Question about HP PSC 2210 All-In-One InkJet Printer
Printer won't turn on!
I started to print something today and I noticed no power. The light was off! I checked the the wires to make sure all was connected and nothing happened.
    Genius:
  • 2,120 Answers
Probably a bad AC adapter. Buy one from www.hp.com partsurfer or eBay.
Posted on Jan 20, 2009
Continuous orange light, how to fix/ turn on the printer ?
The constant orange light is the standby indicator. Do you have the correct driver for this model? Did you select the correct printer from the list of printing devices.
In Windows, often after installing a printer driver and software you'll notice more than one printer installed. But only one has a green check mark beside it (set as default device). If that is the one you want to use, then when printing make sure you select it. If you select another and it isn't set as the default device it won't print until it is set as the new default.
Generally from Windows if you're going to need to print something, after clicking the, "Print", button from the program you want to print from, it will open the print dialogue. Make sure the default active printer is set. Most printers come with software to access other functions. Some functions include status query and a cleaning print head option as well as print sample image/text.
For Mac's a similar procedure only there is no option to select from a variety of printers. If there is a printer installed, Mac's will try to send to that device only.
Aug 30, 2015 | Office Equipment & Supplies
Hl1440 drum indicator flashing
ok turn it off take the toner out clean all the terminals put them back in make sure everything is closed properly turn the machinie back on and let me no what happenes then
Sep 12, 2008 | Brother DR-400 Replacement Drum - 20000...
The green power light keeps blinking and it won't print, it says it is not getting a connection
Thank you for using fixya.com.
The computer is not detecting your printer. Here's what you need to do:
1. Check all the connections or Reset the connection between your computer and your printer.
2. Press and hold the power button of your printer for 5 seconds to do a power cycle. The printer will turn off.
3. Turn it back on.
4. Print something.
If no go,
1. Uninstall and reinstall the driver of your printer. You can access the driver in Control Panel>Add and Remove Programs. After un installing the driver, put the disc of your printer into your computer's DVD player. Follow the onscreen instructions.
2. Print Something.
If no go, let me know by posting in this thread.
Thank you,
CARLO ADRIAN
FIxya Expert
Jun 04, 2011 | Dell A920 InkJet Printer
In the last 2 weeks my Canon MP830 printer has been printing jiberish the first time a print job was sent to it, then when resent it printed properly. Today the printer won't turn on. What can I do ?
Unfortunately these are considered disposable printers.
If it won't power on at all even in a known good power outlet there isn't much you can do as the cost to repair it out of warranty would cost more than to simply replace it.
Other than checking the power outlet and the power cable nothing else to do.
May 31, 2011 | Canon PIXMA MP830 All-In-One InkJet...
Printer wont go online - light continually flashing green to yellow...
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
PREM
May 24, 2009 | Office Equipment & Supplies
Won't print - just flashes it's lights at me!
I tried what phrek said (" Pressing the flashing buttons simultaneously, evokes the printer to spit out an internal diagnostic page ..."), but after the diagnostic page printed out the printer worked fine again.
Thanks for the help, and hopefully things work out for the rest of you as well.
Aug 06, 2008 | HP PSC 1510 All-In-One InkJet Printer
Problem
Start removing wires from the amp, one by one (except for the +12V, Ground, and remote) until the amp seems to work fine. Usually, this type of issue is due to a speaker wire shorting to something it shouldn't be touching. Check the "non-amp" end of all the wiring to make sure they are solid and correct.
Apr 04, 2008 | Volfenhag ZX-8300 Car Audio Amplifier
Printer has no Power
how long has the printer been in your family? sounds like it's starting to let you know it's on it's final episode.
Feb 19, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
The printer apear to be dead!
Buttons and lights on the printer Two buttons and three lights are located on the front of an HP Deskjet printer.
  • The lights tell when the printer is working or when it needs attention.
  • The buttons help control the printer.
Buttons and lights Purpose c00123886.jpg POWER button and light Push the POWER button to turn the printer off and on. When lit, the light shows that the printer is turned on. c00123889.jpg RESUME button and light The light blinks when there is a problem with paper. When the problem is corrected, press the button. c00123892.jpg Print cartridge light The light blinks when there is a problem with a print cartridge. When the problem is corrected and the top cover is closed, the light will stop blinking. Troubleshooting blinking printer lights Blinking lights Reason c00123895.jpg
All lights are off. The printer is off (asleep).
Press the POWER buttonc00123886.jpg to turn the printer on.
The printer should turn on automatically when a print job is sent to it. c00123898.jpg
The POWER (top) light is on. The printer is idle.
The POWER (top) light is blinking. The printer is busy printing.
Allow enough time to print. When a document has many fonts or graphics or uses complex color such as a color photo, it takes longer to begin printing. c00123902.jpg
The PRINT CARTRIDGE (bottom) light is blinking. Possible causes:
  • The front cover is open. Make sure the front cover is completely closed.
  • The print cartridge is missing. Make sure the print cartridge has been installed correctly.
  • The print cartridge is broken or incompatible. Lift the front cover, and wait for the print-cartridge cradle to slide out. Check the part numbers on the print cartridge:
Black: 51645A
Color: C1823D,
If the print cartridges are compatible and correctly installed, they may be defective. Try replacing the print cartridges.
If none of the above suggestions fix the problem, and, if the error message still occurs, it may be a hardware failure. Call the HP Customer Support Center.
Jan 20, 2008 | HP DeskJet 710c InkJet Printer
HP PSC 2210 All-In-One InkJet Printer Logo
43 people viewed this question
Seeker5211
Seeker5211
