Question about Trendnet TEW 652BRP Wireless N Home Router (710931600599)
My Trendnet TEW 652BRP router keeps kicking me off the internet. I usually unplug the power and then plug it back in and it will work, but only for periodic amounts of time, sometimes a half hour and sometimes 2-3 hours and then kicks itself out again? Any solutions??
4 Suggested Answers
puertobori
  • 7733 Answers
SOURCE: trendnet tew-652brp username: admin password: admin Computer
Just reset it! At the back of the router is a small hole.With a toothpick or some like press gently for 30 seconds and wait for the router to start up again.Log in to http://192.xxx.xxx and start a new configuration.
Ifyou need more help come back.
Post/ thumbs / testimonial are welcome!
Posted on Dec 27, 2010
puertobori
  • 7733 Answers
SOURCE: How to reset Trendnet TEW 652BRP Wireless N Home
In order to get your router back to the original settings, you must push in the reset button (usually on the back of the router) for somewhere between 10 and 30 seconds depending on the router. You may need a pin or something small to push in the button, because it can be recessed. Once you have reset the router, the username and password will be changed to the defaults, admin and password, respectively. One thing you must remember is that resetting the router will change all of the router settings back to the factory settings. This means you will lose all of the changes you made since you got the router. Make sure to write down any things you've changed, so you can change them back after the reset. Also, I recommend updating to the latest firmware after the reset.
There a great article at General Router Setup.
If you need more help post back!
Thumbs and testimonial are welcome!
Posted on Feb 12, 2011
  • 18 Answers
SOURCE: how can i connect a
depending on what you are doing with the two devices, there are a bunch of different answers. usually connecting two like devices requires a crossover cable. This is different from the traditional straight-through cables that you can buy at walmart. but for simplicity sake, use a crossover cable
Posted on May 09, 2011
Pin for trendnet tew 652brp wireless n home router
Is it a password? May be try the default password Or you can try 'reseting' the router. Beware, that resetting removes all settings and shift it to factory defaults
Apr 07, 2014 | Trendnet TEW 652BRP Wireless N Home Router...
WAN light keeps blinking on my Wireless N Home Router and I cannot access the internet although I can access the router config page. This started just yesterday and before that the WAN light used to be...
How old is the device? May be time for a new device? Has there been any electrical storms? Power surges? Tried different connecting cables? When you reset the device, hold reset for 30 secs., release, wait for selftest, unplug device for 30 secs., plug in, wait for selftest, connect with a Ethernet cable, reconfigure SSID and Security Key.
Apr 28, 2013 | Trendnet TEW 652BRP Wireless N Home Router...
I cant get my xbox to conect to the internet through this router. what should i do?
You have several options.
Home Wireless Routers - They DMZ and a Virtual Server / Port Forwarding. Go to Port Forward dot com for exact settings on your model. Use the free instructions.
Jan 08, 2013 | Trendnet TEW 652BRP Wireless N Home Router...
How can i connect a trendnet (tew-652brp) 300mbps wireless router on aevdo wireless modem
May 09, 2011 | Trendnet TEW652BRP 300 Mbps WiFi N router...
How to reset Trendnet TEW 652BRP Wireless N Home Router
Feb 12, 2011 | Trendnet TEW 652BRP Wireless N Home Router...
Can't connect apple iphone or sony vaio laptop to trendnet tew-652brp wireless router
Have you run the "Wireless Networking Setup Wizard", to configure the router, and to set an SSID, an encryption-level, and to set a password? If not, do it, and then use those settings on your iPhone & on your laptop.
Sep 18, 2010 | Trendware TEW-652BRP Router
Trendnet losing signal all the time. No idea why?
my suggestions is replace it..its damage already
Jun 24, 2010 | Trendware TEW-652BRP Router
Cant connect to internet, icon shows as internet
Just unplug the router for 10 full seconds from plug-in, then plug it back in, wait a couple minutes, and try connection again.
Feb 20, 2010 | Trendware TEW-652BRP Router
I am trying to set up a wireless network. Trendnet TEW-652BRP router. Book says to go to 192.168.10.1? I get INternet Explorer cannot display them webpage. i went to run>cmd ping 192.168.10.1 Request...
open up command prompt (run--> cmd) and type in "ipconfig" (without quotes). Look for the folowing: Default Gateway: 192.168.something.something Open up internet explorer and go to that 192.168.something.something instead of going to 192.168.10.1
You should be able to finish configuration from here. Also, you have to be connected to the router, either wirelessly or with a cable in order to access the settings, double check your connection.
Good luck
Dec 28, 2009 | Trendware TEW-652BRP Router
Slow internet connection
Sometimes ISPs (Internet Service Providers) upgrade information on their end to improve or alter something about their network. When this happens, routers have outdated information from the modem. You might want to try power cycling the modem and router. To do this, unplug the power from both the router and modem. After about 15-30 seconds, plug the modem back in. Wait for all of the lights to come on excluding the "PC Activity" light if it exists. Once the modem is registered with your ISP, plug your router back in and test your net speed using a site such as:
http://www.speedtest.net
If your service is back to normal, then you're all set. If it isn't, you may want to contact your ISP as there could be something wrong with the route traffic is taking from the node to your residence.
Mar 05, 2009 | Trendware TRENDnet TEW-452BRP 108Mbps...
Trendnet TEW 652BRP Wireless N Home Router (710931600599) Logo
41 people viewed this question
Top Trendnet Computers & Internet Experts
David Payne
David Payne
Lynne
Are you a Trendnet Computer and Internet Expert? Answer questions, earn points and help others
