Question about Gateway FHX2300 LCD TV
My fhx2300 gateway monitor has a constant flicker that makes it difficult to view for any length of time
You can see the picture , but the inconsistent light causes a flickering effect that gives you a headache.
SOURCE: Blue light flickers, but no picture
I have a gatway fpd2185w the blue light blinks and then dims and the power button dosent work.
Posted on Aug 18, 2009
budmrtn
  • 11361 Answers
SOURCE: fpd2185w Flicker
Check out your power supplycapacitors
http://s807.photobucket.com/albums/yy352/budm/Gateway%20FPD2185/
Posted on Dec 22, 2009
bammbammfran
  • 159 Answers
SOURCE: Flickering screen (likea strobe light)
Problem with flickering is in the board that is mounted to the back of the lcd screen. Part is only available in China.
Board will either need replacing or repairing (if it is repairable? Not all are)
I repair lcd monitors on ebay and just repaired one of these boards.
ebay id: bammbammfran
Posted on Mar 07, 2010
bammbammfran
  • 159 Answers
SOURCE: No picture on my Gateway monitor
If you get power to the controls and you don’t have the startup sound or see the gateway logo when you plug it in, the main board may be bad.
If your picture was pinkish or dark at the top or bottom when it was working then you may have 1 or more of the bulbs failing.
If you have the startup sound and see the gateway logo and the screen just flashes and the power buttons stay lit, then it sounds like probably the inverter may have went.
Take the screws out of the bottom rear edge (these hold the front trim), and the 4 big black ones at the middle of the back that hold the stand bracket.
The trim then unsnaps. {Be aware of the small ribbon to the power button board on the right edge}Start at the bottom and release the trim (pulling up the trim on the screen side usually starts it off), then work your way up each side bottom to top ((a pocket knife or thin putty knife even a credit card, will help release the catches as you work your way up)
Then unsnap the top edge (rocking it while lifting helps)
Disconnect the ribbon at the power button board, (Tiny latch lifts up on a hinge and ribbon slides out)
Once trim is off, remove the 4 corner screws that hold the screen in. Then the screen will lift out with all the guts. You may have to pry up on a corner with a screw driver to get it started.
The inverter is under the medium size metal case.
The power board and main board are under the large cover.
You’ll then have to remove a bunch of screws including the usb board ones and unplug the bulbs and wire to the screen
then the power board and control board is under the center area under the metal cover
Shout if you need more info.
If you email me a good picture of the boards to bammbamm@ptd.net , I may be able to get a better idea if it is the inverter from a visual.
Thanks Fran
  • 80 Answers
SOURCE: Gateway FHD2400 flickering / blinking / flashing on and off...
Open the monitor, examine the circuit boards. Look for small components that look like small cans, these are capacitors. If you see any that look bulged on top, then your problem can probably be solved by replacing these. Check out the following sites;
http://www.youtube.com/watch?v=9Q6_TgNJvQw
Follow the directions and good luck!
Posted on May 15, 2010
Gateway fhx2300 monitor turns on then screen goes black
Just wondering how you even got to the motherboard...I got the stand off of the monitor and that's it, please help
Jan 24, 2013 | Gateway Computers & Internet
I have an fhx2300 monitor and when watching movies on it, random pixel will start turning neon green. The computer will display blue screen saying the driver crashed and then the monitor will display a...
I would go to the Gateway website (http://www.gateway.com/gw/en/US/content/drivers-downloads) and see if your model has a driver update. Drivers Downloads listed for Vista but it should work for Win7-64 bit.
Jun 05, 2017 | Gateway FHX2300 LCD TV
Power went off and now my gateway monitor displays GatewayWhield theft Deterrence. I never set up a password how do I fix this problem. Connect the monitor to the pc you would think fixes it but no. Help
Disable GatewayShield Theft Deterrence
  1. Launch EzTune.
    View Picture
  2. In the EzTune window, click the Plug-ins tab, and then click Theft Deterrence.
    View Picture
  3. To deactivate theft deterrence, click Disable Theft.
    View Picture
  4. Type the PIN for the monitor in the appropriate field, and then click Accept.
    View Picture
  5. A screen confirms that theft deterrence is now disabled.
    View Picture
Dec 03, 2010 | Gateway FPD1785 Monitor
Montior goes black i turn off the monitor and turn it back on i can do about 2 things and screen goes black again repeat this as many times as i want. Gateway FHX2300 monitor
My monitor has been switching connections on me randomly. Hit the menu button. The one to the left of the power butter when facing the screen. Hit the left arrow twice then hit the menu button again. This will open up the screen where you can choose one of three inputs. I'm going to assume that it is on the incorrect input so use the arrow keys highlight what input you are using and the hit menu button again and your screen should return to normal. Mine only does this randomly when it goes into screen saver, hibernate or sleep. I don't know how to permanently get it to stop doing it though.
Aug 23, 2010 | Gateway FHX2300 LCD TV
I have a green vertical line on my Gateway LCD Monitor FHX2300 . How can I fix this? It's a new monitor.
if you look closley and see if all the pixals are in one line
then the fault is the display itself
Jun 02, 2010 | Gateway FHX2300 LCD TV
MONITOR VERY DARK
Try using the FN key and the up arrow at the same time while tapping the up arrow, also make sure that if you have vista, you are not in "power saver mode". if there is no light at all coming from your screen, you may have a bad display bulb, this could also be a faulty invertor, but you would have noticed a constant flicker.
Sep 07, 2009 | Gateway Computers & Internet
Gateway sx2800-03 compatibility problems with Samsung 2494hm
you have the wrong video driver - go to gateway and redownload the video driver and install it reboot and presto...
Aug 31, 2009 | Gateway SX2800-01 PC Desktop
Flickering picture
chech out some other devices near by to the monitor, they might cause interfearence and in a result your monitor flickers.
1. If there is nay CVT/UPS near your monitor put it away.
2. If you have any speaker without magenetic sealed it will cause flickering, keep it away from monitor.
Otherwise your monitor need to be get service. So please contact your manufacturer service centre.
Thanks
Iqbal
Mar 30, 2008 | Gateway FPD2275W LCD Monitor
Gateway FHX2300 LCD TV Logo
90 people viewed this question
Top Gateway Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Gateway Televison and Video Expert? Answer questions, earn points and help others
