Right channel not working denon dra-335r - Audio Players & Recorders
  • 395 Answers
SOURCE: right channel not working
check the pre out /main in jumper there should be a loop jumper for both left and right. if you are using a graphic EQ check the wires connecting to the receiver and the EQ. also is this happening on all sources?
Posted on Feb 07, 2008
  • 4234 Answers
SOURCE: No Power
There is a thermal fuse built into the main transformer. It is possible that the fuse is open.
Dan
Posted on Mar 30, 2009
SOURCE: looking for Denon dra 1025r Service &/or user manual
I have a Denon Dra-1025R operating instruction book,if this what you need and I can offer some info let me know
Posted on Sep 21, 2009
SOURCE: Denon DRA-335R turns off or changes the source or radio station
I have the exact same problem with my Denon 1600 receiver. I bought the receiver 3 weeks ago and I've been trying to solve this problem ever since. The guys in the "Magnolia" room at Best Buy said it might be a defective receiver, or maybe the receiver is not compatible with my Brighthouse cable box. I think I might swap out the receiver this weekend to see if that solves the problem.
Posted on Dec 10, 2009
  • 4234 Answers
SOURCE: Loud distortion through phono inputs
Phono inputs are designed for turntables only. Any other device will provide too high a signal for that input to handle. The phono input has an extra amplification stage built in. The distortion is because of the high suignal level being supplied to the input. The only way to get this to work properly is to purchase an antenuator which will decrease the signal level to the phono level.
Dan
Posted on Dec 18, 2009
Dan
Dec 18, 2009 | Denon Audio Players & Recorders
Sep 26, 2009 | Denon AVR-1600 Receiver
Hi all i have a Denon DRA 455 with Eltax Linear 6.5 wich is 8ohms i have a sub but no sub output, apart from sharing power between them, how can i hook these up please? thanks
You did not state if your sub is a powered sub or not, but if you use the "B" channel for your sub, it should work. This is possible if the denon will work with "A" channel and 'B" channel on together. The back of the Denon should have two sets of speaker outputs. Connect the "B" channel speaker outputs to the sub. The "A" channel will still drive your 6.5's.
Aug 05, 2009 | Audio Players & Recorders
No Power
Dan
Mar 30, 2009 | Denon DRA-365R Receiver
Receiver cuts inself off about 15 seconds after you turn it on
you need to check your speakers connections to make sure nothing is touching and all is connected right and not to have to many spkrs on the channels, also only have the skrs on that you are using, make sure zone 2 / 3 are off and multi volm is turned down
Feb 01, 2009 | Denon DRA-395 Receiver
Denon DRA 335R changes from tuner to phono by itself or turns off by itself
Hi
One thing that may help you with the problem is to power the amp right down by disconnecting from the wall socket, and then power up again 30 mins later. This will allow for a complete reset of the microprocessor stages of the unit. Try this and let me know how you get on. If the problem does not go away, happy to talk to you more about it.
regards
robotek
Nov 09, 2008 | Denon AVR-1600 Receiver
Hi....you may want to check the speaker fuse, located on the rear of the unit.. sometimes too small wattage speakers get hooked up and the speaker fuse will blow as to not hurt the speakers.
Hope this helps.
Squipps
Feb 07, 2008 | Denon DRA-685 Receiver
 Grubhead
Grubhead
