Question about Proform 725 Fp Treadmill Drive Motor
My pro form 725 FP treadmill won't come on with key. some of the lights are on without the key being in and can't turn on at all.
  • 14 Answers
SOURCE: Pro-Form Sport 1000 treadmill does not stop inclining
Do a Calibration on the treadmill. Take out the safety key. With 2 fingers, hold down the stop button and the speed up or spped plus button. keep holding them down as you insert the safety key, then let go of both.
Press the stop button 1 time, you should see all 0's in the windows, or EP 2P or something weird like that.
Press the Incline up button and then wait. If the incline go up until it stalls then down until it stalls the stops at the bottom, the you are recalibrated, take out the safery key and put it back in to see if all is well. If the incline takes off up again without touching a button, the you have wiring problems or control problems. Call service company to get it repaired.
Posted on Apr 29, 2009
SOURCE: pro form service manual?
Please type in your model number on this page to get the free downloadable manual:
http://www.iconservice.com/proform/manuals.html
Hope this is helpful
Posted on Sep 12, 2009
SOURCE: Pro Form treadmill display lights up but the
Check out The treadmill Doc. Fantastic site and great people to do business with. A lot of helpful trouble shooting information for free! I'm betting it is the motor control board. Site will lead you through step by step instructions to check and fix it yourself. I saved a ton of money and with a little know how and good information you can too.
Posted on Dec 16, 2009
SOURCE: I plugged in my Pro-Form 730cs treadmill and it won't start.
My i FIT treadmill won't turn on. Is there a reset button somewhere?
Posted on Apr 26, 2010
bwinton
  • 83 Answers
SOURCE: treadmill seems to slip while running,
To tighten the belt, start by locating the two bolts that adjust the rear roller (one on each side of the unit in the back). Run the unit at about 3 mph. Tighten the bolts a 1/4 turn at a time. Make sure that what you do to one side, you MUST do to the other side or the belt will get off center. After you tighten it 1/4 turn, check the belt to see if it is still slipping. If it is then tighten the belt 1/4 turn again. Continue until the belt does not slip, but do not tighten the bolts more than 2 full turns.
Posted on Apr 30, 2010
My Pro Form 725 X treadmill won't turn on at all. Any ideas what it could be?
Hi There, if the console doesn't power up, there is a problem with teh motor control board, or MCB, as this board provides power to the upper console. There are some fuses on this board, but please beware of open fuses, as something "pulled" them open in the first place. For those talking about the 2-board set, these boards are known to have issues with teh drive motor heating and cutting out the temp sensors. You can contact jatinah electronics for further help.
Jan 13, 2015 | Exercise & Fitness
I have a pro form 725 can't see the other letters
please see the video and fix it.
God bless you
May 23, 2013 | Exercise & Fitness
My pro form 580 si won't reach max speed. Why is
Dear Sir:
Adjust the speed sensor very weel see the diagram attached, tigh the connector wires very well, and clean the s. sensor very well.
2) Run the software calibration for easy diagnose , fix it, and trouble.according with your manual instructions.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua.
Apr 03, 2012 | Proform Exercise & Fitness
Is it possible to operate a Nordic track A2550 treadmill without the key? If so, how?
First thing I'd try is just using any magnet. I'm sure that's all the key is normally. If that doesn't work, no you cannot use a treadmill without a key. It's a safety measure created by the company.
Here's the key for sale on amazon that goes to your treadmill.
http://www.amazon.com/Pro-Form-Treadmill-Safety-Key/dp/B002YP4KQE
Hope this helped!
Jun 18, 2011 | Exercise & Fitness
My Pro-form 980 CS will not start. I plug the key
Press the Stop and the Speed Up keys down while inserting the safety key. This should get you into calibration mode. Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test. If you cannot get into calibration or if the EPROM test fails then the upper console will have to be replaced.
If you get pass to this point then proceed with the calibrating the incline and speed.
Press either incline key and the incline will calibrate automatically.
Be careful the treadmill will run at full speed in the next mode DO NOT STAND ON THE WALKING BELT.Press the Speed Up key and hold it down until 85 is shown in the Distance window (some models may show the 85 number in another window).
If the top speed of the treadmill does not match the displayed speed on the computer console, adjust the max speed potentiometer (pot) on the motor control board. This is the board that the red and black motor wires connect directly into in the motor area. The Max Speed pot is clearly labeled
The max speed potentiometer is a small square with a mobile center and is located in one corner of the board and is labeled MAX SPD. It is near the harness that carries the speed signal labeled H,W,L. Using a small insulated screwdriver adjust this potentiometer clockwise to speed up and counter-clockwise to slow down the max speed of the treadmill. A tiny turn of this potentiometer will make a big difference in speed so be careful when making adjustments.
It is not important to get the speed set exactly at the max speed of the treadmill but do make sure to get the speed within .2 MPH of the max speed of the treadmill. For instance if the max speed of the treadmill is 10 MPH, make sure to have the speed set between 9.8 MPH and 10.2 MPH. Some models have a 12 MPH top speed, so please check your manual if you aren’t sure.
After completing calibration of the speed, press the Speed Down key. The treadmill will automatically return to 0 MPH. Please allow the unit to stop completely before continuing. Press the Stop key once and remove the safety key.
Jun 12, 2010 | Proform 980 CS Treadmill
My treadmill turns on but will not start showing fp
press the Stop key and then remove the safety key this should get you out of the calibration mode.
May 14, 2010 | Proform Crosswalk 500 Treadmill
I have a pro form performance j4 treadmill. i
It is just plastic. You can wedge a piece into the slot
Dec 22, 2009 | Exercise & Fitness
Aug 28, 2009 | Proform Quick Burn Pro Treadmill with 12...
Apr 27, 2009 | Proform Sport 1000 Folding Treadmill...
Proform 725 Fp Treadmill Drive Motor Logo
130 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
