Question about ViewSonic VX922 19" Monitor Flat Panel
VX900 power issue
The monitor is actually a VX900. When the monitor is attached to the computer ond the computer is powered on, the power switch does not work. It will not work until it's unplugged from the AC and then repowered. The power switch will then turn it back on. THE INTERESTING PART: If I turn the computer off or disconnect signal cable from monitor, the power switch works perfectly. Moniter turns on and off with no problem.
  • Phil Dickey Jun 29, 2007
    Yeah, it's been doing this since the warranty ran out...
    The suggestions you make are all good and very possible causes. I hesitate to dig into it because: when I take away the input signal, the power switch works fine.
    When I plug it into another computer it works fine.
    It's like there's some kind of sync signal missing coming out of my computer.
  • 432 Answers
Strange isn't it. I'm thinking it's in the monitor powersupply relay capacitor holding a charge and not discharging. Then again it could be a bad pin on the monitors male connector. Or loose pin-connector in the video connector. Has it been doing this for a while?
Posted on Jun 29, 2007
Wat is the exact power supply for lcd monitor ?
Here is the Power configuration of your monitor
For more information, visit this site
http://reviews.cnet.com/lcd-monitors/vx900-19-inch-multimedia/4507-3174_7-9691598.html
Good Luck, Do rate the solution if got help
Dec 04, 2010 | ViewSonic VX900 19" LCD Monitor
Have an old view sonic vx900 (~5yrs old). When you
Check the fuse on the inverter board and also verify it does have have 12vdc feeding the fuse. Worst case will be the lamps, power supply caps look OK?
Jan 18, 2010 | ViewSonic VX900 19" LCD Monitor
My ViewSonic VX900 won't turn on. I have had it since late 2003 and it has operated flawlessly. Went to turn it on; nothing. No light, no standby light. Checked the power cord against another monitor and...
The VX900 has 2 different version of the unit. One version has an external power supply and the other has internal power supply. Since you said you changed the power cord I would guess you have the internal power supply version. The issue you have is caused by the capacitors on the power supply board have overheated and blown out. This is a common problem on many LCD monitors after a few years of use. If you open the back of your monitor and look at the supply board you should see the bulging capacitors. Check our web page at: www.ccl-la.com for Pictures and examples of what to look for and what you need to get to do the repair. If you have any questions let us know on our web site and we will be glad to help you get going again.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Jan 12, 2010 | ViewSonic VX900 19" LCD Monitor
When turned on says no signal and screen does not light up is there a reset button this is monitor that is being switched to different computer HP computer
PC may be in hibernation mode or with power plug out f PC remove refit video card if it has one.
Try booting into safe mode then disable hibernation mode found in "power options"
Dec 04, 2009 | ViewSonic VX900 19" Flat Panel LCD Monitor
ViewSonic VX900 - How do I open the casing?
If no obvious screws are there then unit has to be carefully pried open.
Aug 31, 2017 | ViewSonic Computers & Internet
VX900
Hi
Even though you show 12 volts, you could still be coming up short in amps on your powerboard.
Updating the capacitors (all of them except for possibly the main) may correct this.
If that doesn't do it, then the inverter is the next target to check.
Fran
Jun 15, 2008 | ViewSonic VX900 19" LCD Monitor
Vx900 viewsonic monitor problem . Blank screen except for power off/on
no, Viewsonic has the part for sale 42.99 - free shipping. Easy to replace
May 25, 2007 | ViewSonic VX900 19" Flat Panel LCD Monitor
ViewSonic VX922 19" Monitor Flat Panel Logo
102 people viewed this question
Top ViewSonic Computers & Internet Experts
Steve Allison
Steve Allison
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
