Question about Kenmore 22422 Top Load Washer
Kenmore 70 Series leaking water from bottom
The washing machine is leaking water from the bottom. Not alot of water, just a little. Without looking under the machine, does anyone think there could be rust spots letting water seep through.
    Novelist:
  • 101 Answers
I used to work for Sears as a home repair technician and washers and dryers were my specialty. Most likely the problem is with your water pump. I ran across this issue many times and what happens is people leave things in their pockets and it destroys the pump. A hair pin or coins, I have even seen socks and under ware get stuck in them causing leaks. What you want to do is tip the machine back and look at the pump. It is located right at the front of the washer with two hoses connected to it. You will want a pair of hose clamps though if you don't want water all over your floor. Disconnect the pump and look inside it for anything causing the motor inside to not work, this will cause slow draining and even leaking. If it looks clear then look for any cracks in the pump. If there is a crack then it needs to be replaced. Just call your local appliance repair place and tell them what you need. Pumps run around 30 bucks or less on average for Kenmore's. If everything looks good on the pump check the hoses that run from the pump and make sure there are no cracks or holes in the hoses. If they look good then the only thing left is the tub and the overflow tube. Chances are though that your pump is what the problem is and it is an easy fix. Good luck.
Posted on Jan 21, 2009
  • 61 Answers
MOS OF THE TIME IT THE WATER POM. PULL THE WASHER FOWER AND TILD BAL TO LOOK ON BUTTEM AND LOOD IN BUTER FRON FOR A PLASTICK POMP THE HAS 2 CLAMS AND T BLACK HOSES
Posted on Jan 20, 2009
Whirlpool wtw7300xw2 washer leaking from bottom
check for cracked pump hose/ loose hose, leaking pump, small tube up to water level control
if the water is grey or whitish then it could have water in the gear box from a failed shaft seal
Apr 03, 2016 | Whirlpool Washing Machines
My less then 2yr whirlpool front load washer is leaking ALOT of water from the bottom under it what could it be
The first thing to check is the door seals. Look for holes and tears. If there are none, the bottom panel comes off when you remove the screwes. Then you can see the filter trap and the pump. Start it and see where the water is coming from. If it is coming from up high then the filler tubes or the soap dispensor is leaking
Feb 05, 2013 | Whirlpool Duet GHW9150P Front Load Washer
LG Intellowasher 7kg wd-8015c leak
Most of the time it is the door seal, open the door and check all the way round. check the sump hose and pump, sometimes it can leak from the soap draw hose to the outer tub, but not in your case I think. In most cases this can be fixed easy and is the door seal. to find out if it is coming from the front or the back, just place some news paper on the floor under the machine and take a look to see if it is the front or the back. a door seal is about 15/25 pounds retail
Oct 24, 2012 | Washing Machines
My Bosch 300 series clothes washing machine is leaking alot. It leaks during the initial wash cycle from the lower left side. I have cleaned the detergent tray and it appears fine. I have also opened up...
Bosch 300 series This video will show you the 5 main areas to look, the washing machine door seal, the pump, check the drum bearings; look for a split hose, water coming out of the soap draw. This video tutorial will help you find the leaking parts and will also show you what needs to be done to repair it
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Mar 26, 2011 | Bosch Nexxt 300 Series WFMC2201UC
WAter leaking out of the bottom only during a large load
Look under bottom may be a hose or pump leaking Look around the hot/cold water inlets hoses May be coming from them and not the machine and running under the machine unplug it be safe
Mar 18, 2011 | Washing Machines
Kenmore heavy duty 70 series model 110-8237012
probably your drain pump leaking it has a seal right where it attaches to motor,,,,mine is leaking there but haven't replaced it yet! lol
Feb 27, 2010 | Kenmore Washing Machines
Kenmore series 70 squealing and leaking water
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
It sounds as if your pump is bad.
See the following illustrated description of how to access and check / replace the pump.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=134&osCsid=8eaba8b07483055c9c0f23bd2274f0a8
Dec 11, 2009 | Kenmore 22422 Top Load Washer
GE whre5260e1ww zh133346g top load washer is leaking small amount from the bottom of the machine during wash cycle? I took the back of the machine off and the pump and motor assembly had broken off from...
Hello there:
Here is a few tips that might help you out
Hope that they are very helpful for you
Best regards Mike
Washing machine is leaking Washing machine leaks are very common. There are many places a washing machine can leak from although most leaks come from the same few places. The most common cause for a leaking washing machine is the door seal. Door seals often get holes in them and water leaks down the inside of the washing machine which then runs out under the front. Water leaking down the front of the washing machine from the door can be caused by a worn door seal (the flange part that the door glass presses against when closed) or something trapped between the door seal and the door glass which breaks the seal. If the door seal doesn't look worn, or it's too young to be worn, then try cleaning the door seal's flange and the door glass on the inside of the door. Bits of cotton, un dissolved washing machine detergent etc can cause a leak.
Soap dispenser leaks
The next most common cause of a leaking washing machine is the soap dispenser. Leaking water from a soap dispenser is often caused by a blockage, or water pressure that is simply too high. Despite seeing many leaking soap dispensers, I've never seen a soap drawer with a seal, they just rely on water not getting to the front which is not really good enough. Some Hoover soap dispensers in particular, are renowned for leaking, and over the years Hoover have had to introduce modified soap dispensers twice.
Some washing machines, can flood water out of the soap dispenser when a hose gets blocked (usually with un dissolved soap powder) Indesit, and Candy, as well as some of the later Hoover washing machines suffered from this design flaw. The hose where the water is flushed down, was right at the front of the soap dispenser on these washing machines and the hose wasn't wide enough. Un dissolved powder from a tablet or lumps of detergent through poor hot water pressure can block this hose solid. (Note: water flooding out of the front of a washing machine's soap dispenser can also be an indication of overfilling or a partial pump blockage if it does it when spinning)
Finally, black gunge in the top of the soap dispenser can cause water to spray towards the front and leak. Take out the soap dispenser drawer and look at the roof of the soap dispenser. If it's covered in black gunge, blocking some of the water holes, it could be causing problems. In extreme cases I've had to replace the dispenser.
Tips for finding a leak on a washing machine
  • If you have a leaking washing machine, and you can't see where it's coming from, shove some newspaper underneath the washing machine. The slightest drop will give a clue where the water is leaking from. Pull the sheet out regularly to check for water leaks.
  • Water can run round things and drip onto other parts. Be careful with your diagnosis, as water dripping from a hose at the bottom could actually be leaking from somewhere else higher up.
  • Leaks usually leave marks, so it's possible to see something is leaking even without witnessing it. The soap suds that come out with the leaking water leave white trails. Rust is a good indicator of a water leak too. However, if you have had a previous leak cured, the "evidence" of a leak may still be present so be sure you don't blame a part that was repaired in the past.
  • If the washing machine leaks only at the end of the wash, when water is being pumped out. Make sure water isn't backing up and cascading over the top of a blocked drain pipe in the plumbing.
  • WARNING: Don't get electrocuted trying to witness a leak. It's dangerous running the washing machine with the top or back off.
Nov 13, 2009 | GE WDSR2080D Top Load Washer
Kenmore 22422 Top Load Washer Logo
3,912 people viewed this question
Sal De
fordexpert
 Brian Main
Brian Main
