Question about Nikon D80 Digital Camera with 18-135mm Lens
Shutter won't release
When I press the shutter the auto focus moves the lens back and forth but the shutter doesn't release. Not a battery problem. Sometimes the shutter releases if I insist but it sounds sluggish
  • 1 more comment
  • hungarianhil Jan 23, 2009
    I have the same problem with both my lenses 18-135mm and 70-300mm The shutter will will close and I have to push on the button again to get to see the picture and then the top 1/4 of the picture is black.
  • annchov Jan 25, 2009
    My lens is a 18-135.
    I accidentally fixed it by switching the AF setting to af-c.
    Now I have to figure out why that worked. Thanks for your help.
  • Larry Meador May 11, 2010
    Which lens are you using? Do you have another lens to try this with? If so, does it happen when using all lenses?
  • 3 Answers
If the lighting is low and shutter speed is set for a long period of time its the function of the camera taking the picture. If it is a malfunction of the shutter take it in for cleaning you might have foriegn material stuck in your shutter mechanism
Posted on Jan 24, 2009
My Nikon Nikkor 18-135mm f/3.5-5.6G ED-IF AF-S for Digital SLR lens does not seem to auto focus well. Sometimes the lens will focus and unfocus and refocus constinely. Is this normal??
You did not say which camera body you are using, but you probably have three different auto-focus modes on you camera. You might be using the wrong one.
The modes are as follows:
AF-A Mode: Camera automatically selects single-servo autofocus when AF-A subject is stationary, continuous-servo autofocus when subject is moving. Shutter can only be released if camera is able to focus. AF-S Mode: For stationary subjects. Focus locks when shutter-release button AF-S is pressed halfway. Shutter can only be released when in-focus indicator is displayed.
AF-C Mode: For moving subjects. Camera focuses continuously while AF-C shutter-release button is pressed halfway. Photographs can be taken even when in-focus indicator is not displayed.
Dec 19, 2012 | Nikon Nikkor 18-135mm f/3.5-5.6G ED-IF...
How do I set the resolution on my Canon SD850?
The instructions for changing the resolution are on page 30 of the manual.
If the pictures are fuzzy, increasing the resolution won't help. The most likely causes of fuzzy pictures are as follows
1) Focus. Check to make sure the focus is on the subject. If something else in the picture is sharp while others are not, then the camera may have focused on the wrong subject.
2) Subject motion. If moving objects are fuzzier than stationary objects then you need to use a faster shutter speed (or flash).
3) Camera motion. Just because the camera is on a tripod doesn't mean it doesn't move. One philosophy says that if a tripod is light enough to be carried then it's not sturdy enough. For a compact camera like the SD850 that likely isn't the problem. However, you can still shake the camera when you press the shutter release button. Try setting the self-timer. This allows time for the vibrations to die down before snapping the picture.
In your particular case, I think we can assume that the subject isn't moving, so #2 doesn't apply. To assure proper focus, make sure the painting is flat and perpendicular to the lens axis. If the painting is tilted relative to the camera, then different parts of it will be at different distances and the camera won't be able to keep all of it in focus.
Also, make sure the front of the lens is clean.
Feb 03, 2012 | Canon PowerShot SD850 IS Digital Camera
I have a Nikon D80. When I went to use it recently (having charged the batteries) - the shutter would not release every time. I can find no reason for it - it is an intermittant fault. Can you help?
The shutter will not release if the camera is unable to obtain focus. If the switches on both the camera body and the lens (if equipped) are set to auto focus, the camera will prevent the shutter from releasing. The most common cause of a focus problem is the lack of light. The "focus assist" light on the front of the camera will come on automatically for a moment in dark places to help the camera gather enough light to focus. If you haven't disabled the light in the menu, make sure it isn't obstructed.
You can override the whole auto focus issue by setting the switches on the camera / lens to "manual focus" instead. Of course, this means that you are shifting the responsibility of focusing from the camera to you. The camera will release the shutter every time in this situation.
If you still have problems, provide the mode you're running and the lens you're using & I'll try to help out some more. I hope this helps & good luck!
Oct 11, 2011 | Nikon D80 Digital Camera
I just bought a Nikon DX ...and I have used it twice on "self-timer" mode...but when I attempted to use it today....when I pressed the button down, it just wants to focus back and forth ant the...
When the lens moves in an out it is TRYING to focus. In some conditions the auto focus gets confused. Move your field of few and press the shutter button down half way to lock in focus. Then move it back (to original view) and finish taking the photo (pressing down the rest of the way).
Dec 21, 2017 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
New Canon EFS 18-135mm IS lens failed to auto focus on EOS Rebel XTI and shutter won't release to take photo. Lens over a few months has worked without a problem. What is the problem?
Make sure both the lens and the camera are switched to af (auto focus). If that doesn't work remove the lens and replace it to make sure it is mounted properly. You can also check the camera with a different lens to make sure it isn't a problem with the settings on the camera. If all of that fails take it to a camera or electronics store that does service work to make sure it hasn't been damaged.
Jul 30, 2011 | Canon Cameras
My shutter won't fire using 18-55 lens, either on Manual, P or Auto mode. It is set to AF. But when lens is set to MF, shutter fires. I tried switching to another lens and shutter is perfectly fine.
I could be that your lens isn't focusing. If the Auto focus can't find something to focus on the shutter won't fire. If you are shooting in low light sometimes it has trouble try shooting something that is well lit. also your auto focus point may be somewhere other than the center. there is a button on the top of your camera that looks like this [ ][ ] [ ] [ ]
More or less that will switch where your focus point is. If you look in the view finder and see a red dot when you push on the shutter button that is your focus point. push the above button until the red dot is in the centre. that may fix your problem.
Jul 26, 2011 | Canon EOS 450D Digital Camera with 18-55...
\my D50 is not following through when I press the shutter release on auto focus-am able to take a pic on manual. When pressed, the camera makes a whirring noise but does not finish
Your lens might have an issue caused by some sort of shock or impact. Before anything just try to gently turn the focus ring on the lens while on auto focus to see if it pops back into place. Sometimes this actually takes care of the issue. Just DON'T FORCE IT. If this doesn't solve your issue then contact a Nikon authorized service center because your lens is going to need repairs. Hope this helps!
Hiram
Photo Tech Repair Service
110 East 13th Street
New York, NY 10003
212-673-8400
Jul 07, 2011 | Nikon D50 Digital Camera with 18-55mm and...
It won't take pictures sometimes. push the shutter button and nothing happens.
The Nikon D40 in Auto Focus mode will only allow the shutter to operate when the image is in focus. When looking through the viewfinder, the bottom edge provides information relative to what you are looking at. See the image below:
Item 2 is the focus indicator. It must be illuminated to allow the shutter to release. If it is not illuminated, the lens has not been able to determine the correct focus. This can happen when attempting to take a picture in low light conditions. Make sure that the front facing "focus assist lamp" on the camera (between the shutter release and lens) has not been blocked or disabled (Settings Menu # 09) and try again. Many times, you will see and or hear the lens "hunt" for proper focus - the lens will travel from one end of its focus range to the other trying to find focus. When it can't, it stops and prevents the shutter from releasing. You can get around this "unable to focus" issue by changing the position of the switch on the lens to "Manual Focus" mode, detailed below:
If a lens has an "A - M" switch, move it to "M" to manually focus. If the switch says "M/A - M " then leave on M/A (unless you're going to be taking several or more in manual mode), as these lenses may be focused manually at any time in either position. As soon as you tap the shutter button in M/A you return to autofocus.
More advanced lenses, like the 18-200mm, 70-300mm VR and 18-135mm, and any lens with an M/A position, may be focused manually at any time without moving any switches. Leave them in their A or A/M positions.
I hope this helps and good luck!
Jun 13, 2011 | Nikon D40x Digital Camera
I have a D5000 camera w/ kit lens VR 55-200, less than a year old. Recently and only occasionally what is happening is when I press the shutter release button, the lens won't focus, it won't move...
Your camera is still under the one year Nikon warranty. Call Nikon's repair depot at 1-800-NIKON-US (1-800-645-6687) 9AM-8PM EST, Monday to Friday. They will verify your warranty and assist you in returning it for repair.
Jun 08, 2011 | Nikon D5000 Digital Camera
I have a brand new nikon coolpix s3000. it's on full-time auto focus. Any ideas?
You can change this in the menu while in shooting mode. This is from page 48 of the manual:
Choose how the camera focuses.
A (auto) M d (Shooting menu) M I Autofocus mode
A Single AF (default setting)
The camera focuses when the shutter-release button is pressed halfway.
B Full-time AF
The camera focuses continuously until the shutter-release button is pressed down
halfway. Use with moving subjects. The sound of lens drive movement will be heard
while the camera focuses.
Sep 28, 2010 | Nikon Coolpix S3000 Digital Camera
Nikon D80 Digital Camera with 18-135mm Lens Logo
456 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
