Question about Dryers
Whirpool duet dryer stopped working PF signal
Our dryer stopped working. A PF signal comes on
  • 61 Answers
PF MEEN PAWER FAUILER SOME HOW YOU LAST POWER TRY TO UNPLUG AND PLUG BACK IN AND PUSH CUNCEL . IT WILL RESET THE BORD IF IT DOSEN;T YOU MAY HAVE A BAD BORD AND IS NOT TAKING COMAND
Posted on Jan 20, 2009
My whirpool dryer panel comes on but when you push the start button!, it clicks off and then displays the pf code.
PF is a Power Failure error meaning electricity has been interrupted to the machine.
Any electrical interruption to the machine such as a circuit breaker being reset or weather related power outage can cause a PF error code.
To remedy;
Press the Pause/Cancel/Stop button twice to clear the PF in the display.
Try to start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button.
If you continue to receive the PF error code, the control board may need to be replaced
Apr 23, 2015 | Dryers
What causes maytag neptune dryer has pf error? My dryer worked in air fluff but not sensor or timer mode. Now it will not work at all. the lights on the control panel just blink . What could be the cause..
Pf shows a power failure hols the stop clear button and it should work again.As for your other problems I will more details such as a model number Gas or Electric dryer and example of the problem in detail
Aug 05, 2014 | Maytag Neptune MDE5500AY Electric Dryer
PF ERROR
Had same problem with my ex-wifes drier. If possible load test your wall outlet. Chaces are one side of the breaker is not putting out what it should.240 total 120vac each leg.
Oct 03, 2017 | Kenmore 659 Electric Dryer
My Maytag Neptune Dryer stopped running & is
as per heatman The most common cause of your appliance giving you the PF error code is a problem with the power coming in from your utility company. Of course if there is an interruption of power, and then the power comes back on you will get the PF code Loose wires going to the circuit board or the control can also be a cause of the error code. If a wire terminal end happens to get corroded or loose, the vibration from the machine can cause slight power problems and this can cause the PF code to be displayed. Finding the cause of this type of problem is like finding a needle in a haystack. Sometimes you can cause it to be displayed by banging on the side of the appliance or slightly moving the wiring harness, to see if you can get the error code to display.
The bottom line about this power failure error code, is that it is power related. Finding the exact cause can be difficult. If you are continually having to reset the appliance then check to see if all of your appliances are giving the same code. This will indicate utility power problems. If only one appliance is giving the PF code then it is probably internal to the appliance.
Jul 12, 2011 | Maytag Neptune MDE5500AY Electric Dryer
What does PF stand for when my dryer stops working it will state this??
PF is the standard error for power failure. First check to see if this condition happened. Otherwise I would check the dryer cord and the outlet to make sure they are secure.
On most you press HOLD TO START to continue the cycle or OFF/Pause to stop.
Apr 30, 2010 | Kenmore 62602 Electric Dryer
I just plugged in the dryer it has a "PF" message and won't do anything, unplugging dosen't change anything....
Pf is power factor. It is showing you there was an interuption of power. Some models you have to wait at least 3 minutes before you can press stop / pause / cancel to clear the PF. If you still keep getting PF go to the main CB panel and turn off the Dryer CB by physically pushing to breaker to the OFF position to reset the breaker then back to on. You will have to wait again before you can clear the PF. If after resetting the breaker you still get the PF in the display you may have to find out what power you actually have at the outlet. 115V or 230V. Other factors come into play also like 3 or 4 prong connections vs the previous connection. They do make a difference and if the power cord was installed incorrectly the PF will never clear until the cord is connected correctly.
Thanks for using FixYa.
Kelly
Mar 07, 2010 | Dryers
Error code PF
PF means power failure. Check your electrical connections and voltage for proper voltage
Jul 09, 2009 | Frigidaire AEQ7000ES Dryer
Fridgidaire dryer stops with code PF
pf isd power failure
with so many differant possiblities
it would be hard to nail it down here
but i would check my outlet chord and termianl post
where the chord connects to the dryer
one or more of the connections could be loose
Jul 01, 2009 | Frigidaire Electric Dryer
PF singal on dryer. Can not start dryer something electrical possibe pf power failer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
Jun 03, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Aeq6000es2 dryer getting error message PF
power failure...reset breaker for dryer restart cycle then it should be g00d!!!!!!
Mar 31, 2009 | Frigidaire AEQ6000ES Electric Dryer
Dryers Logo
324 people viewed this question
Top Dryers Experts
