Question about Husqvarna Garden
I have a LTH1797 mower product 960410051. The clutch cable spring has rusted and snapped off. I wish to replace the cable but the ops manual and spares diagrams do not make it clear where the spring attaches. Do you have a clearer diagram or can explain simply, many thanks.
rockitman187
  • 2559 Answers
SOURCE: need drive belt diagram for LGT2654 Huskee
Here is a link to the manual on pages 7, 8, and 40,
Please take time to rate this a fixya
Posted on May 10, 2009
  • 218 Answers
SOURCE: replacing belts on sears lt4000 42 in cut?
Hi..my name is Keith..and you can go to an online lawn mower parts site...and they will have a parts diagram of the deck and drive belt..one if the sites is.. www.outdoordistributors.com ..i hope this will help
Posted on Jul 08, 2009
SOURCE: diagram for belt on mower deck of an old Roper
I think I have a diagram for this, what hp is the mower 12hp? what size cutting deck? I have an old roper 12hp which needs a new belt but don't know what size belt to buy?
My email is richy.furlong@hotmail.co.uk
Posted on Oct 06, 2009
  • 376 Answers
SOURCE: Where does the manual clutch cable mower deck
It should connect on top of the idler pulley on the idler arm. The bolt is extended and the spring hooks over it with a 'hairpin' or cotter key through the hole in the end to hold it on.
Posted on Oct 09, 2009
wadembly
  • 462 Answers
SOURCE: Bolens clutch wont engage
check to see if there is something caught around the blades that won't allow to turn
Posted on Jun 27, 2010
How do I replace deck engagement cable on mtd 760-770
if u have enough cable run it back through spring & put a small u clamp on it u can find these at wal mart parts house some hardware stores if end on spring snapped go to a mower repair shop they should be of help
Sep 21, 2014 | Mtd Garden
Yamaha tdr125 clutch lever return spring
if the lever cant be removed from the external clutch shaft then i doubt you will replace the spring unless you remove the sidecasing !
Jan 04, 2014 | Yamaha Motorcycles
Clutch cable installation
  • Put your mower in the lowest position and open the hood.
  • 2 Lift up the retainer spring that holds the clutch cable to the adjustment bracket. Pull the cable out of the bracket.
  • 3 Remove the clutch cable spring from the idler bracket. Pry the spring open with a pair of pliers if necessary.
  • 4 Hook a new clutch cable spring over the idler bracket and squeeze it closed.
  • 5 Slip the clutch cable under the retainer spring.
May 04, 2013 | Husqvarna Garden
1996 883 harley clutch replacement
You put the spring plate on first (after putting on all the clutch disks) with it being held in the compressed state. Then you insert the snap ring into the grooves in the center of the clutch. Then you can re leave the pressure of the compressed spring plate. The snap ring is used to keep the spring plate under pressure at all times in normal operation.
Dec 11, 2012 | 1993 Harley Davidson XLH Sportster 883...
My Nissan 95 sentra clutch had crunched and pedal would not spring back, found that clutch cable had snapped, replaced this and now my clutch pedal is still not 100% springing back, it springs back en
Check the spring to see if it has snapped anywhere within it's coil.
Remove the cable and check operation of the pedal and spring mechanism.
If all is well, then with a lever, check that the clutch release arm on the gearbox is operational. If that is also sticking, then you will have to remove the gearbox to investigate further.
If not sticking, then also remove the clutch cable outer sleeve, and replace.
Nov 10, 2012 | Cars & Trucks
Having trouble with the drive train on my TORO walk behind MOD. 20018
This is from a service note in shop:
"SUBJECT: Self-propelled system locks up or does not work properly. If pushed the wheels will not roll. (may be accompanied by grinding or clicking)
SITUATION: Inadequate lubrication results in the key or drive pinion sticking.
CORRECTION: Remove the drive wheel, clip ring, thrust washer, pinion, key and spring. Clean any lubricant or rust from the parts. Lubricate generously with anti-seize and reassemble.
Note: More information regarding the service of this drive system is in the Walk Power Mower Drive Systems Service Manual, Form #492-4733.
Beginning in April of 2002 Toro began making changes in their production process to ensure proper lubrication. This was done in several steps, each has improved the situation. Please remind your customers that lubrication of the wheel pinion clutch is part of normal maintenance and is covered in the owner's manual. Three to four drops of engine oil on each side of the pinion is required every 25 hours, or at least once a year.
parts for this unit can be looked up at www.arcolawn.com
good luck
Joe
Feb 10, 2011 | Garden
1972 Yamaha XS2 650 clutch is very hard to pull
Hi, Colcww and the usual suspects are:
1. Clutch cable bent, kinked, pinched, rusted or needs lubrication.
2. Hydraulic clutch hose collapsed or pinched.
3. Improper clutch adjustment.
4. Clutch plates rusted.
5. Pressure plate or springs to heavy for service.
6. Damaged clutch shell.
7. Damaged, bent, or stuck push rod assembly.
8. Faulty worm gear mechanism.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Clutch hard to pull
Clutch REALLY hard to pull in any advice please Yamaha XS650 Forum
Yamaha XS650SE Shop Manual
OEM parts for Yamaha
Yamaha XS850G Owner Manual
Jul 30, 2009 | 1972 Yamaha XS2
Craftsman 42 inch deck won't run
Check proper belt routing. These models are a little tricky. Also check tensioner spring.
May 17, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Garden Logo
107 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
