Question about U-Line Icemaker
How to install an icemaker water supply line over concrete floor?
I just bought a house with a concrete slab floor (no under-floor access, built in 1972). After closing, I found out the refrigerator icemaker doesn't work because it has no water supply. Upon further investigation, the nearest water source is the kitchen sink, which is on the wall opposite the refrigerator, about 8 feet away. The kitchen is U-shaped, sink on one leg of U, refrigerator on opposite leg, with a doorway at the bottom of the U. I have thought of 4 methods, listed in order of difficulty, easiest first, best permanent solution last, and would appreciate somebody listing some better alternatives.
(1) Buy a rectangular 5-gallon plastic water tank (about 12'' X 12'' x 4'' high) x and set on top of refrigerator. Connect it to the icemaker, and refill once every 2 or 3 weeks. Reset the icemaker ejector timer to offset the low water pressure. Easiest, but least desirable solution.
(2) Cut holes in the sheetrock walls behind the frig and underneath the sink. Run PVC conduit (necessary for replacing the line when it freezes as it surely will eventually) up the sink wall into the attic, across the attic, and down into the frig wall. Pull a plastic or copper supply line into the conduit. When it freezes, I can pull it out and pull in a new one.
(3) Cut the same wall holes, but cut additional temporary access holes in the doorway wall, and run the tubing completely inside the walls and above the doorway. Advantage is the line is less likely to freeze in the interior walls, disadvantage is the extra holes that will have to be refinished and repapered.
(4) Remove some vinyl floor tiles, get a concrete saw and saw a 1'' wide x 2'' or 3'' deep trench across the 8' wide floor. Install 3/4'' PVC conduit with 45-degree bend on each end, grout and finish to original floor level, pull in copper tubing, connect it up, buy new floor tiles if a match can be found, otherwise replace all tiles in kitchen. I think this is best long-term solution, but I hesitate to tackle the dusty noisy concrete sawing. Holes in the walls will still probably be necessary to get the trench far enough back against the walls. There is a small risk also of sawing into the existing water lines.
Anyone have some additional options?
  • 61 Answers
IM USE A 1/4 INCH WATER LINE LOOK FOR A SINK OR WASHER CLOUSE BY AND ATACH TO THE HOT WATER LIND IF YOU HAVE LIME IN YOUR STATE IF NOT USE THE COLD WATER RUNTHE HOSE INSIDE THE CAVINET TO HIDE THE HOSE.
Posted on Jan 20, 2009
Is there a concrete floor sealant that eliminated moisture seeming through the concrete slab?
if you want to seal the surface a epoxy paint is good !
but if the water come from under the concrete slab only a hole with aggregates ( small rocks ) and a swamp pump works fine !
Oct 04, 2015 | Washing Machines
How do I fix a low spungy spot on a floating engineered floor?
Last night I posted a very lengthy answer to this from my phone ...I clicked post answer and it disappeared. So here I am on the lap top trying it again
I need to know if you have a wood subfloor or concrete slab ?
The wood subfloor typically allows you a crawl space under the house if you are on the first floor. Drill 1/4" holes into the subfloor and inject silicone under the void. This will dry and be soft and flexible and water proof. Use a 10 oz cartridge and a caulking gun.
Silicone is not an adhesive so it wont cause issues with the concept of a Floating Floor system.
The concrete slab gives no alternative other than taking the wood floor up and solving it by repairing the slab with a inexpensive floor patch depending on the severity and size. I can give detailed instructions on this as well...if you choose to do it yourself.
Let me know
Oct 14, 2014 | Millstead Hardwood Reducer: Oak Harvest...
How to repair a water pipe leak under a concreat slab
Things to consider are cut and replace -1. Concrete saw the affected area replace and re-concrete (impact hammer is another option but a concrete saw is neater and you can control the cut better.. 2. You can bypass the pipe. 3. Dig under the slab - you obviously would need to be near an edge.
Jan 18, 2013 | Brett Plummer Android Apps
My water heater runs constantly lately and i noticed water at my property line and around half my house. i can't tell where the leak is coming from. house is on slab. i am afraid to ask. the floor...
Does the hot-water line running from the heater go into / under the slab before going back into the house?
Or does the pressure relief valve drain line on the water heater go into / under the slab ?
It could be as simple as a faulty pressure relief valve on the heater (which would be the most likely of the two possibilities). When the water heats, the pressure builds in the tank, the water flows out the faulty pressure relief valve and down the drain line under the slab.
A plumber would be the person to call.
Charlie
Feb 19, 2011 | Kitchen Ranges
Carrier Infinity AC indoor unit in the garage is leaking water on the floor. There is no ice on the coils, The drain is not clogged. There is no water in the coil area. I turned off power to the...
It seems as though you have an unrelated water leak....
Often the water supplies are copper tubing....
Copper tubing and concrete do not get along well...
but hey it lasts till the warranty is up....
and they can't see it from their house...
heatman101
Jan 16, 2011 | Carrier 52CQ315 Air Conditioner
We live in a slab home. We have been noticing a order that smells like sewage. It is mainly coming from the floor heating vents in the kitchen and in the back laundry room. Is there a way to find out...
some where under your slab your sewer pipe has broken. most times you must cut away the concrete floor and explore for damaged pipes.
Jul 23, 2009 | Plumbing
Whirlpool LHW0050PQ Front Loading Washer VERY NOISY during spin cycle
remove the top access panel 3 screws in top rear.
now look around and push on the drum from top
it has suspension shocks and springs like your car they should resist any movements.
look/wiggle the concrete balance blocks , no cracks or loose.
inside the tub are the arm solid /not loose.
run it with the top open what do you see/hear and where
look under the rubber flap in front did anything get under the tub
Dec 29, 2007 | Whirlpool LHW0050PQ Front Load Washer
U-Line Icemaker Logo
1,875 people viewed this question
Top U-Line Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
jasbo
jasbo
Are you an U-Line Kitchen Appliances - Other Expert? Answer questions, earn points and help others
