Question about Dell Inspiron E1505 Notebook
Picture viewing from memory card
Oh welll
  • xiller8er
    xiller8er May 11, 2010
    Have you ever Reinstalled WindowsXP on your laptop, or know if a previous user (if any) has done so?
    I also Recommend You getting this Update From Dell. (if you haven't already.)
    And Running windows update can also help (sometimes) in fixing this type of problem.
    I'm currently Determined to help you Fix this Problem.
  • xiller8er
    See My Request@ your Post
Card locked shows of view finder, cannot take a picture it shows a't picture but won't take a picture
Look at the memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Dec 06, 2012 | Canon PowerShot S2 IS Digital Camera
I have put my m2 memory card in memory reader then plug the memory reader in usb slot at my pc ( windows 7 os ) but it says system cant install driver for this . and when i gio to device manager there is a...
Check it in other computers. If it works welll then you have install driver in your system. Although now a days drivers comes automatically installed, sometimes it causes problem. Or you can go to sandisk site and get the driver.
Sep 17, 2011 | SanDisk 2GB Memory Stick Micro M2 Memory...
I have pics saved on internal memory and need to transfer to memory card. how do I do this?
-Turn On camera
-press Menu and go to setup
-Under setup look for Choose image storage and switch to internal Memory
-Now if your image storage set into Internal memory, Press menu again to exit menu settings
-Press review button for you to able to see picture from internal Memory
-now Press menu again while viewing the slected picture that you want to transffer
-It will provide option PICTURE/ALL/EXIT
-If you want to transffer all the picture select all
-If you want to trnasffer selected picture select picture.
Note: You need to set your Image storage into AUTO so you can use your memory card to take and view picture
Nov 09, 2009 | Kodak EasyShare DX4330 Digital Camera
My memory card is in my camera, but when it takes a picture and i put my memory card in the computer to view the pics, there's nothing on the memory card. what's wrong
A few things... Make sure that the card is the one recommended for the camera. Can you play back a picture which you have taken? That needs to be checked first. Put the card in the camera, take a picture then view it on the camera's LCD. If you can see pictures, then some thing is wrong on the computer and the way it is reading the card.
Oct 21, 2009 | Bushnell Trail Sentry 11-9200 Digital...
I have a nikon coolpix L20 and HP memory card.
hey you can put your photos from your camera to your computer and view it directly but if you want to do the vice versa(i.e computer to camera) if you just like that copy the photos from your computer and paste them in your device's memeory then you cannot view them . instead you have to install the picture package transfer from your installation cd(may be a different name for nikon software) and then connect your camera via usb. open the software you installed then you should transfer the photos to camera from computer via the software only. this happens because your camera is an embedded system and its not a computer.for your information hp and nikon have nothing to do with this issue..
Jun 25, 2009 | Nikon COOLPIX S51 Digital Camera
How to transfer internal images to sd card?
Put memory card in camera, power up, go to menu and find copy option, select it and press ok.
That will copy picture files from internal memory to memory card.
Jun 17, 2009 | Fuji FinePix Z10fd Digital Camera
When viewing picture from camera question mark appear no picture
try formatting ur memory card sometimes after adding deleting pics it gets corrupted or becomes in such a format that is hard for a camera to show u , becoz sometimes u use ur memory card on card readers and then edit them there so they are unable to be read in camera try formatting the card temme if it helps
Feb 20, 2009 | Canon PowerShot A700 Digital Camera
Sandisk 4gb memory card w/adapters
oh! too sorry for that..you have formatted your card and you cannot put the files back.. but after you have formatted it is the problem had been solved?
Feb 23, 2008 | SanDisk Memory Media
Motorola L7 media player?
the format is .3gp or Mp4...but it is better to use the .3gp it compression is way smaller than the .mp4.
Jan 11, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Dell Inspiron E1505 Notebook Logo
32 people viewed this question
Alun Cox
