Question about Black & Decker Drills
Dr250 black and decker drill chuck stuck to where it will not tighten around a bit.
DR250
  • 16 Answers
SOURCE: HOW DO I LOOSEN A KEYLESS CHUCK TO REMOVE A DRILL
Keyless chucks normally have a knurled ring at the base of the chuck that you hold in one hand while turning the large knurled taper with the other. If the chuck has been overtightened, and you cant open like this, try using two stilson wrenches (Pipe wrenches) one on each of these parts. Use a soft cloth in the jaws to avoid damaging the knurling. You can also try some Q20 or similar into the chuck to help lubricate it.
Posted on Jun 15, 2009
  • 14 Answers
SOURCE: Keyless Chuck how do you change the bit? Model
hold outside collar on chuck firmly with your hand and reverse drill
Posted on Aug 02, 2009
carlsbiz
  • 1124 Answers
SOURCE: my chuck wont open on my KD574CRE Black &
Try putting a vise grip on the bit,, and a big vise grip or chanel lock wrench on the key lock..
That should break it free..
Good luck..
Posted on Sep 10, 2009
  • 50 Answers
SOURCE: I have a Black & Decker DR250 Type 1, 3/8 inch
the coil spring should be attach to the 2 carbon inside it
Posted on Jan 16, 2010
heatman101
  • 43501 Answers
SOURCE: The chuck is frozen on
Yes, they are an inferior product. However you can replace the B & D chuck with a Jacobs chuck that will hold up and last for a long time!
Jacobs Chuck
heatman101
Posted on May 23, 2011
Black and decker 20 volt keyless chuck stuck open how to freeit
two pairs of multigrips
one on e chuck and the other on the bit that does the turning to tighten on the drill bit.
Apr 19, 2015 | Drills
Cord connection to switch of black and decker hammer drill Dr250
Look beside the wire in the switch their should be a small hole.put a paper clip in this hole and push down and then pull on the wire.
Jan 11, 2015 | Drills
Chuck is stuck , can't get it unlock to tighten around a new bit
Could be a dying battery making it not be able to open itself cuz theres not enough juice, try charging the battery and do it or get some wd-40 and spray it around the chuck and let it drip over the bit into it.
May 18, 2011 | Black & Decker Pivot Plus Cordless...
I have a DR250 and I can't get the chuck open
I've run into this from time to time, usually have to fix it with two pairs of channel locks, one on each collar on the chuck. With the drill facing you, hold the inner collar steady and turn the outer collar counter-clockwise.
The chuck should not stick like that under normal circumstances (mine only did it when it got full of sawdust), so there may be a mechanism issue and there is a fair possibility that you will break the chuck doing this repair. That being said, 30 bucks is reasonable for a new one, and it's not doing you much good jammed like that.
Nov 06, 2010 | Black & Decker 3/8" Variable Speed...
Bit is stuck. chuck wont open. turns but makes a
the chuck is broken inside if clicking. Ace and True Value stores sell chuck replacements
Mar 04, 2010 | Black & Decker BD12PSK 12-Volt Smart...
Black and Decker corded drill won't tighten around a bit.
the chuck sounds like it is bad or maybe stuck from rust, what you can try and do is spray some WD-40 on the jaws and then try and holding the collar with a glove and run the drill SLOWLY in forward/reverse and see if it loosens up if not you will need a new one.
Jan 14, 2010 | Black & Decker Drills
Black & Decker Quattro, drill, won't tighten to grip drill bit.
give a good coating of oil then clamp chuck in a bench vice or alike and using short bursts with it set in the forward direction to free the chuck
Jul 07, 2009 | Hand Tools
Having problems securing masonary Bit on 3/8 Black&Decker Drill 7
If it's an inexpensive bit, odds are it's spinning in the chuck. If the chuck key can't tighten the jaws well enough, you'll need to borrow or buy a different drill (or you could replace the chuck).
If you bought an SDS bit (one with slots milled in the shank), you're best off buying a bit made for a standard drill. It's not impossible to get a SDS bit to chuck into a standard drill, but it's difficult and they often slip loose during drilling, messing up the hole.
Take care!
May 24, 2009 | Black & Decker Drills
Black decker drill
If the problem is with very small bits 1/16" for example, the chuck could be defective in either design or manufacture. I have had this problem with a cordless model FS1800D. Waiting on a replacement chuck.
Sep 08, 2007 | Black & Decker Compact Power Screwdriver
Drills Logo
256 people viewed this question
Top Black & Decker Drills Experts
JOHN LAPIER
Are you a Black & Decker Drill Expert? Answer questions, earn points and help others
