Question about Pantech Matrix Cell Phone
Keyboard sounds I want to turn keyboard sounds off. Can you help please?
  • 1 more comment
  • tekwane Jan 24, 2009
    go to MENU then SETTINGS then PROFILES then NORMAL and hit OPTIONS and then press CUSTOMIZE scroll down to KEY VOLUME and change to desired volume and then save.
    First got to MENU then SETTINGS then PROFILES scroll to NORMAL hit OPTIONS then press CUSTOMIZE then scroll down do KEY VOLUME and then change to desired volume and then press SAVE
  • Anonymous Apr 16, 2009
    i had the same problem. i tried everything on the phone and couldnt find it. this site helped! thanks!!!! it was driving me nuts!
To turn the keyboard sounds off, first go to menu, then settings, then profiles, then normal,press options, customize, and scroll down to Key Volume and adjust sound. I hope this helps. I had the same problem!
Posted on Jan 25, 2009
Grandchildren playing on computer/keyboard and now have no sound did they turn something off?
With some multimedia keyboards, it's easy to mute or turn down the volume from the keyboard. Many Systemax systems ship with this type of keyboard. The volume controls are usually at the top of the keyboard or on the right or left side of the keyboard.
However, since there are a number of different styles of multimedia keyboards, I'm not sure which key you would need to find. Look for a key with the speaker symbol (looks like a megaphone). Also look in the bottom right corner of the computer screen for the same symbol. If there is a red circle with a line, then the mute has been enabled. Otherwise, it may be that the volume was reduced. With a mouse it's easy to change the setting; just left click on that symbol in that section of the notification bar.
In some cases, speakers do fail. So if changing the volume doesn't work, try a different set of speakers.
I hope this helps. Please add a comment with more information about your keyboard or Systemax computer model if you need additional assistance.
Nov 22, 2012 | Systemax Venture Computers & Internet
Error 210 Stuck key 69
Hello Scott,
Make sure that there are no objects placed on the keyboard, or
if you have one, the external keyboard. Turn off the computer,
and turn off all attached devices. Turn on the computer first;
then turn on the attached devices.
If an external keyboard is connected, do the following:
v Turn off the computer and disconnect the external keyboard;
then turn on the computer. Make sure that the built-in
keyboard operates correctly. If it does, have the external
keyboard serviced.
Make sure that the external keyboard is connected to the
correct connector.
Please feel free to ask me if you any further questions or concerns.
Also please rate me if you like my answer, that helps me alot.
Thanks.
Apr 19, 2012 | Lenovo ThinkPad R400 Notebook
CANNOT TURN SOUND DOWN
Your problem is tied to a GE Wireless Office keyboard and mouse. I must assume that you are trying to use the keyboard function to turn your sound down. In this case, since it is a keyboard with special functions, you need to install the drivers for the devices.
If this is not the real question you are asking, please try again under a different heading.
Jan 03, 2012 | GE Wireless Office Keyboard/Mouse HO98055
I have a korg n5 music workstation. one side of my keyboard plays fine but whe i play the other half there is no sound.help
It could be that you have a keyboard 'split' turned on but haven't allocated a voice / sound to one half of the keyboard.
See chapter 1 page 11 and chapter 3 page 27 of the manual available at the link below for a more detailed explanation
http://soundprogramming.net/manuals/Korg_N1_N5_Manual.pdf
Jan 31, 2011 | Compaq Keyboard
The sound doesn't work I placed papers on my keyboard and it turned off the sound! Please Help! Can't work without music!!!
under the clock display is a mute button un mute it by pressing it once of go to the volume icon bottom right of the task bar and unmute it from there
Sep 07, 2010 | Logitech Cordless Desktop MX3200 Laser...
I have the logitech keyboard and the sound will not work
I think you have a multimedia keyboard and you hear nothing when you try to use it or your keyboard is not working.Well if you remove the keyboard do you hear anything from the speakers?You might want to check the volume levels,make sure nothing is muted.The device you are trying to play make sure the levels are turned up.
Good luck
Mar 21, 2010 | Computers & Internet
No Sound
You didn't give any specifics. Possibly it is just broken due to a loose cable to the keyboard (which you could look inside and check) or a burned out semiconductor (harder to check).
If it is a MIDI keyboard, usually symptoms like this are due to a "MIDI Channel ID" problem. It is sending the keyboard on one MIDI channel and whatever is producing the sound is listening on another. For this sort of thing, you can substitute devices to narrow down the problem or try to reset everything, removing all the batteries, if any, and checking the manuals or website for reset instructions. Of course, you may lose stored settings that way.
Jul 01, 2009 | Music
Wireless Keyboard not connecting
I opened up the Logitech Mouse and Keyboard Settings, turned my keyboard off, changed out the batteries and turned it back on. It then detected the Keyboard and asked for a password, I entered in the password, it said it was rebooting it and asked for another password which I entered (both passwords were given to me in the Settings). Now it is working just fine! Not sure if you have tried this but it might work for you.
Jan 04, 2009 | Logitech EasyCall Desktop? Keyboard and...
Keyboard Not Working
It sounds like maybe the keyboard died if that can happen in a laptop. Or maybe a connection came loose inside the unit. Was it dropped or anything like that? Laptops are hard to repair because everything inside is very small and delicate. If it needs a keyboard replacement it won't be cheap. Maybe a driver got turned off somehow. Look in the BIOS and the device manager to check that. Hopefully it is that simple. You could always carry an external keyboard around with you which would kind of defeat the purpose of having a laptop in the first place. I've seen these flexible roll-up keyboards that aren't too big. That might be an option.
Dec 17, 2008 | IBM ThinkCentre M52 8113 - P4 551 3.4 GHz...
Play casio keyboard through midi and acer laptop
Update your usb driver, make sure you have the latest miditzet driver, check your connections, and make sur sure you get all this for the operating system you are using. This should help.
Good Luck
Fehdi
Jul 09, 2008 | Computers & Internet
Pantech Matrix  Cell Phone Logo
172 people viewed this question
Top Pantech Cell Phones Experts
Computer Repairing
Computer Repairing
Jax Planet
Jax Planet
Abdul Mannan
Abdul Mannan
Are you a Pantech Cell Phone Expert? Answer questions, earn points and help others
