Question about Riccar 3623210300 RC 1700, 1800 Full Size Canister Electric Suction Hose
I have the Riccar Starbright canister vacuum. I have replaced the bag and filter, however it will not work. All of the indicator lights are on and should be vacuuming, but nothing. This has
SOURCE: riccar 8750
I have an 8625 and the button is now white not red. Probably fadded. Thanks that was the reset button and it solved my problem.
Posted on Apr 19, 2008
SOURCE: reset button on riccar upright vacuum
I CANT SEEN TO GET THE TOP TANK TO SNAP BACK IN, IT KEEPS SPILLING THE WATER AND SOLUTION
Posted on Dec 21, 2008
SOURCE: Lost suction after I changed the bag and cleaned the air filter
The bag has a cardboard collar with latex. It must seal over the inlet. Make sure not to tear the bag when replacing.
Is the cover closing properly? The cover seals against a gasket. The same with the filter.
Posted on May 21, 2009
  • 95 Answers
SOURCE: my riccar vacuum does not pick up anything
Check the belt and then the tube on the side of the vacuum that runs from the bottom to up the side to the bag. If they belt is broken the vacuum will not pick anything up. If that tube is clogged up with dirt that will keep the vacuum from picking up as well.
Posted on Oct 21, 2009
SOURCE: When I plugged in my Riccar Vacuum cleaner - it
check the cord where it goes into the machine on back. most likely blew out at machine
Posted on Dec 30, 2009
Is there a reset button
The reset button is internal. If it overheats it will shut off but will come back on when it cools down. This usually means you have a clog somewhere or a clogged bag or filter. If that doesn't take care of it have it checked by your Riccar dealer.
Mar 30, 2014 | Riccar 1500. 1700, 1800, Pristine,...
Riccar 8850 red light is on and won't go off, I changed the bag but do not know what the light indicates
The light indicates a restriction, a full bag or clog or something restricting the airflow
Dec 15, 2013 | Riccar Vacuums
No suction in hose
There is most likely something stuck in the hose.
Jun 06, 2013 | Riccar Model RC1100 Canister Vacuum...
Why does the check bag light come on when the bag is new on my riccar vacuum?
The light is indicating an obstruction somewhere. It is most likely in the hose or the suction tube the hose inserts into.
Mar 16, 2012 | Riccar Vacuums
Stopped running. Filter was clogged. Cleaned filter and changed bag, but still won't start. Motor was warm when it stopped.
Hi There,
This sounds like the Thermal Switch in your motor tripped. All Riccar vacuum cleaners have a motor reset switch, that will shut the motor down when it gets hot. Usually it's caused by a full bag, clog, or dirty filter.
Try resetting the thermal switch first. If this doesn't work, you may have done some more serious damage to the motor, and it might be a good idea to take it into a local Riccar dealer in your area.
Here's a step by step guide on how to check the reset switch on your Riccar 8850:
To reset the thermal fuse:
  1. Unplug the vacuum cleaner
  2. Check for problem – over–filled bag, clog in hose, clogged filters, etc.
Remove the vacuum bag, and see if you can visibly see any obstructions, or replace the bag if it's full:
Also inspect the Secondary filter while you have the vacuum bag removed from the machine. If the filter is clogged or dirty, rinse under warm water, and air dry completely before reinstalling it into the vacuum. It's best to wash this filter every 30 days, and replace after 4-5 washings.
Here's a link to the secondary filter on our website if you ever need to purchase one:
Riccar 8800 Series Secondary Filter
Your Riccar 8850 also has a set of exhaust filters that are on the front of the vacuum, near the bottom where the upright body meets the agitator housing. These filters when clogged may also cause the thermal switch to trip. These filters are recommended to be replaced every 6-12 months, and are not recommended to be washed.
Here's a link to 2 sets of the exhaust filters for the Riccar 8850 on our website:
Riccar 8850 Exhaust Final Filters, 2 Sets, 4 Total Filters
It's also possible that you may have clog in the suction port inside of the agitator housing. Remove the bottom plate from the vacuum, and look for the tube that runs on the left hand side from the tray to the rear of the agitator housing. Make sure that this tube is clear from obstructions:
Locate "tripped" fuse – the small white button located on the bottom of the back side of
the main body (roughly one inch to the right of the left wheel)
Using a pencil, paper clip or other pointed object, push the reset button in, you should hear a clicking noise when it resets.
Plug the vacuum cleaner back into the wall, and try turning the vacuum on. It should come right back on. If not, it's best to take your machine into a local Riccar authorized repair facility for further more advanced diagnosing.
Please feel free to ask any follow up questions by adding a comment to this repair, I'm always more then happy to answer any and all follow up questions if you need some clarification. If this was helpful, please rate the repair helpful or leave some feedback for me. Thanks so much,
Chris Jones
Govacuum.com
May 22, 2010 | Riccar 8850 Vacuum
My Riccar 8850 stopped running. Changed the bag and cleared all hoses. Light comes on but the motor doesn't operate. I can turn the brush freely by hand.
Greetings from GoVacuum,
If the light on your Riccar 8850 is coming on, but the motor is not coming on, this indicates that your motor has gone bad. There is a reset switch on the back of the vacuum cleaner that sometimes trips if the bag is too full, or the filters are not maintained, but when this happens nothing on the vacuum comes on including the headlight. If the headlight is coming on, this indicates that electricity is making it down to the headlight, and the current is going through, but just not activating the motor. This is a tell tale sign of your motor being bad, and needing replacement. You can purchase the motor for the Riccar 8850 (12 AMP, 2 stage motor, Riccar part D113-1700 $122.44) from GoVacuum by giving us a call, as we don't yet have this part on our website.
I hope this helped you. We have been fixing Riccar's for over 30 years, and they are great vacuum cleaners, and the age of the model 8850 is probably the life expectancy of this vacuum cleaner.
Chris Jones
GoVacuum.com
Mar 18, 2010 | Riccar 8850 Vacuum
Where can I get replacement wheels?
Greetings from GoVacuum.com,
I just wanted to let you know that we are an authorized Riccar dealer, and we can certainly get the replacement wheels for your Riccar 4812 upright vacuum cleaner.
We stock some parts, and what we don't stock we'll order for you. We don't currently have the wheels on our site, but if you still need the wheels, you may email me at chris.jones@govacuum.com.
We do stock a lot of parts for your 4812 Riccar, including the following;
Riccar 4000 Series Bags That Fit the 4812. Paper Bags 12pk.
http://www.govacuum.com/ricc103.html
Riccar 4000 Series Exhaust Filters for the 4812 Part RF4-2;
http://www.govacuum.com/ricc117.html
Riccar 4000 / 8000 Series Drive Belts Part # A20-R2P
http://www.govacuum.com/ricc112.html
Foam Filter Underneath of Bag Riccar 4812 Part B622-0500
http://www.govacuum.com/ricc133.html
I look forward to helping you if you still need to get the wheels for your vacuum.
Thank you,
Chris J.
GoVacuum.com
Jan 11, 2010 | Riccar 4812 Vacuum
May 20, 2009 | Riccar 8955 Upright Vacuum
Performance indicator light
check to make sure the bag isn't being sucked into the air filter. open the access door where the bag is and you'll see the air filter at the bottom. to check, leave the door open while you would see the performance indicator light on, and then pull up the bag. this is one of many solutions i'm sure to the performance indicator problem.
Oct 17, 2007 | Kenmore 23913 Progressive PowerMate Bagged...
Riccar 3623210300 RC 1700, 1800 Full Size Canister Electric Suction Hose Logo
32 people viewed this question
Top Riccar Vacuums Experts
quennie732
ka4iup
ka4iup
Are you a Riccar Vacuum Expert? Answer questions, earn points and help others
