Question about Refrigerators
Voltas fridge compressor relay dfc1 wiring diagram
2 Suggested Answers
  • 1144 Answers
SOURCE: Need wiring diagram for GE model CA15DRN upright
http://genet.geappliances.com/DocSearch/pdf/49-6545.PDF
The best I could come up with is this site for the user manual. Not able to find wiring diagram on this GE site. Hope this helps ya.
Posted on Nov 29, 2009
Looking for the wiring diagram for a UR30G fridge
Just because the compressor checked out okay doesn't mean that the overload and relay doesn't need to be replaced it also could mean that the compressor is mechanically defective I would try by installing a URCO810RC 4n1 relay kit. It is all you need no sense in wasting money on new parts if your refrigerator does not have the run capacitor do not install the one that comes with the kit
Supco
Aug 30, 2016 | Carrier Beverage-Air UR30GEFD Beverage...
Voltas ac
have a fridge mechanic check the capacitor for the motor if it is external
May 25, 2013 | Refrigerators
My maytag fridge pbt1953grw has a problem when the compresspr goes to kick in it just clicks and humms then clicks off i jumped the orange and white wire and the compressor comes on only for 3 sec then...
Hi!
A relay starts the compressor with a higher voltage and then quickly kicks out
It does a lot of clicking (trying to start over and over again)
If thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
I use part no ERP410 POWER START RELAY, CAPACITOR AND OVERLOAD all in one. (110 v)
If you still have trouble Go Here:
http://www.applianceaid.com/procedures.html
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Sep 22, 2011 | Maytag PTB1953G Top Freezer Refrigerator
Not sure how to wire Supco RO41 Relay/Overload Combo to Maytag side by side Fridge MSD2454GRW. It's a universal part, so it's different than the manufacturer's part, but I just want to see if...
while i loath those RO41 because your compressor will be dead SOON. The 2 black wires connect to the wires were connected to the wiring on FACTORY RELAY AND OVERLOAD WHICH WAS ORIGINALLY CONNECTED TO WHERE THE RED/WHITE/AND BLACK WIRES WITH THE TERMINALS NOW ARE.
my advice though is throw that thing in the trash and get factory OEM relay and overload
Aug 17, 2011 | Refrigerators
Kelvinator 401 Impression series. Oldie but a goodie until I switched it off for 6 weeks while on holidays. Switched it back on and now fridge area freezing. Tried switching up overnight (8-10) hrs and...
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
The cold control is the knob in the ref that turns it on and off and has numbers on it.
If it runs then that cold control is the problem.
If this doesn't work Do this
That is probably the compressor relay or cold control (Thermostat
The relay is on the compressor and needs replaced
Thats what is happening with yours
also try hooking the two wires together on the cold control to route around the cold control.
If you need more help GO HERE:
Leo Ponder
Aug 16, 2011 | Kelvinator Refrigerators
Fridge seems to work but blows warm air. Is it possible the capacitor if faulty and if so how do I check it. Could the fridge need to be re-charged?
Hi!
Leo Ponder
Aug 11, 2011 | Danby DFF9102BLS Top Freezer Refrigerator
My copressor won't start. relay works fine in
HAVE YOU TRY A 3-N-1 COMPRESSOR BOOSTER|? YOUR LOCAL APPLIANCE PARTS STORE SHOULD HAVE THEM. TELL THEM THE SIZE OF YOUR FRIDGE AND COMPRESSOR AND THEY SHOULD BE ABLE GIVE YOU THE RIGHT ONE. FOLLOW THE INSTRUCTIONS ON THE 3-N-1 AND CONNECT TO THE COMPRESSORS. BUT CONNECT THE TWO BLACK WIRES TO A EXTERNAL POWER(GET AN EXTENSION CORD AND CUT IT, WIRE NUT THE TWO WIRES TOGETHER). PLUG IT IN, IF THE COMPRESSOR KICKS OFF, YOU HAVE A BAD COMPRESSOR. IF IT RUNS WITHOUT KICKING OFF, THAT MEANS YOU ARE NOT GETTING POWER TO THE OVERLOAD RELAY TO TURN KICK ON COMPRESSOR. CHECK YOUR TEMP CONTROL INSIDE FRIDGE, AND THE DEFROST TIMER(MIGHT BE STUCK IN DEFROST)
Jan 24, 2010 | Amana Freezers
I NED TO CONECT 3-1 RELAY OVERLOAD CAPACITOR IN MI FRIDGE
first take all the relays and capacitor off of compressor , then attach black wire with terminal on "C" terminal post usually top terminal, white wire with terminal goes on "S" terminal post on compressor, red wire with terminal goes on "R" terminal post on compressor. then take the two black wires one connects to white neutral wire and the other connects to the black power wire if tis fridge has a condensor fan then you will also need to connect it two the two black wires also thanks hope this helps
Jan 23, 2009 | Kenmore 50522 / 50524 Side by Side...
Candy cpca240ffk compressor running.
i don't have a diagram but im familiar with that problem its either a bad relay on the compressor a bad thermal over load in the relay box mounted on the compressor terminals or a bad compressor don't know where you live im in usa here you can get an after market relay with a start capacitor and if its not the compressor will fix the problem
Jan 10, 2008 | Candy CPCA240FFK Bottom Freezer...
After defrosting the freezer the whole fridge doesn't work (is warm!)
sounds like the compressor is locked up or the relay on the compressor is bad. whats happening is its drawing too much current and cutting out from the overlaod relay. that may be a bad compressor or the start relay. both the overload and the relay are under the black box on the front of the compressor. you will need to check the relay to make sure its good, and also the compressor. there should be a wiring diagram on the back that will tell you how many ohms from terminal to terminal on the compressor. hope it helped if its a newer unit the relays are electronic and if you shake it and hear like little sand pebbles in it most likley its bad and thats why it wont run.
Aug 10, 2007 | Danby DCR34 Compact Refrigerator
Refrigerators Logo
143 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
