Question about HP PhotoSmart 7350 InkJet Printer
7150 has dead ac adapter. How to remove inks with no power?
You need to cycle the power to get the cradle to the center where they can be removed
    Genius:
  • 2,120 Answers
Buy a new one from www.hp.com partsurfer or eBay.
Posted on Jan 20, 2009
The adapter light is on when first plugged in but then when I connect the adapter to my laptop the light goes off and it doesnt supply any power
I suggest check out the AC adapter first.
1) When plugged into power, and plugged into the laptop, gently wiggle the cable from the AC adapter TO laptop.
Any change?
Do the same on the power cord TO AC adapter.
NO?
Go on.
2) The port on the laptop that the plug from the AC adapter plugs into, is the DC Power Jack.
If we are discussing an Acer Aspire 5738Z Notebook PC, the DC Power Jack resembles this one, (Not installed),
http://www.batterysupport.com/acer-aspire-5738-jack-p-302046.html
(When I note the DC Power Jack, it is this link I will be referring to )
As you can see there is a Center Pin. All power removed from the laptop, use a small wooden, or plastic object, and see if this pin moves around.
ANY perceptible movement means a bad DC Power Jack.
DC Power Jack checks out it's back to the AC adapter.
Wanted to perform the easy diagnosis first.
This will require a multimeter. An economical, yet fine for this test multimeter, can be purchased for as little as $8 to $12.
Available in a multitude of stores. An auto parts store is but one example.
Analog or digital is fine.
http://www.youtube.com/watch?v=bF3OyQ3HwfU
(Analog is fine. Some of us still like 'em)
DC Voltage is what you are going to check.
Black probe lead (Negative) goes in the Common port on the multimeter. (COM)
Red probe lead (Positive) goes in the Voltage port on the multimeter. (V)
If the multimeter just has symbols around the Function Knob, set it to the dotted line over a solid line, symbol.
The plug on the end of the AC adapter, that plugs into the laptop, has a center hole, and a cylindrical metal shield surrounding it.
The Center Hole of the plug is where the red Positive lead, of the multimeter goes.
The outside cylindrical metal shell is where the black Negative lead of the multimeter goes.
Hold the AC adapter plug in one hand, and at the same time hold the red Positive multimeter probe in the center hole.
With the other hand touch the black Negative lead of the multimeter, to the cylindrical metal shield on the outside of the plug.
You should read 19 Volts (DC), or VERY close to it,
http://www.cellularfactory.com/laptop/ACER/3/305268/
I believe the AC adapter is the problem. Post back in a Comment as to your findings.
Regards,
joecoolvette
Apr 29, 2012 | Acer Aspire 5738Z-423G32Mn Notebook
Dell Inspiron 1521 battery not charging
Laptop batteries power a laptop when it is not connected to an electrical outlet. If the laptop battery fails to charge when the laptop is plugged into an electrical outlet, the battery is likely dead and needs to be replaced. Unfortunately there is no way to fix a dead battery. However, while a dead battery is the likely cause, it is not the only cause. The AC adapter may be broken, in which case the battery won't charge, or the battery contacts may be dirty and need cleaning. Prior to replacing the battery, perform simple tasks to ensure a dead battery is the cause of the problems.
1.Power down the laptop. Gently pull the AC adapter from the side of the laptop for removal.
2.Place the laptop in front of you, bottom side up. Locate the battery release mechanism. This can be a button that slides or needs to be pushed to unlock or release the laptop battery from the housing unit. Press or slide the mechanism. Slide or lift the battery from the battery bay for removal.
3.Insert the AC adapter into the side of the laptop. Power on the laptop. If the laptop does not power on, ensure the AC adapter is securely plugged into a working electrical outlet. If the electrical outlet is working and the laptop won't power on, the AC adapter is not properly working and needs to be replaced. Remove the AC adapter.
4.Dip a cotton swab in a small amount of rubbing alcohol. The cotton swab should be damp, not dripping wet. Lightly rub the dampened cotton swab onto the battery contacts and battery bay contacts to remove dust, buildup and grime. Allow the contacts to air dry.
5.Align the battery over the battery bay. Either press or slide into place. A clicking or snapping noise produced from the locking mechanism will confirm the laptop battery is securely locked into place.
6.Install the AC adapter. Allow the AC adapter to fully charge the battery for 8 hours.
7.Remove the AC adapter. Power on the laptop. If the laptop does not power on, the battery needs to be replaced.
Sep 01, 2011 | Dell Inspiron 1521 Laptop
When printing from my hp 7150 photosmart printer the words are not printing straight, they are lopsided
Cleaning the ink cartridges with the HP Printer Toolbox
  1. Click Start .
  2. Click Settings .
  3. Click Printers .
  4. Right-click the icon of the printer in use.
  5. Click Properties .
  6. Click the Services tab.
  7. Click Open the HP Photosmart Toolbox or Service this device.
  8. Click the Device Services tab. This tab does not display in Windows XP; proceed to the next step.
  9. Click Clean the Print Cartridges .
  10. Follow the onscreen prompts.
Manually cleaning the ink cartridges
  1. Turn the printer on and lift the top cover.
  2. After the ink cartridges have moved to the center of the printer, unplug the power cord from the back of the printer.
  3. Remove the ink cartridges and place them wide side down on a piece of paper.
  4. Prepare a clean, foam-rubber swab or a lint-free cloth slightly dampened with water.
  5. Locate the copper-colored circuitry strip on the back of each cartridge.
  6. Clean the copper-colored strip with the dampened swab or cloth. Do not wipe the nozzle end of the cartridge or touch the nozzle plate.
  7. Clean the carriage contacts on the back wall of the ink cartridge carriage with a damp foam-rubber swab or lint-free cloth. Use a dry foam-rubber swab or a lint-free cloth to remove moisture from the contacts.
Cleaning the ink cartridge cradle
  1. Assume an eye level position with the HP Photosmart printer.
  2. Locate the ink cartridge cradle.
  3. Using clean, moistened swabs, wipe the underside of each wall of the carriage where fibers may collect and come in contact with the paper. Repeat until no ink residue is seen on a clean swab.
  4. Reconnect power cord when finished cleaning.
  5. When finished cleaning the ink cartridges and the cradle, print a test page.
Apr 05, 2011 | Office Equipment & Supplies
How do i change the ink cartridge on my printer
These are the steps on how to install/replace cartridge(s) on Hp Deskjet 5550.
  • Press the POWER button to turn on the printer.
  • Open the top cover. The cradle moves to the center of the printer.
  • Open the cradle latch.
  • Slide the print cartridge out of the print cartridge cradle and discard it.
  • Remove the replacement print cartridge from its packaging and carefully remove the plastic tape. Hold the print cartridge so that the copper strip is on the bottom.
  • Slide the print cartridge firmly into the cradle. Ensure that the copper contacts of the print cartridge meet the copper contacts of the print cartridge cradle.
  • Close the cradle latch.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Nov 19, 2010 | HP DeskJet 5550 InkJet Printer
MYFI XM2GO WILL NOT TURN ON. ALSO WHEN I PUT IN CRADLE WILL NOT SHOW CHARGING
I had the same problem. This procedure from the "Technical Questions" section of http://shopdelphi.com/consumers/support/faqs/myfi/ worked for me:
"My MyFi won't power up, how do I reset it?
To reset your MyFi, start by turning the receiver off and removing it from its (car, home, audio system) cradle. Then remove the back cover and battery. Using a small paperclip, press the reset button located on the top left corner of the battery compartment. Now plug the AC power adapter into a wall outlet and plug the power port directly into the bottom of the MyFi (battery stays removed). Wait 10 seconds and listen for a beep. After you hear the beep the message "insert battery" will appear. Cycle the MyFi to ensure it powers up and powers down. If the power cycle is normal, then turn off the MyFi, unplug the power adapter, and reinstall the battery. Re-plug the AC power adapter directly into the bottom of the MyFi. Wait 10 seconds and listen for a beep. After the beep you will see the message "battery charging". Leave the MyFi plugged in until it's fully charged. You will see the message "charging complete" displayed. After the MyFi is fully charged, turn it on and reset to the factory defaults. Unplug the MyFi from the AC power adapter and using the battery power leave it on until it fully discharges (approximately 2-5 hours). Plug the MyFi in using the AC power adapter to recharge the unit and resume normal use. If you need help at any point during this process contact us at 1-877-463-3574 for technical support."
I hope it works for you too.
Sep 27, 2010 | Delphi MyFi SA10113 XM Radio Receiver with...
Hard drive will not boot.
try to install with other sytems and check the data cable
Jul 11, 2009 | Acer Aspire One PC Notebook
Remove inks from 7150 with power off
You can't. Buy a new one from www.hp.com partsurfer or eBay.
Jan 20, 2009 | HP PhotoSmart 7350 InkJet Printer
MYFI does not powerup
You may not be getting power through the base because of a bad physical connection between the base pins and the receiver, and it won't power up because it has no battery charge. Try plugging the AC power adapter directly into the bottom of the receiver (not through the cradle). Push the adapter plug toward the back of the receiver to see if the + sign on the battery on the top right of the screen shows that it is now receiving power and charging. Alternatively, with the receiver in the base, try pulling the top of the reciever toward you to tilt the receiver forward on the pins to see if it starts charging.
Sep 04, 2008 | Delphi MyFi SA10113 XM Radio Receiver with...
HP PhotoSmart 7350 InkJet Printer Logo
37 people viewed this question
Ben Johnson
