Question about Boston Acoustics TVEEM25 TVee Model 25 SoundBar Speaker System -
Boston acoustic teevee 25 sound bar goes into standby mode after two minutes of activating.
After 2minutes activating the sound bar from standby mode it returns to standby mode. Before going into standby mode the sound bar and subwoofer function fine.
  • 7 Answers
SOURCE: Boston Acoustic BA735 digital CD quality 16 bit/44.1khz speakers
Assuming you are using digital BA735.
Dell laptops come with a proprietery s-video dongle. It gives you a digital output which can go into the BA735 speakers.
I use one set of BA735 with two computers. Computer A sends digital out and Computer B sends analog. BA735 plays both. I listen to music using digital while the analog from the other computer alerts me to the incoming messages in Pidgin.
I did have to change bios settings on one computer to use the on-board audio.
To enable digital output in XP, click on the speaker icon > Advanced > Select Enable SPDIF. You can leave the PC Spk Mute unchecked if you want the analog output as well. That's all.
I hope you are able to enjoy the rich sound of BA735. It's beautiful. My ears thank a lot for replacing those desktop speakers. BA735 hardly takes up any space . Two small speakers are perched on the hutch and the bass module is somewhere behind the desk, completely invisible.
Posted on Mar 06, 2009
SOURCE: Need new Power Supply Boston Acoustics Model No.
Boston Acoustics 12VAC 3000mA (3A) Adapter -BA Model DM12-3A0-1AN Only Source: BA Direct (in NJ: 978/538-5000) $54.00 (Incl. S&H) Ordered one on 7/8/09. Meow! Florida
Posted on Jul 16, 2009
SOURCE: Boston BA790 Subwoofer Making Strange Noises
I just took my sub apart and found that the surround on the driver speaker inside the sub was totally crumbled and lying in pieces throughout the sub box.
I'm looking around now for specs on the sub speaker so I can find a replacement.
Posted on Feb 15, 2010
SOURCE: My speaker set up boston acoustics ba7500 will'nt
The Guys at Boston Acoustics helped me get my speakers to work. The Boston BA7500 speakers are coaxial digital speakers so you need a digital output on your sound card. Analog will NOT work. My new HP Pavilion has a Realtek sound card with a digitial RCA plug output. I had to go to Amazon and get a male RCA to 1/8" Stereo Mini Female adapter plug. I just pluged it in and configured my sound card to 16 bit 48 khz output to the RCA output and everything works great. The speakers sound better then ever, great for 10 year old speakers! They sound better then anything I have seen avalable today. The guys at Boston were the only guys that helped with getting this to work! Thanks again to them and Amazon has every type of adapter plug you may need. Good luck.
Rick
Posted on Feb 20, 2010
SOURCE: no sound in sound bar and subwoofer
for Jameslicon re wireless sub going on and off repeatedly. Both the soundbar and the sub have 4 wireless channels - try a different pairing of those channels. There is a sliding switch on the back of both units. I set each of mine to channel 4 and the problem went away. There is also a signal level switch with 3 levels on the back of the soundbar. If the wireless channel idea does not work, try a different setting on the level switch. Good luck.
Posted on Nov 12, 2010
I HAVE A 50" EMERSON T.V. AND I HOOKED UP A SOUND BAR TO IT AQND I DON'T HAVE NO SOUND
Ensure that the output from the TV is feeding the soundbar. Use Settings/Sound/Output in the Main TV Menu.
Dec 02, 2013 | Boston Acoustics TVEEM25 TVee Model 25...
How do i access optical digital port
The cover is a plastic plug that prevents dust from entering. It is removed by pulling it straight out. Be sure to save the cover for reinstallation
Jan 08, 2013 | Boston Acoustics TVee Model 25 Sound Bar...
Can't get sound out of Boston soundbar when hooked up to 46" LCD Philips? Soundbar works fine when hooked directly to iPod.
You may have to go into the settings on the tv and turn off the internal speakers in order to get audio out of the jacks on back.
Dec 27, 2012 | Boston Acoustics Tvee Model 25 Sound Bar...
Programming time warner remote to boston tvee volume
I had just about given up on programming my Time Warner universal remote with my Boston Soundbar until a mental lightbulb came on. This is a two step process. Step 1: Program your Time Warner remote (I have CLIKR-5, instructions available for other models at timewarner.com) Using Pre-Programmed 3-digit Code method -Turn on soundbar - Press device button (I chose AUX) and OK/Select simultaneously until device button stays lit. - Point remote control toward the soundbar and enter code (447 for Boston Acoustics) - Press the device button again to store the code. The TW instructions say you should now be able to turn the device off to verify that it works, but this is not true for the soundbar. Hang in there with me. Step 2: Program your remote from the Boston Soundbar. - Press the power button and the volume up button simultaneously until the indicator light flashes orange. Here's where the instructions provided with the soundbar fail to explain how to do this. Each button is individually programmed into the TW remote. What you have done so far is enable the remote to accept the programming. - Volume Up: press the volume up button on the soundbar while it is flashing, the light should become steadily orange. - While holding the remote steady about a foot away from the soundbar, slowly press the volume up button on the TW remote four times. The orange light should flicker each time you do, turning green when completed. - Volume Down, Mute, Power: repeat the steps for Volume Up, except press the button on the soundbar you wish program to the TW remote while the soundbar is flashing orange. It should become steady before you press the corresponding button on the TW remote. Good luck, I hope this helps. -Deidre.
Dec 05, 2012 | Boston Acoustics TVee Model 25 Sound Bar...
Volume on Boston sound bar will not go up very high
There is a internal problem with it, Take it in for repair, out put transisters are probally fried,
Dec 02, 2012 | Boston Acoustics TVee Model 20 Soundbar...
My sound bar hooked up directly to my tv has no sound
You may have to go into the Bravia setup procedure and opt to disable its internal speakers
Nov 17, 2012 | Boston Acoustics TVEEM25 TVee Model 25...
Tvee model 25
Have you checked all your wire connections? To make sure thier not loose.
Aug 05, 2012 | Boston Acoustics Tvee Model 25 Sound Bar...
Where is the fuse for a Boston TVee Model 20?
Same thing here, I'm afraid, my Boston TeeVee 20 sub randomly goes on and off. I've taken it apart and to see if it might be the fuse and unfortunately the fuse isn't a standard unit, rather it's a "built in thermal fuse", see picture. This isn't going to be easily switchable, and in any case I'm not convinced the fuse is the problem as the sub sometimes does come on--sounds more like a wiring issue to me. Shame as now that I've got this opened up it's clearly a well-made device, other than the issue we're running into. 11_3_2012_5_50_45_pm.jpg
Jan 24, 2012 | Boston Acoustics Audio Players & Recorders
Trying to synch my remote to the new tvee model 25 sound bar and can't get the orange lights.
I had this same problem and it was due to their instructions which do not adequately explain the setup procedure.
On my own, I was successful in programming volume up but that was all. I assumed that for volume down I would hold the power button and the VOLUME DOWN button and wait for the flashing light just as I had for volume up. Problem is, you never get a flashing light.
Today, I spoke with a rep from Boston Acoustics who patiently explained that step one of the instructions has to be done the same way each time as it is the step that puts the soundbar into programming mode.
It is only at step 2 that things change.
The solution is to hold the power button and the Volume Up button every time in order to get the system into programming mode. Once the light is flashing, in order to program Volume Down, you then hold the Volume Down button until the light goes solid. Once the light goes solid, then press the volume down button on your remote 4 times slowly. Works like a charm.
Works the same way to program the mute button. Follow step one to get the unit in programming mode. Once the light is flashing, hold down only the mute button until the light goes solid. When the light goes solid, press the mute button slowly 4 times.
OBTW, this was programmed with a Logitech Harmony 650 remote unit.
Sep 05, 2011 | Boston Acoustics Audio Players & Recorders
Boston Acoustics BA7500... Problem
Try installing an old creative driver for digital audio but use system restore to take a backup of your settings first. Also, you may have to update the bios and unselect the AUTO mode for sound.
Feb 18, 2008 | Boston Acoustics BA7500 Computer Speakers
Boston Acoustics TVEEM25 TVee Model 25 SoundBar Speaker System - Logo
Top Boston Acoustics Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
