the whole controller PCB.
Does it sound as if I am on the right track or do you have any other suggestions?
All comments welcome!
Thanks so much.
Mark
Solution #1
posted on Jan 20, 2009
Not Rated)
subzero_hc
Rank: Guide
Rating: 82%, 3 votes
Had this problem with a armstrong unit. Replace the board.
Was this helpful?
Yes
No
Popular Solutions for Frigidaire FAA065M7A Air
Questions and Unsolved Problems for Frigidaire FAA065M7A Air
Do you recommend Frigidaire FAA065M7A Air Conditioner?
Answer
Answer
blower moter turns off after a hour or so some times can run all day or turn off within a hour or so... (More)
Answer
my stove shuts off 2 minute after I turn it on there's a black wire to the left when you look at the... (More)
Answer
Need a wiring schematic for a Frigidaire FAA051N7A1 Air Conditioner. The unit fell out the back side... (More)
Answer
york mini split 07-21 this unit has power,but will not come on with the remote or manualy. when the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Frigidaire FAA065M7A Air...:
Top Air Conditioner Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Air Conditioner Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
