Non spinning maytag estate washer - Washing Machines
  • 296 Answers
Check the belt on the bottom of the washer. If belt is good then the motor would have to be checked.
Posted on Jan 20, 2009
LR CODE ON A NEPTUNE 55OOBWW WASHER
Hello there:
The LR error on your non-spinning Maytag Neptune is usually, thoughnot always, accompanied either by a burn spot or a blown fuse on theMotor Control Board.
Burn Spot on a Maytag Neptune Washer Motor Control Board (click to enlarge)
Blown Fuse on a Maytag Neptune Washer Motor Control Board (click to enlarge)Either way, it means just one thing: a new motor and motor control board kit are in your future.
Hop this is very helpful for you
Best regards Michael
Dec 29, 2009 | Maytag Washing Machines
Neptune - has Lr displayed where time remaining for wash usually displays. Doesn't finish.
Hello there
The LR error on your non-spinning Maytag Neptune is usually, though not always, accompanied either by a burn spot or a blown fuse on the Motor Control Board.
Blown Fuse on a Maytag Neptune Washer Motor Control Board (click to enlarge) Either way, it means just one thang: a new motor and motor control board kit are in your future.
Dec 25, 2009 | Maytag Neptune MAH5500B Front Load Washer
Whirlpool Estate etw4300sq squeaks during spin
WASHER IS FINE, SOMETIMES SQUEAKS WHEN THE TEMPERATURE CHANGES
Nov 08, 2009 | Crosley CW5000 Front Load Washer
Washer will only spin with light loads. When
I replaced the clutch and the problem seems to be fixed
May 13, 2009 | Estate TAWS800JQ Top Load Washer
Front load washer shakes violently during spin cycle
On something like this you will need to remove the washer wrap to inspect the suspension springs & base assembly. Please see the link provided for accessing the inside of the washer. Be sure the shipping pins have been removed. The tub should float freely.
Apr 03, 2009 | Washing Machines
Washing machine spin problem!!!!!
whirlpool estate washer is dun the clothes are ring Wet
Jan 13, 2009 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Estate washer won't spin
If it still agitates and fills, this is most likely due to a faulty lid switch.
Oct 12, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
WASHER WILL NOT SPIN
This is probably a timer problem. In maytag washers the motor turns in one direction to wash, the opposite direction to spin. The timer decides which direction to start the motor.
Jul 05, 2008 | Estate TAWX700JQ Top Load Washer
Maytag washer spin cycle
check the door switch for broken or damaged wires. A jumper wire across the switch ends will give you either a spinning or non-spinning washer.
Jun 20, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
