Question about Brother LS-2125 Mechanical Sewing Machine
Sc9500 brother sewing machine needle hits plate
SOURCE: needle jam
stuck the whole machine the needle did not move .needle and wheel handle both are stuck
Posted on Feb 28, 2008
SOURCE: Brother CS-6000 Sewing Machine - Jam
I had the same problem.. I think the bobbin used in this machine is no good I replaced mine.. It cost alot too.. but now I do not have any problems.. good luck
Posted on Aug 20, 2008
kent581
  • 87 Answers
SOURCE: The needle hits the throat plate
if a new needle still wont align with the needle plate, your needle bar is out of whack
Posted on Mar 18, 2009
  • 201 Answers
SOURCE: needles keep breaking & bobbing wont feed thru
First try taking your bobbin case right out of the machine (not sure if this model has a top loading or front loading bobbin, but your manual will help you here) and floss out the tension slot with a piece of strong thread. Don't use waxed dental floss, but non-waxed would work okay. (The bobbin case is the piece that the bobbin sits in.) Look around while you have the machine open and remove any fluff and thread you can see - TURN MACHINE OFF BEFORE DOING THIS! Replace bobbin case. Replace bobbin and make sure it "clicks" into the tension slot.
Then unthread the top of the machine, clean the tension disks by passing a folded dollar bill (or any paper money, depends on what country you are in) through the disks in the direction you thread the machine. Do this several times. Re-thread making sure you follow the correct thread path.
Make sure the needle plate is on firmly.
If after all that it still won't work, I'm sorry to say that it sounds like you have a misaligned needle bar. This commonly happens after you have a major thread snaffoo and needle breakage. The needle gets caught in the thread knot, pulls to the side and breaks but if it gets seriously caught it can pull the needle bar out of place. You cannot put the needle bar back in place yourself - it's a job for the workshop. Don't sew on your machine until it is fixed. The noise you are hearing is likely to be the needle striking against the needle plate or even the bobbin. Your timing will probably need re-setting too and this needs to be done by a qualified technician.
If you really need to sew before you can get your machine into the workshop, and if you can move the needle position on your machine by pressing a "sideways" button of some sort, you could try to get the needle in the centre yourself using this feature. This will not help if it is the timing that is the major problem.
Pam M.
Posted on May 03, 2009
  • 37 Answers
SOURCE: MACHINE RUNS BS2450 BROTHER SEWING MACHINE BUT
I'm wondering if the bobbin spool is set to wind? Or the clutch is disengaged (older models).
Posted on Jun 05, 2009
Needles hit the loopers making a grinding noise
Take it for a service and re-timing ...NOT a home fix
Apr 02, 2014 | Brother 1034D Mechanical Sewing Machine
I put on the 1/4 inch quilting foot and the machine will not hold the settings, feed: 2 to 2.5 and stitch width 0
This sounds like a stepper motor problem. When you say it will not hold the settings do the feed teeth stop moving? Your feed teeth should be 1mm above the needle plate at the highest setting. Is that working for you?
Dec 15, 2013 | Husqvarna Viking 1
Brother xr7700 needle hitting plate
sounds like the machine is out of time & needs to be serviced at a sewing machine repair shop
May 19, 2012 | Brother XR7700
Brother se 400
try changing needles
also possible that the machine is out of time
Apr 09, 2012 | Brother SE400 Computerized Sewing Machine
Have brother sewing machine sc9500. Need invisible zipper foot. Don't know which kind to get.
My invisible zipper foot is a plastic generic one which was describd as being "low shank" and it works fine on three different Elnas I own.
I would have thought your machine was a low shank style too, there is a fair bit of similarity between feet with low shank clip on style. So if your feet clip on and off the shank, then you should be able to clip on another type of foot too.
if you try this link http://www.sewingpartsonline.com/sewing-machine-presser-feet.aspx
then go through to the page for the foot attachment system that looks like yours you might be able to establish which one you need. THere is a brother high shank invisble foot listed, and an alternative part number. I jcan't see a Brother SC9500 machine listed so you might need to do a bit of elimination.
You could also email sewingpartsonline.com and ask them to help you identify the right foot.
Jul 12, 2011 | Brother Sewing Machines
My needle keeps hitting the plate and breaking. How do I fix this?
Take the needle plate off and see where it needle is connecting with the bobbin. The bobbin case may not be in place and this is what the needle is hitting.
Feb 27, 2010 | Brother LS-2125 Mechanical Sewing Machine
Mar 18, 2009 | Brother CS6000i Computerized Sewing...
Needle getes broken
Check to see if your needle plate is gouged or signs that the needle is hitting the plate. If so, you may be pulling a little too hard when the fabric is feeding. Sometimes when you pull too hard, it pulls the needle back and it will hit the plate instead of going into the needle hole and you will break needles. Try just letting the fabric feed itself and you simply guide it to make sure it stays in a straight line.
Feb 07, 2009 | Brother LS-2125 Mechanical Sewing Machine
Brother LS-2125 Mechanical Sewing Machine Logo
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
