Question about Frigidaire Refrigerators
Frigidair fphb2899lf4 refrigerator temperature does not hold goes down and up freezer stays constant
Rotu
  • 175 Answers
SOURCE: Refrigerator not cooling properly
You may have a low freon condition in the fridge section. Look to see if you have an ice block building up on the rear wall towards the lower left side. If so, you are low on freon and the ost likely culprit is a leaking evaporater. The best way to tell if you are low on freon for sure is to take out all the shelves, remove the light cover, then the 2 screws holding the fan cover, and then remove the back wall. You wont be able to pull it all the way out cause the cold control is attached to it for the freezer and fridge so be careful. Turn the fridge control all the way up to 10 and wait till the compressor is running. you can tell if the compressor is running by pushing in the little switch on the top of the door frame and seeing if the fan runs(one switch is for lights, the other for fan) if it runs the compressor is on. anyway watch the coils and see if they develop frost all the way from top to bottom. If they dont you are low on freon and are ooking at about a $600 repair. if it does frost all the way you may have a bad cold control or a stalling fan motor up by the condensor on top. The best way to tell this is the next time the fridge feels warm, sheck the frame around the door seal and see if it is hot to the touch. If it is you almost surley have a bad condensor fan motor. Hope you can wade through all tis to find the answers. Good Luck!
Posted on Feb 24, 2007
SOURCE: frigidaire refrigerator leaking water inside refrigerator
There is a plastic panel inside the frigidaire looking at the underside of the freezer inside the refrigerator compartment which holds the thermostate dial and the light fixture. remove the four 1/4 in hex head screws holding the assembly. pull the panel toward the front. you will expose the drain hose connection you can let it dangle from the plug wires or remove the panel completely, I worked with mine in place. look at the back funnel shape drain. just in front of that see a rectangular styroform collar which should be snug fit to match the underside. clean and dry all. there is a divider between the two funnel compartments, mine was separated between the plastic and the styroform. I used kitchen and bath tub caulking to seal the gap. and a little around the rectangle shape that fits to the underside. plug the wire back in if disconnected. reassemble the panel. that may fix it. good luck.
Posted on Jun 17, 2008
  • 531 Answers
SOURCE: Ge model PSC25MSTASS digital refrigerator setting
check for frost in the freezer back wall
Posted on Apr 01, 2009
SOURCE: Samsung double door refrigerator/freezer is not
I just had (have?) this same problem. I called out the repair man and in the end he suggested that I buy a new fridge because of all the problems reported with my model (RS2555SL) on the internet. Anyway, after a while I heard what sounded like a fan trying to spin on the fridge side. I unplugged the unit, removed the inside back panel on the fridge side. The entire coils and the fan had iced over. I removed all the ice, plugged the unit back in and it is now working. I will still replace this unit because I probably only corrected the symptom but the problem remains.
Posted on Jun 21, 2009
EnginEar
  • 57 Answers
SOURCE: my top freezer of my refrigerator was constantly
The GE refridgerators are known for bad mother boards (or circuit boards). The relay gets carbon tracking and causes arcing until it finally burns out. I am a mechanical engineer and I work with an electrical engineer. Our GE fridges went out in the same week. A place called appliance parts pros dot com had our parts in stock and we could order through the net on their website. The part is roughly 150.00 including shipping.
Posted on Jul 09, 2009
Chimes constantly. How do you turn them off?
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator. Cause of Beeping Noise in Frigidaire Refrigerator eHow
May 15, 2016 | Samsung RF263AEBP Refrigeration :...
There is a constant buzzing noise coming from the lower freezer ice maker. It is producing very few ice cubes. The control bar is down and in proper position to make ice.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
May 21, 2015 | Whirlpool Gold Series GB2SHTXTS (219 cu...
Frigidaire PLHS67EGSB1, the digital guage to set the tempoearture keeps chaning. set it at 0, day later might read 16, one tap down and goes back to 0. Next day might read 8, same thing. What can cause...
Most likely the=> 241608401 Thermistor and the=> 241608501 Freezer Thermistor You will need to begin somewhere and with the symptoms you are having it brings the controls the regulate temperatures to the top of my list for what may be causing this. PLHS67EGSB1 Controls item 21 and 21A are the thermistors I am here should you have questions, Thanks, John Tripp Appliance 911
uploads>parent.mediatoolbar.onimageuploaded('error with image');
Feb 13, 2014 | Frigidaire PLHS67EGSB Stainless Steel Side...
Inside the freezer has bunch of icicles and the freezer temperature fluctuate and it does not stay constant?
Your evaporator fan motor might be bad. This causes the icicles. Listen for the fan motor turning next time, you may want to hold down door switch.
Rich
Western Appliance Repair Boise id
Dec 02, 2010 | Jenn-Air Refrigerators
I have a Frigidaire refrigerato with top freezer that I keep on the back porch. The freezer has quit working completely. The temperature has been below freezing lately and I was wondering in this has...
Good day,
Yes, Frigidaire specifically states any temperature below 55 degrees will unbalance the machine causing the freezer to warm.
This is due to the fact that the thermostat that runs the entire machine is located in the fresh food section. When it reaches it's normal temperature it shuts the entire machine down.
In cold weather it could stay off for the best part of the dy, if not the entire day.
As well. on some model Frigidaire's, they makes a winterizing kit.
It is wired to the thermostat in a manner that heats the thermostat artificially in cold weather to cause it to cycle more.
Contact your local appliance parts house to see if they carry the kit for your machine.
Feb 17, 2010 | Frigidaire FRT21H8 Top Freezer...
Monogram refrigerator can't keep temperature constant
We need to look behind the rear panel in the back of the freezer and need to look at the mother board on both sides. Will need to unplug and begin. Let me know, Sea Breeze
Aug 18, 2009 | GE Profile PSW26P Stainless Steel Side by...
Upright Frigidaire freezer with warning buzzer on constantly
If your'e positive the temp is ok then your freezer cold control may be bad. Slowly turn it toward off. If the compressor doesn't cut off before it gets to off, the control is probably bad. Test it here>http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Jul 12, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Frigidaire Frig side by side making a loud buzzing noise
it sounds like the compressor, or something near it. it is generally the only moving part in a refrigerator other than the door, so would be my first guess. If it is constantly running, but staying cool in the freezer there may be a small leak somewhere or the compressor is losing power, and pumping slower.
Jun 15, 2009 | Frigidaire FRS26H5AS Side by Side...
Refrigerators Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
