Question about Acer Computers & Internet
How do i copy & paste on acer chromebook
How do i copy & paste with the touchpad
4 Suggested Answers
joecoolvette
  • 5660 Answers
SOURCE: my acer chromebook AC710 SCREEN IS CRAZY CANT SEE ANYTHING BUT COLORS AN LINES WHAT TO DO?
The reason your monitor is in screensaver mode, (Read your other problem too), is there is no video signal coming to it.
No Signal
This is because the Netbook isn't sending one.
It isn't sending one because apparently you have graphics problems. Problems with graphics hardware.
So no, there is no Sync, or settings to change on the monitor.
(It is Not a video/graphics card. Your laptop uses Integrated Graphics. Intel HD 3000 Graphics )
However the point is moot now. Netbook is being sent in.
Point now is getting the info off the Harddrive, before some geek looses it.
(I'm a computer geek too, so that was no slam)
Remove the Harddrive. Then install it in an external enclosure.
You've seen an external enclosure, if you have seen an external harddrive.
You can buy just that 'outside case', too.
The external enclosure has a USB cable going to it.
The USB cable goes inside the enclosure, and connects to a small circuit board, with an interface on it.
The harddrive plugs into the interface.
The external enclosure comes apart VERY easily. Manufacturers make it easy to open the external enclosure, and install the Harddrive.
Usually a 2 piece case. One screw to open. Remove cover, plug Harddrive in, replace cover.
Plug USB cable into a USB port, on a working computer.
This is one example that will work with your Harddrive,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3195233&CatId=2783
[Harddrives are measured across their width.
A laptop harddrive is 2.5 inches across in Width. 2-1/2 inches.
A desktop harddrive is 3.5 inches across in Width.
Three technology styles of Harddrive, are presently being used;
1) IDE (PATA),
http://en.wikipedia.org/wiki/Parallel_ATA
2) SATA,
http://en.wikipedia.org/wiki/Serial_ATA
These two types of Harddrives use mechanical parts. For example a Spindle, Spindle Motor, and Platters,
http://computer.howstuffworks.com/hard-disk.htm
3) SSD,
http://en.wikipedia.org/wiki/SSD
No mechanical parts. Just electronic components. (Solid State)
Your laptop uses a 2.5 SATA harddrive ]
Going on..................
I haven't had any direct dealings with this laptop. Or the Aspire V5-171 version.
I see no Service Manual listed.
Searching the internet for Harddrive replacement info though, I ran into that there is a large panel on the Bottom of the Netbook; which has a single Philips head screw in the middle.
Remove the screw, remove the large panel.
This is supposed to be in the User's Guide, but cannot seem to download it right now to see.
It will be in replace the Memory. Ram Memory.
The Harddrive should sit in a compartment area all it's own.
The Harddrive itself will be in a sheet metal Caddy. Harddrive Caddy.
Remove a screw, or screws; to remove Harddrive, and Harddrive Caddy.
Once screw/s are removed, L@@K at the Harddrive.
There should be a piece of 'silk strap', to pull on.
Keeping Harddrive flat, and down in Netbook, pull on the strap; and pull the Harddrive across towards the OUTSIDE of the Netbook.
You are unplugging it.
You DO NOT want to lift straight up on the strap, as you will bend contact pins.
Once the Harddrive is slid over, then lift at an angle; and remove.
Lift up on the Back of the Harddrive.
This is the opposite side of the one that plugs in.
Open the external enclosure case, slide the harddrive in; then close the external enclosure case. (Referring to Tigerdirect example. Other external enclosures will be different)
Plug the USB cable into any working computer's open USB port.
Look in My Computer/Computer. (WinXP/WinVista - Win 7)
The external harddrive will be shown.
DOUBLE-click on the drive letter it is next to.
Have problems with that post back in a Comment.
Your Netbook, is supposed to be just an ACER Aspire V5-171 series of Notebook PC; with a Chrome logo on it.
For additional questions please post in a Comment.
Regards,
joecoolvette
Posted on Mar 05, 2013
jonsnell4
  • 22695 Answers
SOURCE: acer chromebook
Try running chkdsk/f to attempt to clear errors.
Posted on Nov 26, 2013
highwheeler8
throw any acer chromebook in the garbage or give it to a preschooler to learn to do absolutely nothing with. its the biggest waist of money ive ever spent in my life.
Posted on Mar 01, 2014
How do i tranfer my photos from sumsung chromebook to usb
I'm not familiar with the Chromebook OS but I'm assuming that you should be able to copy and paste them if it doesn't have a programme or app you can do it from.
1. Insert your usb device (your chromebook should recognize this as an additional drive).
2. Open the folder with the photos you want to transfer select *copy
then open the window for the usb drive and select *paste (*usually commands found when you right click on a mouse).
Feb 25, 2015 | Samsung Chromebook Series 3
How to change mouse sensitivity in chromebook
In the Web address bar, type "chrome://settings/" (without the quotation marks). Scroll down a bit to the "Device" section and move the "Touchpad speed" slider to the right to adjust the sensitivity of your mouse. You can also change a plethora of other settings from this page.
Aug 28, 2014 | Computers & Internet
How to copy and paste on a acer 710-2847 chromebook computer?
ctrl + C for copy and ctrl + V for paste
Here's a list of other keyboard shortcuts
https://support.google.com/chromebook/answer/183101?hl=en
Jul 16, 2014 | Acer Computers & Internet
How do copy and paste on a acer chromebook
Ctrl +C to copy and then Ctrl + V to paste.
Jun 12, 2014 | Acer Computers & Internet
How do i copy and paste on acer c7 chromebook
"to copy and paste a paragraph" - I just used my c7 to copy the prior phrase from you the text in your question and to paste it into this "add your solution" answer box. Here's how I did it...... 1-I placed the cursor in front of the word "to", and while holding the touchpad down with my left finger, swiped the cursor through the phrase to the end of the word "paragraph" (thereby highlighting the desired phrase), then lifted both hands. 2- With the cursor over the end of the highlighted phrase, I used my left finger to hold down the "alt" key to the left of the touchpad the clicked the touchpad causing the drop-down copy menu to appear, then lifted both hands. 3-I then used the touchpad to move the cursor over the word "copy" in the drop-down menu and clicked the touchpad.
4-Then I placed the cursor in this "answer" text-box clicked once once. Next I held down the "alt" key to the left of the touchpad and clicked the touchpad to cause the "paste" drop-down menu to appear and raised both hands. Finally I moved the cursor over the word "paste" in the drop-down menu and clicked the touchpad, thereby successfully copying and pasting the phrase from your question. PS - an alternative to holding the left alt key and clicking to get the drop-down menu is to place two fingers on the touchpad (about a half inch apart) and click with both fingers simultaneously. The latter method only works about 75% of the time for me, so I recommend using the alt key.
Apr 10, 2014 | Acer C7 Chromebook
Black screen
The game has probably screwed up the configuration. They do sometimes.
Press the power button and just before the machine tries to boot press the F8 key. That should allow you to restore or repair your machine.If there is absolutely no display, get it repaired under warranty.
Oct 25, 2013 | Acer C7 Chromebook
Touchpad Part Number
Your best bet is to disassemble the laptop and verify the part number, it may be different on different laptops. I've never used this site, http://www.cdsparts.com/m-3-acer.aspx?gclid=CKr055Sok7gCFVEV7AodHnoAiA ,But it's a place to start.
Jul 03, 2013 | Acer AC700-1099 Chromebook Wi-Fi
Acer 5102
You need to download and reinstall the latest touchpad driver from Acer Support at the following link. Copy & paste the link to your browser
http://global-download.acer.com/GDFiles/Driver/TouchPad/Touchpad_Synaptics_9.0.3_Vistax86.zip?acerid=633640464790858763&Step1=Notebook&Step2=Aspire&Step3=Aspire 5100&OS=V10&LC=en&SC=EMEA_27
Oct 23, 2009 | Acer Aspire 5100-5022 Notebook
Computers & Internet Logo
865 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
