Question about Epson Stylus C43SX InkJet Printer
My printer print but theres no ink coming up! but my ink is new!
Pls help me !!!!
  • Gerry Millward
    Gerry Millward May 11, 2010
    Please provide more detail. Does this apply to all colours or just one? If no ink at all comes out (black, cyan, magenta, yellow), did they all stop at once, or was the deterioration gradual. Have you tried a head cleaning cycle and nozzle check print? If so what was the result? Have you tried changing the cartridges? A response to these question will permit me to give you much more specific help.
  • 353 Answers
It looks like thraser999 has lost interest in this problem, so I think we can call it "solved by poster".
Posted on May 11, 2009
lmvp
  • 10 Answers
SOURCE: new black ink but faded
I have had the same problem and if you are in the UK phone Sansung helpline see technical support on the website and as they have done with me arrange for the optical printing unit to be replace under the warrenty - only took 2 day to arrange and it has a 3 day completion time on it - my advice if you have done around 5000 pagers of printing or less get intouch with sansung direct and ask them to replace under the warrenty- to find out all the operational information your printer is set up with
1 open the shortcut to the printer settings on the start bar
2 click printer settings
3 click the button that say 'print settings' botton right corner
hop this help and good luck
Posted on Jun 26, 2008
  • 13 Answers
SOURCE: printer not printing
find the maintance section of your print driver display ( far right of the display ) should see a maintance tab.
do a cleaning cycle or a deep cleaning cycle and see what happens. it should start printing.
if necessary make up a solid single color block on a windows word doc using the squares make them no line perimiters and do a black blue red and yellow about 1/2 inch tall and 7 inches wide
as a test pattern. the color that doesnt print is clogged
in the future try not to let the inks run completly dry before they are replaced.
if that doesn't help use isoprople alcohol 91proof on a cotton swab or clean cloth and let the print head soak in it for 5 minutes and try again.
Posted on Feb 21, 2009
  • 5 Answers
SOURCE: my cannon printer pixma ip1800 cannot detect ink pls help me...
If after you install the cartridge you get a yellow light and error message:
“The following may have run out of color. The function for
detecting the remaining ink level will be disabled since the
ink level cannot be correctly detected. If you want to
continue printing with out this function, press the printer’s
start button. Canon recommends using new genuine Canon
cartridges in order to obtain optimum quality.”
Do not click “cancel printing”. Press printer start button
to start printing. This action will bypass the ink level
detection from the recycled cartridge. It will not damage the
printer! With a recycled cartridge this action needs to be
done one time.
A full recycled cartridge ink level may not display correctly.
It may show empty.
If you want to check the ink level, you can do a “Nozzle
check” by follow the directions below:
Go to menu File select print click on “Property” click
on “Maintenance”
Click on “Nozzle check” to print out the color check.
Click on “Cartridge Alignment” to align the cartridge.
See pictures for above process at Inktelligent ip 1800 topic
Also the refills refered to above are at the IP 1800 inkfilling page
Posted on Feb 23, 2009
  • 54 Answers
SOURCE: put new ink in printer l7590 message comes up
1. Check the cartridge number is same as the L7590
2. If same, by replacing the new other ink cartridges
3. if the issue persists, then perform the below steps.
Unplug the power cord from the HP All-in-One.
Wait for 20 seconds.
Press and hold # and 3 while plugging in the power cord to the HP All-in-One.
Release the buttons after the HP All-in-One starts up.
The HP All-in-One will now be reset to factory defaults.
4. if the issue persists, then follow the below instructions.
It should resolve the issue.
Posted on Sep 03, 2009
  • 979 Answers
SOURCE: Printer has new ink but won't print black tones
Good day SIr/Maam, the path blocking the ink will not reach the paper, usually the ink travels from the ink cartride to the carrier or cradle, then to the paper. since you mention that the cartride has ink, check also the carrier of the ink, it may have dried ink on it. you need to remove the carrier and clean the dried ink. If you cant remove the carrier, bring it to your dealer, they have inhouse techs there to help you out.
Posted on Oct 26, 2009
Stripes in printing pictures in canon ip2700
Run the utility maintenance printer coming with the printer , for to clean the head from your printer.
God bless you
Jul 28, 2013 | Canon iP2700 Inkjet Photo Printer
Cannon LBP 2900 lazer printer cartridge is refilled. than it prints blank page only.
canon 2900 printer first time refilling completed but print not coming wht is problem
Sep 12, 2012 | Canon LASER SHOT LBP-2900 Printer
My printer does not print black characters although a new cartridge
pls do check the cartridge of your printer..maybe the black ink had been dry..and do pls..check and try to print again..and clean were the ink comes out.
Nov 14, 2011 | Lexmark X1195 All-In-One Printer
After changing the ink cartridges...my printer is only printing out blank pages... I tried soaking the print head in distilled water then gently wiping it off with alcohol.. the printer is working but...
Assuming you're cart. got ink in it (I had some new carts. with no ink in them once !) , soak surface of the head into hot water for about 20 sec. and test it over a cloth by gliding it. Repeat process until ink is out.
Also clean contacs on both cartridge and holder with lint free damped cloth.
Good luck.
pls. vote for better service
Nov 13, 2010 | Canon PIXMA MP530 All-In-One InkJet...
No color from the ink cartridge
hi this is kamal...
pls purchase a color cartridge new... coz ur color catridge is not working properly...
so pls go through this advice... n let me know...
best regards
kamal singh
Oct 08, 2009 | Canon i860 InkJet Photo Printer
Black ink does not print
I have a problem about my printer here. it doesnt print black color even if i replaced it with new cartridge...anyone have solution about this pls help....joy
Feb 16, 2008 | HP Photosmart C3150 Printer
We just attached the macbook to the hppsc 1350v all in one printer and new print cartridges. When attempting to print, message reads"color print cartridge not compatible with this printer". We know we have...
Just to confirm pls:
1. the new print cartridges are original HP inks;
2. you have remove the bright pink tape from the ink cartridges;
3. the black is on the right side and the color is on the left side.
You can try removing both cartridges and clean the gold colored contacts where the pink tape was. Pls do the same to the mate pins in the cartridge holder in the printer.
Try again. If this does not be corrective, you may need to change inks again.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Feb 02, 2008 | Computers & Internet
Colored Ink problem
Make sure the printer settings are set properly to print in color on the PC. Even if there is a color cartridge, if the PC only tells it to print black ink it's not going to use the color cartridge.
Jun 08, 2007 | Lexmark Color Z35 InkJet
Epson Stylus C43SX InkJet Printer Logo
104 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
