Question about Kitchen Ranges
Loose door hinge on waterford stanley electric oven
5 Suggested Answers
  • 1314 Answers
SOURCE: Oven Door Hinge is broken Kitchenaid KERC507 range
at about any appliance parts store in you area you just need your model and serial number there are links on this site kitchenaide is made by whirlpool so they can help or if you want to do it online this is good http://www.repairclinic.com/SmartSearch/smartsearch.aspx
Posted on Jun 20, 2008
SOURCE: cant get whirlpool electric oven door hinges back on
Pull the hinges out and there should be a hole in it to where you can slide a nail or a screw through to hold the hinge open so you can put it back on
Information is here: http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%203196274.pdf
Posted on Apr 03, 2009
jumptrout51
  • 3361 Answers
SOURCE: hinge, oven door #822144
Pull up on the door to remove it from the hinges.
Remove the pan drawer on the bottom. Remove the spring from the hinge to be replaced. Remove the hinge mounting screws. Remove the hinge.
Reverse this process to install the new hinge.
Posted on Jan 06, 2010
SOURCE: replacing the oven door to the Whirlpool electric range RF375PXE
There is a hole in the hinge, for placing a pin, to hold fully open. Two man job. One forces the hinge into the fully open position; the second inserts the pin (nail) into the hole.
Posted on Jan 19, 2010
Eletrolux wall oven modelE30ew7cgps2 change door hinges
The hinges mount inside the oven door, open the door all the way, then move the small clips that are riveted to the hinge to the position opposite of where they sit now... this will hold the hinge springs open. Lift up the door as if to close it, then the hinges will lift out of their slots and you can remove the door... Electrolux Range Stove Oven Door Hinge 318244305
Jun 24, 2016 | Electrolux 30" Built-In Single Electric...
Why does the oven door on a 20" Danby stove "bump" as it closes?
check the hinges are not loose or damaged. the door isnt hitting the striker pin is it when you close the door.
May 21, 2014 | Danby DER2009W 20" Freestanding Electric...
Door to oven does not close completely - how do I access the door hinge to check or replace it?
Open oven door. Flip metal holder down at hinge to lock hinge. Lift door with hinge attached up slightly and off oven. Reverse to re-install door, making sure notch at bottom of hinge is hooked in frame of oven properly.
Jan 02, 2011 | GE JTP45 Electric Double Oven
Oven takes forever to heat up - its a thermador double oven - me272
Hello- Check these things first-  Door seals tend to get stiff over time. This is normal. Door hinges can become loose or get bent a bit, causing door to not close tight. This little gap can allow heat to escape, causing extended pre-heat times and frequent cycling of elements. If door doesn't seem to pull shut tightly- hinges will need to be replaced. If oven appears to operate normally otherwise, this should solve problem.  Let me know if the info helps- have more if needed- Thanks  - Ed
Mar 17, 2010 | Thermador C272 Electric Double Oven
Our Bosch electric oven is 5 years old. We
Either you have not refitted the door back correctly, or the door hinge springs are weak, a common problem.
This being the case, then the only solution is to replace door hinges.
Feb 11, 2010 | Bosch Ovens
Door hinge on hygena single electric oven broken
You neede to replace both door hinges.
To get more detailed instructions on how to do this, go to the following site.
WWW.YOUTUBE.CO.UK
In the search box enter FITTING OVEN DOOR HINGES.
You should then click on the appropiate link, and follow the instructions.
Please rate my solution.
Thankyou.
Feb 03, 2010 | Ovens
Bosch Oven Door Problem - doesn't close at top
On our oven (Bosch Evolution 700 Series HGS7152UC), the problem was getting worse and worse. I found it is was worsening simply because the hinges had started to come loose. I removed the door as suggested above, and although there are no adjustment screws on this model I tightened the now-loose hinge mounting screws. For each hinge there are three screws altogether: two (phillips heads) on the bottom of the door and one (torx head) on the inside wall of the door. After tightening those screws it is a lot better, only leaks as much heat as it did when it was new which is tolerable. Still a bad design.
Mar 02, 2009 | Bosch HBL 742 / HBL 746 Electric Single...
Belling oven door not closing fully
Hi. Yes, you will need to replace hinges, and possibly the hinge guides located inside the cookere.
Oct 17, 2008 | Belling XOU252 Electric Single Oven
Main oven door will not close properly. Is there any adjustment for it.
This comment applies to most electric ovens that have drop down doors with hinges at the bottom.
The hinges are not adjustable, and in every case the problem is caused by one or both hinge springs being weak.
The only solution, is to replace both oven door hinges together.
May 06, 2008 | Neff U1421 Double circotherm Electric Oven
Kitchen Ranges Logo
59 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
